Old 06-20-2018, 10:22 PM   #1151
Black_Sheep
Black_Sheep's Avatar
Re: What did you do with your truck today, Part 3
So I got my hinges in, hopefully the pilot holes I drilled after mock up will have alignment pretty close when the doors go on. I also checked the function of the door jamb switches and the door solenoid circuits, turns out the power supply to the relays is only hot with the key on. Not good. Would it be a bad idea to run the wire to one side of the "red-battery" terminal on the HL switch? The relays and an auto resetting circuit breaker are mounted inside the left door jamb. A 10ga wire feeds power to the HL switch so it should handle the current draw ok. Connecting it there would sure be convenient.
Black_Sheep is offline   Reply With Quote
Old 06-20-2018, 10:31 PM   #1152
MARTINSR
MARTINSR's Avatar
Beautiful work!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 06-20-2018, 10:35 PM   #1153
Black_Sheep
Originally Posted by MARTINSR View Post
Beautiful work!
Brian
Thanks, any thoughts on the wiring question?
Old 06-20-2018, 11:17 PM   #1154
evilokc
I worked more on the a/c bracket. I did a first mock up. the compressor and alternator are going to work great on the same side of the motor. im stoked about that. I need to get the correct length belt and do a full mock up but its going well. I need to trim the original spacer from the alternator to allow the bracket and alternator use the same mounting hole. I also need to make a spacer for the arm that goes on the manifold. I used stacked washers for the mock up but I will cut a real one. good progress today.
evilokc is offline   Reply With Quote
Old 06-21-2018, 01:00 AM   #1155
mikebte
Better than me, I gave up and switched to the painless wiring push/ pull switch. Made more since for my wiring set up. I could not for the life of me get the OEM switch to work. Here is my new switch wiring if you can make anything to work with what you have, googled this.
mikebte is offline   Reply With Quote
Old 06-21-2018, 02:03 AM   #1156
MARTINSR
MARTINSR's Avatar
I don't know but I can toss it past my brother, he is the wiring expert that I refer too.
I got the right kick panel welded in! I was going to have them both, that was the plan. But a family movie night won over that with "Cars 3" and we had fun, what a fun movie.
Brian
1948 Chevy pickup
Old 06-21-2018, 02:41 AM   #1157
MiraclePieCo
MiraclePieCo's Avatar
Painted the springs in preparation for hood installation. Discovered some automotive genius in the truck's past had welded one of the hood spring mounting holes closed - why in heck would anyone do that??? I drilled out the weld and retapped the hole.
Proceeded to fabricate a shift selector lever in anticipation of installing my floor shifter. The 1-1/2" left offset will help place the shifter in a comfortable position.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 06-21-2018, 08:39 AM   #1158
mikebte
You work pretty fast!
That is a couple of 5 minute evenings. Last night was just bolt ons. Wiring was fabricated the night before. I only wish I could wire that fast, I would be almost done..
Old 06-21-2018, 04:12 PM   #1159
wolffcub
wolffcub's Avatar
Been working away on the fitech install. Should be installed this weekend if all goes well.
52 Chev 1300,55 235 40 over, 848 head, dual Edelbrock intake, Fenton headers, CW 32/32 carbs, 251 cam, HEI, T5 Trans, 3.23 rear, 235/75/r15 rubber.
If it aint broke I still try to fix it!
wolffcub is offline   Reply With Quote
Old 06-21-2018, 05:34 PM   #1160
mikebte
So awesome, Makes me wish at times that I had kept my inline 6. Maybe in the next project.
Old 06-21-2018, 10:36 PM   #1161
evilokc
that's cool man. an injected inline 6 is awesome. did you do any kind of write up on it? I would be interested in how well it (fit) adapts to the old motor. I also wonder how it affects the drivability.
Old 06-22-2018, 12:05 AM   #1162
MARTINSR
MARTINSR's Avatar
I am putting mine back in on this rebuild (it's third since I have had it) and I can't wait!
