Old 01-28-2016, 11:01 PM   #1151
MySons68C20
MySons68C20's Avatar
Re: 1976 Square "Simple Green"
Originally Posted by RodsGreen10 View Post
Well 4 hours later no change. So I have called over a few people. 2 guys own a hot rod resto shops the other owns a tuning shop and builds race engines and the other owns a import shop that does turbos and injection system for ricers. If we all can't get it working no hope for this FiTech on my truck. They are coming over and taking everything off my truck including fuel system. And they are going to install it all from scratch. I will know something before I go to work in the early am. Pulling a all nighter.
You rule take some pics!!!
MySons68C20 is offline   Reply With Quote
Old 01-28-2016, 11:08 PM   #1152
RodsGreen10
RodsGreen10's Avatar
Email I just got. I have a 3500 stall and my motor is a 385.
You’re running a gigantic camshaft. It’s going to be a process to get it all done properly. Try raising the idle speed even more, and opening the idle screws. That cam should be used with a 4000+ rpm stall converter. If it’s lugging down too hard, it’ll be hard to keep it running with anything with that cam, but cranking open the screw and setting a higher idle speed should help.
If cranking takes opening the throttle, reduce the Crank Fuel.
Keep trying adjustments to suit your motor. It’s hard to make something work for a stock 289 engine and a monster cam 383 with the same settings, so, give it more time before throwing in the towel.
Good luck!
Jeremy
RodsGreen10 is offline   Reply With Quote
Old 01-28-2016, 11:10 PM   #1153
RodsGreen10
Lol. I am doing all that I can so this will work. Plus I am pisses off so I will make something happen. Well I know I will be pissing the wife and the neighbors off tonight lmao. I love my wife but could careless about my neighbors.
Old 01-28-2016, 11:17 PM   #1154
RodsGreen10
Hell I forgot my new dizzy is extremely nice. Never ran a Pertronix but sure is nice. Has that new HEI III module with multispark and a digital rev limiter. Money well spent.
Old 01-28-2016, 11:21 PM   #1155
MySons68C20
To lazy to read back can you use timing control with the Pertronix? Do you run mech only or w/vac advance?
Old 01-28-2016, 11:28 PM   #1156
MySons68C20
Distributor porn pics too lol!
Old 01-29-2016, 12:41 AM   #1157
Trucker79
Trucker79's Avatar
I have faith in you Rod! There has to be something with the idle settings that we are overlooking. I am sure once you figure it out it'll run good.
Trucker79 is offline   Reply With Quote
Old 01-29-2016, 05:48 AM   #1158
RodsGreen10
Do not use timing control. Mechanical only no vac advance.
Old 01-29-2016, 05:50 AM   #1159
RodsGreen10
Well thought about taking PTO today but I went into work. Left the guys at the house. Everything got installed again made a few tweaks on the install. And when I left it still had not started. So when they let me know something I will let you all know.
Old 01-29-2016, 06:24 AM   #1160
RodsGreen10
They all did agree that I had all my fuel setup installed correctly.
Old 01-29-2016, 08:15 AM   #1161
swampbog
swampbog's Avatar
Jesus christ Rod, I would of tossed in the towel after the first4 hours....then I would be like you and try it again.
I'm like you, I won't give up till I tried everything and then some more. Which sounds like having those guys come over is the "then some more".
Hope this works and your out their spinning the tires soon.
swampbog is offline   Reply With Quote
Old 01-29-2016, 08:56 AM   #1162
RodsGreen10
Lol. Swamp the towel is wet and rolled up ready to be thrown. It's funny the stuff people say that have never seen the system. This is why they did away with tbi. This software is cheap. The handheld is cheap. Why did they do this. This thing needs a carb not tbi. That some comments I heard last night. So hope it works if not I just want to send it back and get my money back.
Old 01-29-2016, 09:11 AM   #1163
swampbog
swampbog's Avatar
This is why they did away with tbi. ........ This thing needs a carb not tbi.
Actually thinking about it, why not toss it back and then wait for the port injection system to come out?
Not sure on the price of the port injection but hopefully it'll be cheaper than the other brands.
I thought of it for myself but I would have to take my intake and drill holes for the injectors or buy a intake from Edelbrock that already has ports drilled for their system http://www.summitracing.com/parts/edl-35310, either way its more than I want to spend.
Now I know FiTech is probably making one with intake for the Chevy motors so it should be easy to install.
