Old 07-18-2020, 12:34 PM   #1126
Gregski
Post Whore
Gregski's Avatar
Re: A '54 named Busty
Originally Posted by joedoh View Post
haha!
but in the good news department, that OEM flex joint isnt really made to take that much angle anyway, even if it didnt hit you would wear the rubber out of it pretty quickly. get a real deal u joint for that, you may need a longer steering shaft too. I know the struggle!
looking at your lengths you may be a candidate for a jeep cherokee (not grand cherokee, the early 80s-90s box) shaft, it has u joints at both ends and a slip shaft, it may be just right and has u joints at both ends. I know you have a camaro clip but the principle and most importantly the DD and splines are the same. those cherokees are all over my local craigslist from the 4x4 guys, parting them out.
V8 S10 Steering shaft upgrade from a 1994 Jeep Grand Cherokee - YouTube
you always put in so much detail in order to help me, I so appreciate it brother, thank you so much, this has been added to my Do It Right List (... eventually)
Update: after removing the compression coupling I noticed that the bottom shaft was only inserted like 1/4" of an inch instead of like an 1 1/4" glad I took it all apart, by inserting it in fully that lowered the interfering bolt out of the way of the spark plug wire and switching to a shorter bolt fixed the problem.
As far as the angle I also noticed that my steering column sags about an inch at the firewall opening, so I must devise a proper lower steering column bracket, looking for ideas/advice?
looks like this Ididit beauty is just what the doctor ordered:
Gregski is offline   Reply With Quote
Old 07-18-2020, 07:07 PM   #1127
joedoh
joedoh's Avatar
huh I found one of those column clamps in a box of parts I bought and used it on a 41 chevy truck, they are handy! I had no idea where it came from.
you could always just get some bluetooth cordless spark plug wires!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 07-18-2020, 08:22 PM   #1128
Gregski
Post Whore
Gregski's Avatar
I will handle the humor around here, thank you!
jk... that was ridiculously clever and funny
Old 07-18-2020, 08:25 PM   #1129
Gregski
Post Whore
Gregski's Avatar
can't wait to install these, and see if she will go into Closed Loop like a good girl
Old 07-18-2020, 11:48 PM   #1130
Gregski
Post Whore
Gregski's Avatar
new O2 sensors installed, truck now goes into Closed Loop like it is supposed to, sounds like a Cadillac and a Swiss watch had a baby, lovin' it
Old 07-19-2020, 01:42 AM   #1131
Wide Open
Sweet!
1972 K10
1986 K30 crew cab dually
2002 Z06
2007 Escalade
Wide Open is offline   Reply With Quote
Old 07-19-2020, 01:11 PM   #1132
Gregski
Post Whore
Gregski's Avatar
having fixed our steering column spark plug wire interference problem we moved on to the pesky leaky power steering pump
it appeared the precipitation was limited to only when the vehicle was running, and the steering pump was under pressure
further inspection revealed the high pressure hose adapter to the -6 AN fitting as the culprit
it appears out of the 47 different adapters we were using the wrong one (imagine that)
Old 07-19-2020, 01:12 PM   #1133
Gregski
Post Whore
Gregski's Avatar
however in an unprecedented happenstance we happened to have the proper one in our drawer of everything you have except what you need
please don't ask me what the different adapter / fittings are called, I reserve the right to Ron Swanson this and I do not wanna know, ha ha
Old 07-19-2020, 01:14 PM   #1134
Gregski
Post Whore
Gregski's Avatar
... literally 5 minutes after we fixed the power steering leak !!!
yup, gosh darn it, the water cooled crank pulley sprung a leak
Old 07-19-2020, 01:56 PM   #1135
8man
The ol' Texas two-step, one step forward, two steps back.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 07-19-2020, 02:02 PM   #1136
Gregski
Post Whore
Gregski's Avatar
ah yup, so off to AutoZone to get a new water pumpulator
Old 07-19-2020, 02:52 PM   #1137
Gregski
Post Whore
Gregski's Avatar
ah what the hewk...
yup she runs and drives!
Old 07-19-2020, 02:54 PM   #1138
Gregski
Post Whore
Gregski's Avatar
sorry about the shadows
Old 07-19-2020, 02:56 PM   #1139
Wide Open
That is awesome!!
Is that post pumpulator fixin or the heck with it runnin?
1972 K10
2002 Z06
2007 Escalade
Old 07-19-2020, 02:58 PM   #1140
Wide Open
Umm, I think you may have sprung a sunshine leak in your bed.
1972 K10
2002 Z06
2007 Escalade
Old 07-19-2020, 03:00 PM   #1141
Gregski
Post Whore
Gregski's Avatar
Originally Posted by Wide Open View Post
That is awesome!!
um... the latter (technically Pontiac Mike had me tighten the bolts a bit and either that fixed it or we just ran out of water, ha ha
Old 07-19-2020, 03:21 PM   #1142
8man
And so they lived happily ever after...
8man-aka Robert
Old 07-19-2020, 03:46 PM   #1143
Gregski
Post Whore
Gregski's Avatar
First Test Drive Video post LS Swap
this is nice and gentle since I don't have any conduit on my wiring harness and don't want to risk frying any wires, and you've seen my brakes ha ha or lack there of
squeaks and rattles free of charge
Old 07-19-2020, 04:14 PM   #1144
8man
Big day, huge. Congrats.
8man-aka Robert
Old 07-19-2020, 04:48 PM   #1145
joedoh
joedoh's Avatar
perfect!
Old 07-19-2020, 06:00 PM   #1146
Gregski
Post Whore
Gregski's Avatar
perfect!
thank you mate, glad I have your attention, got one pesky issue, she rubs in da front passenger side wheel when turning right but not when turning left
I think maybe the previous owner cut the coils to lower her some, not sure, but
I expect nothing short of part numbers, bar codes, retailers cats names, and a multitude of suggestions on how to fix it from you, ha ha
ready set go...
Old 07-19-2020, 06:03 PM   #1147
Wide Open
Nice job dude!
Remember that all LS swaps demand obligatory burnouts. Right there in the cul de sac will be fine. Don’t be shy.
1972 K10
2002 Z06
2007 Escalade
Old 07-19-2020, 06:07 PM   #1148
Gregski
Post Whore
Gregski's Avatar
Nice job dude!
ha ha, I would but I am already on a first name basis with the HOA since the previous owners cut the tree down in our front yard, replaced bark with white rocks, and painted the side gate the wrong shade of gray without getting their permission before we even moved in, therefor I tread lightly (and keep in mind this is my third truck, so I already laid down some solid one wheel peels in da past, hee hee)
Old 07-19-2020, 10:02 PM   #1149
joedoh
joedoh's Avatar
ready set go...
haha i get it, i can be too thorough. its the engineer in me, sorry. no cats names this time i promise
Old 07-19-2020, 11:24 PM   #1150
Gregski
Post Whore
Gregski's Avatar
after a proper power nap it was Game Time
the old pump came off quicker than a prom dress
