Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 11-05-2012, 12:12 AM   #1151
ItsRandy
ItsRandy's Avatar
Re: SoCal checkin' in
Originally Posted by robnolimit View Post
If anyone is interested, we could have a monthly meet up at our shop in San Bernardino
I could do that...sounds like fun. We could get a bunch of Jack in the Box tacos (2 for $.99) and hang out and tell lies and stuff.
ItsRandy is offline
Old 11-05-2012, 12:23 AM   #1152
VDOG
Grand PooBaa Member
VDOG's Avatar
That sounds like a plan. Im in.
Anybody know of a community college in OC or Long Beach that offers night classes in auto body repair?
Try Golden West College in the OC, and Long Beach City College. Only other school I know offers it is El Camino College in Torrance.
VDOG is offline
Old 11-05-2012, 12:24 AM   #1153
Mike Bradbury
Mike Bradbury's Avatar
I think a lot of guys would be up for a monthly meeting. Although I am down here in San Diego I could not make many of them but it would be nice to meet some more guys. The tacos are a plus too. LOL
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline
Old 11-05-2012, 12:27 AM   #1154
Drewsteezy68
Let's set this up. It's a new month.
Drewsteezy68 is offline
Old 11-05-2012, 12:50 AM   #1155
VDOG
Grand PooBaa Member
VDOG's Avatar
Mike I dont everybody is going to make all of them, but it should be a nice turn out from time to time. So come down when you can.
VDOG is offline
Old 11-06-2012, 12:21 AM   #1156
VWNate1
VWNate1's Avatar
Post Re : Starter Bendix
Originally Posted by hopped up View Post
Hey nate ny starter has 9 teeth
O.K. , now it is time to begin hitting the books (or OnLine Catalogs) and see how many different ones are available and what they fit , then scour some Wrecking yards until you find different ones and test fit............
I'm sorry I cannot offer hands on help but my driveway is full to the street with dead vehicles.....
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 11-06-2012, 12:39 AM   #1157
hopped up
hopped up's Avatar
Thanks vwnate. Id pretty much given up on my motor. But maybe (im hoping youre right) that i can still fix my problem. I really dont want to swap my motor. Im just at my whitts end!! Been fighting aith thos for over a year
hopped up is offline
Old 11-06-2012, 12:50 AM   #1158
VWNate1
VWNate1's Avatar
Unhappy Re : Starter Madness
I know how frustrating it is because I always get these weird problems when I buy abandoned projects then I have to figger out what the hell's going on (I'm currently buried in a $1,200 '91 Camry 4 door that whizzed right on past $4,500 in parts and isn't done yet.....)
Anyways , you've been offered free starters from several here and what I'd do is : remove the torque converter cover plate and gut the starter of brushes and solenoid , mount it to the engine and pull the plunger with a bungie cord etc. then hand rotate the engine and visually inspect the depth or the tooth mesh ~ I feel it has to be in there somehow , be aware this is just a " S.W.A.G. " but that's the 1st, thing I'd do as a good running engine , to me , is priceless and always worth saving .
Maybe it's the flex plate , maybe the crankshaft is bent ? . I dunno 'til it's looked at .
FWIW , we once had a bramd new '81 C-60 with a 4 bolt 350 , when Chevy machined the bare block new , the center of the main bearing saddles was 0.010" OFF (wow) - yet it started and ran , it vibrated pretty badly but I don't recall any starter troubles , it just beat itself to death in 10,000 miles .
My point is : someone had to take the time to really LOOK at it to figure out what the hell was wrong , I worked in a Major Fleet Repair Shop and they were all too (insert pejorative here) to be bothered taking the time....
This is why I always counsel most DIY'ers to JUST DO IT ! because you're interested and have the time , you'll usually do a better job .
'K ? .
Don't give up ! .
-Nate
Geezer
VWNate1 is offline
Old 11-06-2012, 01:31 AM   #1159
hopped up
hopped up's Avatar
Its juat soo strange that itll start perfectly fine a few times then start grinding all over again
Old 11-06-2012, 01:32 AM   #1160
hopped up
hopped up's Avatar
I sure have never experienced anything like this ever
Old 11-06-2012, 09:42 AM   #1161
VWNate1
VWNate1's Avatar
Post Re : Starter Griding
As it didn't do it while I was there , I don't know .