The first photo is the one it had when I bought it with the homemade intake my brother and his friend made, and then what I going to run, a 53 Corvette Blue flame!
Brian
1948 Chevy pickup
Old 06-22-2018, 12:10 AM   #1163
MARTINSR
MARTINSR's Avatar
I finished up welding the right kick panel and then got the left one clamped in and ready to weld tomorrow. I was planning on getting them both all finished but damn I am beat tonight.
The other photo is a memorial sticker that is on the dash of a car buddy who passed away way too young back then. I am thinking it's dime I got this truck back on the road! My God, it's been sitting in pieces for 25 years! Why do we do this?
Brian
1948 Chevy pickup
Old 06-22-2018, 02:43 AM   #1164
MiraclePieCo
Mounted the shifter and connected the linkage.
So now I have throttle, brakes, steering and gears!
Old 06-22-2018, 09:53 AM   #1165
MARTINSR
MARTINSR's Avatar
WHOOO HOOOO! I love seeing that shift boot style from back in the day. I need to order that floor cover, where did you get yours and does it fit well?
Brian
1948 Chevy pickup
Old 06-22-2018, 09:59 AM   #1166
wolffcub
wolffcub's Avatar
This is the first post about it on this site, All my others have been on facebook groups for the 3100 trucks.
I should get the install done this weekend and i will post up a few more pics and info.
Old 06-22-2018, 04:02 PM   #1167
MiraclePieCo
Brian
The transmission floor cover came from Classic Parts. It fit perfectly and all the screw holes aligned without modification.
https://www.classicparts.com/1947-54...info/40%2D411/
Old 06-22-2018, 04:32 PM   #1168
MARTINSR
MARTINSR's Avatar
Thanks so much.
Brian
1948 Chevy pickup
Old 06-23-2018, 12:31 AM   #1169
evilokc
I measured and picked up the a/c compressor belt. that's one more thing checked off the list. tomorrow I will get it lined up and measure for spacers.
Old 06-23-2018, 12:43 AM   #1170
MARTINSR
MARTINSR's Avatar
Got the drivers side kick panel welded in, whoo hooo! Went out to dinner with the family and came back and made an extender for the bottom of the panel to finish it off tomorrow.
Brian
1948 Chevy pickup
Old 06-23-2018, 02:51 AM   #1171
MiraclePieCo
Since I'll be installing the hood by myself, I used scrap to make an attachment for my engine hoist to support the hood in position while I install the bolts. Am I a genius or what?
Old 06-23-2018, 11:02 AM   #1172
MARTINSR
MARTINSR's Avatar
You are genius, but you can't find someone to give you a hand? I don't have many people I could go to either, don't hang out with guys in the garage if you get my drift. But I could find someone, you can't find someone?
That being said, many years of when I had my shop I worked alone and I could do a HELL OF A LOT alone. It's so funny how guys will ask for help at work doing the most stupid basic stuff, I am amazed by it. I could get it done in the time it takes them to come ask for your help. MOST hoods (late model Japanese cars) I would put on by myself, MOST doors, by myself, I rarely had to ask.
So I guess you are one up on me.
Brian
1948 Chevy pickup
Old 06-23-2018, 03:03 PM   #1173
evilokc
Brian
what is the tank on the passenger sides function?
Old 06-23-2018, 03:07 PM   #1174
MARTINSR
MARTINSR's Avatar
That's a radiator tank.
Brian
1948 Chevy pickup
Old 06-23-2018, 03:07 PM   #1175
evilokc
I came across a GREAT deal on a parts truck. its been sitting for a long time. I bought this for $50 guys. $50! the bumper brackets are worth that. im going to use only a few parts and will then offer it to you guys super cheap. I don't have the room for a parts truck so its going to be a quick offer once I pull my parts off of it then it will go on craigs list. im stoked guys. I love a good deal.