Old 01-29-2016, 09:17 AM   #1164
RodsGreen10
They are. But if I can't get this working I am done with EFI on this truck. Good carb a AFR gauge some jets and extensions good to go. Lol. I am at the point I have put so much money into my truck that irbid time to drive and enjoy it. Which I was until I bought the FiTech and put it on. If I could just get the FiTech to work I will be happy.
Old 01-29-2016, 09:34 AM   #1165
MySons68C20
What puzzles me is what makes your install unique that you are having these problems and not a lot of others? I hope you get it sorted out and find it's something simple or overlooked. Great idea having a group of guys in the know helping you gettin it done!
I appreciate you keeping all of us in the loop!
Blake
Old 01-29-2016, 09:42 AM   #1166
RodsGreen10
Blake
I keep being told by FiTech that it is the idle adjustment and the crank fuel and the IAC when engine is at temp. So I keep adjusting them per instruction. With same results. And I am puzzled also. What makes my setup different that I am having to go into the systems and make so many adjustments. Carbs are a little more forgiving than EFI but damn. I should not have to make that many adjumenst then that throws the self learning out the window. But that statement is misleading itself for these type of setups. Never had a issue before with a carb in this motor 3 different carbs. And put efi and everything goes to hell.
Old 01-29-2016, 09:42 AM   #1167
swampbog
swampbog's Avatar
It's a green truck
Old 01-29-2016, 09:47 AM   #1168
RodsGreen10
Cold idle is @1200 in park
Warm idle is @ 1000 in park
and I was told I need to idle it up more. Damn come on.
Old 01-29-2016, 09:51 AM   #1169
RodsGreen10
It's a green truck
**** that superstitious ****. Ran like a scalded dawg. From day one I got new motor and all the new ****. So it not the color it's not the motor it's not the torque converter it's not a vacuum leak. It's something in that little crap handheld that is not set right to mess with my setup. FiTech can't tell me I still habe not found the magic numbers yet. I need some coffee.
Old 01-29-2016, 10:00 AM   #1170
RodsGreen10
I will get it or FiTech will get it. I just want it to work. I didn't spend all this time and money I go back carb.
Old 01-29-2016, 10:47 AM   #1171
68Timber
I know the pieces fit
68Timber's Avatar
Do you mind posting your cam specs, and whether its roller or flat tappet?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-29-2016, 11:01 AM   #1172
RodsGreen10
I posted it before but will again.
Roller
110 lobe
Cam @ 50 is 253
AFR 220 heads
Old 01-29-2016, 11:03 AM   #1173
funkatation
Rod,
Think they would send you a non adder system to test? Or another system at all?
funkatation is offline   Reply With Quote
Old 01-29-2016, 11:07 AM   #1174
RodsGreen10
Originally Posted by funkatation View Post
Rod,
I asked for a new unit. No dice. They got mine tested said it was good sent it back. They made adjustments to the tune and fine tuned it said it was running great on the vehicle they put it on. Told me to bolt it on and try it out. Even with the adjustments they made still doing the same. Roll into throttle for start and won't idle in gear. I am going to bump the idle up more and see if that helps. I told them in a email that this weekend will be nice in the 60's sunny. So if it does not get fixed this weekend monday I will be getting a RMA# for a return and refund.
Old 01-29-2016, 11:17 AM   #1175
y5mgisi
Second Chance Program
y5mgisi's Avatar
This is just me playing devil's advocate, but, when I saw that you were going to run this self learning kit on a (I think you said) 650hp small Block, I figured there was no way it was going to work out. I'm sure you can get it to work, but with that big of a cam, that crazy of a motor, and this fairly simple unit, it's going to take some doing to get it to run right and especially start right. I Will say that it is entirely possible that yours has some unique problems. I would personally want to maybe even try installing it on a different car/truck with smaller cam and hp to see how it runs with that. That to me would be a good way of determining if it's your setup, or the unit.
Playing devil's advocate again would be to remember that yes, this unit is cheap. It's the cheapest on the market. How do you think they got it to be so cheap? It's probably not going to have the quality that some of the more expensive units like the holley terminator system does such. But those are $2500+!
If you really wanted the absolute best injection for your truck, a fully custom tuned multi port injection system would be best in my opinion. I would personally assume that my truck would need an entire day with a good dyno tuner to get it to run reasonably well constantly.
Backing up a bit, again, I do think you will get yourself dialed in. But I think it's going to require the frustration of it not being as simple as you thought originally. In fact, far from simple.
So that's my opinion. And I give it only in hopes of it bringing back from the edge and remembering that this is a hobby. It's fun but sometimes insanely frustrating and you just have to get through it in as enjoyable a Manor as possible.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