In general , grinding instead of meshing and cranking the engine , is caused by worn ring gear teeth on the flywheel (torque converter in your case) , the teeth usually get worn because 99 % of the time , the engine always comes to rest in the same position .
The simple Dealer fix is to loosen the flywheel bolts & rotate the flywheel one set of bolt holes , in the direction the engine turns ~ this means the engine now comes to rest with the least worn ring gear teeth aligned with the starter .
Of course , not always is it possible to do this as some applications have asymetrical bolt holes.....
This is why I feel your pain and wish I could get hands on it .
By assembling a no drag starter & hand turning the engine while observing it , you'll hopefully see what/where/if there's a meshing problem .
If the starter bendix's teeth touch the bottom of the flywheel's teeth grooves , it'll never work ~ this is why there are shims *but* , you cannot just jamb a couple in willy-nilly , you have to figure out what's what first .
Me ? I rather enjoy playing " Automotive Detiective " .
-Nate
Geezer
VWNate1 is offline
Old 11-08-2012, 06:15 PM   #1162
hopped up
hopped up's Avatar
Vwnate im on my second flywheel this year already and it still does the exact same thing . I swapped it the second time thinking it was the cause of the grinding which it wasnt
Old 11-08-2012, 08:55 PM   #1163
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Are you using the bracket that holds the end of the starter motor?
I had a truck doing the same thing till I located a bracket and installed it.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline
Old 11-08-2012, 09:16 PM   #1164
hopped up
hopped up's Avatar
Kevs classic , no i dont have that bracket. Its pretty hard to find kne i the junkyard around here. At least i havent had any luck. I made a bracket to keep the starter from moving sideways , but that disnt help
Old 11-08-2012, 09:51 PM   #1165
mx574
that would be cool. i vote for a sat or sun. because traffic from the oc to ie sucks so bad.
mx574 is offline
Old 11-09-2012, 11:08 AM   #1166
VWNate1
VWNate1's Avatar
Post Re : Sarter Problems
Dang .
I wonder what's going on .
I found two in my local P-A-P yesterday whilst doing my P.T. and was thinking about your starter issues .
-Nate
Geezer
VWNate1 is offline
Old 11-09-2012, 11:26 AM   #1167
hopped up
hopped up's Avatar
Well id be willing to buy one of ya if you have a spare
Old 11-09-2012, 11:33 AM   #1168
VWNate1
VWNate1's Avatar
Post Re: SoCal checkin' in
I don't have any spare starters and I don't think you should simply swap 'em out ~ try testing like I explained before ~ YOU are the On Site Mechanic Detective .
-Nate
Geezer
VWNate1 is offline
Old 11-09-2012, 12:39 PM   #1169
hopped up
hopped up's Avatar
Or let me knowl what pick a part you were at and ill go on sat to see if theyre still there
Old 11-09-2012, 12:40 PM   #1170
hopped up
hopped up's Avatar
I meant the starter brackets
Old 11-09-2012, 12:51 PM   #1171
Dano69c10
Dano69c10's Avatar
Maybe we can get a couple of us together to help out with this problem. Sometimes another brain or another pair of eyes can solve the problem. I think those of us who can make it, should bring any starters/parts and flywheels so we can do a mockup and then the right parts can be ordered. I firmly believe in Nate's mantra about doing some detective work. I'm willing to crawl under the truck and help out.
Just my $0.02
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline
Old 11-09-2012, 01:06 PM   #1172
Lee H
Lee H's Avatar
Just my $0.02
Dano
I'll help out also.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline
Old 11-09-2012, 01:13 PM   #1173
VDOG
Grand PooBaa Member
VDOG's Avatar
Of course I will help. I can bring the starter I have also.
VDOG is offline
Old 11-09-2012, 02:37 PM   #1174
hopped up
hopped up's Avatar
You guys are too cool. I know vdog would and has been helping me out . And vwnate and dano are cool guys too , but the others that i havent met i appreciate it alot.
Old 11-12-2012, 01:49 AM   #1175
ItsRandy
ItsRandy's Avatar
There are a pair of early big block motor mounts in a '71 3/4 ton at the pick a part on 6th street in San Bernardino and a hydro boost on a later model 1 ton if anybody is interested. The motor is still in the truck.
ItsRandy is offline
