06-23-2020, 08:16 AM | #1176 |
Post Whore
Re: Columbus..the 1957 IH 4x4..
Thanks Robert..!
06-23-2020, 09:05 AM | #1177 |
Proprietor of Dale's Corner
Starting to look like a truck....Yea!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
06-23-2020, 09:25 AM | #1178 |
Looking really good!
Can you put a window a/c unit in? I have a large unit for a 1200sqft space I got at Lowe’s about 10 years ago and every summer I stick in in the garage window. I have a large four car garage and put a big fan in front of the a/c unit To push the cold air further inside and it takes 10 or 15 degrees off the temp. I could put another one on the other end of the garage and it would probably get cold in there! I know your shop is much larger but 96 is brutal! Just a thought...
Scott ______________ my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979 |
06-23-2020, 02:41 PM | #1179 |
Post Whore
Thanks Dale..Scott
Scott, I had a window unit I tried a couple yrs ago, and unless you stood right in front of it you couldnt tell any difference...my biggest issue is the useless insulation that I have...I think if I get that issue taken care of itll help more than anything..
06-23-2020, 02:58 PM | #1180 |
Looking better than good, looking great.
I hear you on heat and humidity. It puts a damper on me every summer.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
06-23-2020, 03:11 PM | #1181 |
Post Whore
Thanks 67C...
06-29-2020, 12:12 AM | #1182 |
Post Whore
Not really much of a update..just getting a few minutes here and there..
Installed the trans tunnel...what a job that was ..all the orig clips were screwed up, so I would up using socket head countersunk bolts with nuts and washers under the truck Not a 1 man job, but I got it done Got the heater box and control cables installed and ran the heater hoses ..I used a old air heater bypass valve. The old control valve is inside the heater box..I installed this one under the hood..so itll be easier to service if needed..I was disappointed I couldnt find one in all brass..this one is plastic..
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 06-29-2020 at 12:28 AM. |
06-29-2020, 12:15 AM | #1183 |
Post Whore
Also finally got a block of time when it wasnt 99 deg to try out the new black widow HTE paint gun..
1st impressions are this is a very nice gun..I resprayed the hood and radiator support..each coat I put down looked very slick..so it should take only minimal sanding and buffing...hopefully this time i won't burn thru the paint..
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 06-29-2020 at 12:32 AM. |
06-29-2020, 06:26 AM | #1184 |
Looking Good as always.
NHRA Super Street 469C It only runs 10.90 at 156 mph |
06-29-2020, 06:30 AM | #1185 |
Looking like progress to me. Progress always looks good.
06-29-2020, 06:32 PM | #1186 |
Post Whore
thanks Regan and Dale....
but just my luck...sometime last night between lights out and dry paint, about a half dozen bugs decided to land in my wet hood paint...1 of them was the size of a VW ...they all decided to do the backstroke in my paint..dont know if thatll sand out or not..its pretty bad... it doesnt show in the 2nd pic but one of them left a 6in trail behind him..
06-29-2020, 07:59 PM | #1187 |
WHAT THE? Dangitalltoheck! WHERE are you getting all these darn bugs?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
06-29-2020, 09:53 PM | #1188 |
Post Whore
I don't know JJ...my paintbooth is sealed up fairly well...and I think I wouldve seen that one giant bug for sure... it all looked good when I shut the lights off
06-30-2020, 08:16 AM | #1189 | |
06-30-2020, 08:22 AM | #1190 |
Darn the luck! You can't catch a break on that paint stuff.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
06-30-2020, 04:23 PM | #1191 |
Got any bad blood with your neighbor or an ex wife?
That's a heart breaker for sure.
06-30-2020, 08:28 PM | #1192 |
Post Whore
looked at it again today..havnt sanded it yet but I'm pretty sure some more layers of paint are gonna be needed...dagnabit...
06-30-2020, 09:04 PM | #1193 |
Just a little tidy bit from my signature. Some days chickens and some days feathers. I use it because it explains my life in a nutshell...lol
06-30-2020, 09:10 PM | #1194 |
Post Whore
me to Dale.....me to
07-04-2020, 02:28 AM | #1195 |
Post Whore
Well...I finally got up enough nerve/gumption/courage to try and wet sand the doodle bug leavings outta my newly painted hood...
I'm not sure how much paint I removed, but I got 90% of the 4 worst spots out..I reckon they was breaking their legs off in the paint while they was doing their thang...as I was sanding you could feel bug parts roll up under the sandpaper everytime I went across his mess...I'll have to get it out in the sun where i can see it good....I'm not sure how many paint layers I've got till i hit primer...this being the 2nd goaround for paint on the hood, I may be ok..
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 07-04-2020 at 09:11 AM. |
07-04-2020, 12:08 PM | #1196 |
I hope it works out........
07-06-2020, 08:30 AM | #1197 |
Ugh. Bugs were terrible at my place this weekend too.
Just keep going slow, you'll get them out. Also, don't forget, if there's holes, etc, from their feet, you can try to blip in a little dab of paint and wet sand that out. I found a big paint chip on my Mustang's headlight bucket this weekend, two eraser size chunks side by side missing. Not sure what hit it, I guess a rock, but there wasn't any ding damage. I'll fill them in and eventually forget about them...
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
07-06-2020, 04:44 PM | #1198 |
Post Whore
Dale, as long as I don't burn thru the paint when I buff, I think itll be ok...
Dang Jesse,, is the chip on the 65?...I know ill get chips along the way, but id like it to all look good once...
07-06-2020, 04:50 PM | #1199 |
Yea, she's gotten a bunch over the last 35-40K miles, yes, it's actually been driven that much. I just fill em in and smooth 'em out best I can.
The FIRST DAY I had it, I took Jena for a ride, it had lap belts, she opened the door and dropped the belt latch right on the top of the rocker and took a good 3/8" chunk out of the paint. Been touching it up ever since Then just last week I took a friend for a ride and he flung my 3 point belt right into the top of the painted door (inside). Just have to accept it...
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 07-06-2020 at 04:58 PM. |
07-06-2020, 05:56 PM | #1200 |
Post Whore
ouch...that's kinda the way I look at my C30...I got quoted $7k to paint just the cab...I said screw that and painted it in the driveway for under $300...I think about how much less it hurts when I hear a rock bounce of it
