#1126 |
Re: 1976 Square "Simple Green"
Got mine set up...this vid is the 3rd start...crappy cell phone vid...sorry...son at exes and I'm working solo today...
Need to drive and tune tomorrow... Runs great so far....looks like I need a low side fuel regulator tho... ![]() https://m.youtube.com/watch?v=zIqaVJEVBXY
71 C10: Crush10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=650510 |
#1127 | |
#1128 | |
I need to hook up a regulator...that needle jumping around makes me nervous. ..
#1129 |
#1130 |
I'm in the same boat. I'll just get a locked out 2 wire and let the fitech work its magic.
Posted via Mobile Device |
#1131 |
#1132 |
New dizzy headed my way.
#1133 |
Doesn't ever end does it?
#1134 |
#1135 |
After the 3rd set of pushrods I was about to dump mine in the lake. I'm in double what I thought and still need paint!
#1136 |
Signals in the bumper.
Beautiful truck! I'm surprised I haven't seen you running around town.
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
#1137 |
#1138 |
Went with a Pertroix Dizzy this time. Never used that brand before figured I would try it out.
#1139 |
Second Chance Program
Something I have been wanting to see or hear reviews on that I haven't yet is how the system behaves in everyday driving conditions like quick stops, quick back up maneuvers, stop and go traffic etc.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
#1140 |
![]() Join Date: Sep 2014
I've read they are being used in autocrossing with good success.
#1141 |
#1142 |
Dizzy is in hand!!!
#1143 |
#1144 | |
I know the pieces fit
#1145 |
Fire in the hole!! Well it started. Still had to roll into the throttle and the MF won't idle in gear?!?i did not adjust anything I left everything the way they sent it to me. I am at a loss. And I am pissed off.
#1146 |
This **** is getting ****ing old. I put a carb on it this ***** has zero problems. Put the FiTech on have to roll into the throttle so it will start and dies in gear it should idle up but it won't. I sent Ken and Jeremy a email telling them. Told the I am giving it 1 more try so they need to come up with something. If it does not work I am sending it back and getting my money back and we can part ways. I am over this ****. Makes me not even enjoy my truck now.
#1147 |
At least you got yours back.
The mother board is toast in mine.(No warranty for me) But cant seam to get it back? AS IS. Good luck on your finale outcome.. Logging out.... |
#1148 |
This is the BS email I got back. I am hot right now!!!
I think I had set the idle speed to 700 something for my test car – so, go into the initial setup and set it to your 1000+ rpm as you had it. Make sure you open the throttle screws to suit your engine also. It is the normal setup procedure to adjust the throttle screws so that at warm engine it uses low IAC steps. Also, for cranking, there’s adjustments that you can make yourself to the cranking fuel. It’s engine dependent, so you’ll have to do your own testing to get them set correctly. There’s things that don’t self learn, such as cranking fuel, accel fuel, idle screw settings. Adjust them to get it working as needed. Those are the things that you had issues with, so follow the instructions to set them up, and it should be working. Good luck! |
#1149 |
They better not **** me over on my money if this does not work. I find it hard to believe from that last email with all of these they have sold that everyone is havin to make that many adjustments.
#1150 |
Well 4 hours later no change. So I have called over a few people. 2 guys own a hot rod resto shops the other owns a tuning shop and builds race engines and the other owns a import shop that does turbos and injection system for ricers. If we all can't get it working no hope for this FiTech on my truck. They are coming over and taking everything off my truck including fuel system. And they are going to install it all from scratch. I will know something before I go to work in the early am. Pulling a all nighter.
