Closed Thread
Old 09-22-2014, 08:26 PM   #1151
Delo69
Delo69's Avatar
Re: What did you do to your truck today? Chapter II
Had my inline 6 resealed, cleaned and painted and then I added the decals for that clean from factory look..I'm happy with the results..
Before and After.
_____________________________________
Dennis
1969 C10 250 w/3 on the tree - project/weekend warrior
2010 Subaru Impreza - daily driver
Delo69 is offline
Old 09-22-2014, 08:35 PM   #1152
ole dollor
ole dollor's Avatar
Before and After.
that made a big difference....looks great.
ole dollor is offline
Old 09-22-2014, 08:50 PM   #1153
CST10
CST10's Avatar
Drastic differance. In like it. Nothing like a clean motor in the bay.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 09-22-2014, 11:14 PM   #1154
9teen69
9teen69's Avatar
Engine looks really good!
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline
Old 09-22-2014, 11:30 PM   #1155
9teen69
9teen69's Avatar
Installed new green glass, weather-stripping and rebuilt vent window on passenger side. My stainless trim was in good enough shape for a daily driver.
Now I see why people buy new ones or get rebuilt from RogerKoop. They were a PITA but turned out nyce. One more to go.
9teen69 is offline
Old 09-23-2014, 04:55 AM   #1156
Mike_The_Grad
Mike_The_Grad's Avatar
Found out had a vacuum leak, and it wasnt brake booster or pcv... P.O.E. determined intake was at fault. Pulled it and this is what I found... Its funny how the saying "hindsight is 20/20." Rings so true. I'm new to everything as far as putting together an engine goes.the gasket did last a month I must say. I have since learned the correct way of installing an intake on a rebuilt motor. And now am pulling a steady 19.5hg straight from intake. also lowered my idle from 1,000 down to about 600. Oil change was due,also regapped plugs. Next on the list is upjet my Q-jet. And reseal the rear end. Other than that. I'm happy to say the "mechanical part" is taken care of. Next is "cosmetics". let's see how deep the rabbit hole goes......
1972 C/10 LWB - Mine
1964 C/10 LWB - My Dad's
Instagram: Mike_The_Grad
Mike_The_Grad is offline
Old 09-23-2014, 07:32 PM   #1157
BugzC10
BugzC10's Avatar
Finshed installing Vintage Air Sure Fit A/C system, new 4 core radiator, new March pulleys and 100 amp alternator. Get the A/C charged up next week.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 09-23-2014, 08:42 PM   #1158
texjake
texjake's Avatar
All gasket mfgs should never be including that cheap ass rubber gasket for the front or rear intake manifold for Chevy engines. It's been that way for way too dang long. It's always just better to toss that damn thing in the floor & just to put down a bead of silicone and never look back.
"Now all I need is a shop to go with my shop vac!"
texjake is offline
Old 09-23-2014, 09:08 PM   #1159
In The Ten Ring
I showed it off today to a contractor who needed to store some tools in my garage. He was immediately impressed with it, even though it's up on blocks! That might help motivate me to get back on it as soon as I have the time.
In The Ten Ring is offline
Old 09-23-2014, 10:57 PM   #1160
texasld
texasld's Avatar
Originally Posted by Andy4639 View Post
Have you posted this on the LS swap thread yet? Nice work would like to here about the swap.
There are several. Would you Kindly point me towards the right direction? I will happily post some info.
It's also in my build thread.
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress)
2015 GMC 2500 Duramax (Daily Driver)
1999 Jeep TJ
2010 Harley Street Glide
Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981
texasld is offline
Old 09-24-2014, 06:25 PM   #1161
vidman
vidman's Avatar
Changed the valve cover gaskets to felpro-1635 and Installed my Track-bar.
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline
Old 09-24-2014, 07:12 PM   #1162
Econman
Econman's Avatar
Just ordered my new Hughes torque converter and Lokar kickdown cable and Lokar throttle bracket from Summit.
Econman is offline
Old 09-24-2014, 07:41 PM   #1163
ole dollor
ole dollor's Avatar
looks very nice...good work.
Old 09-26-2014, 07:38 AM   #1164
Econman
Econman's Avatar
Installed a new servo piston sleeve and piston, plus got the valve body back in and tail shaft back on..
Econman is offline
Old 09-28-2014, 05:12 PM   #1165
Andy4639
Old member
Andy4639's Avatar
Wink Re: What did you do to your truck today? Chapter II
Well I got the brakes al swapped out. It didn't go as smooth as I had hope but I gotter done!
The original booster and master cylinder was all standard fittings, the new one was all metric fittings. Had to put new lines down to the a arm also.
While I was doing it I went a head and swapped the rear rubber hose tee out for the stainless one I've had now for over a year.
Everything is tight with no leaks so far. Going for a short ride and check everything again.
Had to use the old valve since the brake switch wouldn't fit the new one. I may order one if I can find one. O-Reilly's didn't have it and couldn't order it.
If anybody has a lead on one LMK.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline
Old 09-28-2014, 05:55 PM   #1166
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today? Chapter II
Here is a couple more of the S/S rear hose and Clear gear rear housing cover.I tie wrapped the hose away from the muffler also.
Andy4639 is offline
Old 09-28-2014, 10:23 PM   #1167
ole dollor
ole dollor's Avatar
[QUOTE=Andy4639;6859700]Well I got the brakes al swapped out. It didn't go as smooth as I had hope but I gotter done!
Very nice set up and nice and shinny....
Old 09-29-2014, 01:46 AM   #1168
texjake
texjake's Avatar
I painted the rear bumper with Rust-Oleum® truck bed coating.
Before & after;
texjake is offline
Old 09-29-2014, 09:05 PM   #1169
Andy4639
Old member
Andy4639's Avatar
Cool Re: What did you do to your truck today? Chapter II
[quote=ole dollor;6860125]
Thanks!
Andy4639 is offline
Old 09-30-2014, 05:30 AM   #1170
CST10
CST10's Avatar
Bought it drove to muffler shop then Drove it home.
MyToys:
CST10 is offline
Old 10-02-2014, 07:20 AM   #1171
Elliot949
Elliot949's Avatar
Got My Steering Wheel Yesterday... man this thing is NICE!!!!
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline
Old 10-02-2014, 09:18 AM   #1172
chevy2tom
chevy2tom's Avatar
Changed the cam,lifters, installed new studs, roller rockers, new valve covers (had to pull the booster to get the drivers cover on) new water pump, March serpentine pulleys & brackets, new power steering pump & break in the new cam. (More like a week, lol))
chevy2tom is offline
Old 10-02-2014, 04:04 PM   #1173
texasld
texasld's Avatar
Originally Posted by chevy2tom View Post
changed the cam,lifters, installed new studs, roller rockers, new valve covers (had to pull the booster to get the drivers cover on) new water pump, march serpentine pulleys & brackets, new power steering pump & break in the new cam. (more like a week, lol))
noyce!!!!
1999 Jeep TJ
texasld is offline
Old 10-02-2014, 06:51 PM   #1174
vidman
vidman's Avatar
Thank you..Today I pulled the side airbags out of my new seats and off to the auto upholsterer tomorrow..
vidman is offline
Old 10-03-2014, 10:11 AM   #1175
zellway
zellway's Avatar
I have been thinking of getting a Con2r wheel for my 56. keep me posted on how you like it! Looks great
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline
Closed Thread
