Old 07-22-2023, 11:15 AM   #1176
SkinnyG
SkinnyG's Avatar
Re: SkinnyG's '61 Apache
Latest Video:
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is online now   Reply With Quote
Old 07-23-2023, 01:01 AM   #1177
SkinnyG
SkinnyG's Avatar
Trial fit to feel good.
Old 07-24-2023, 01:41 AM   #1178
SkinnyG
SkinnyG's Avatar
Finally decided on where the battery is going to go. For that, we need a mount!
First, in Fusion360:
Old 07-24-2023, 08:38 AM   #1179
joesscamaro
Cool video on the door latch mechanism...thanks for sharing.
For your battery tray, are you going to going to just mount it to a frame rail? Have you thought about one of the trays that drops down and then you can stow it back up once the battery is in it?
joesscamaro is offline   Reply With Quote
Old 07-24-2023, 08:46 PM   #1180
SkinnyG
SkinnyG's Avatar
This will be mounted to the frame rail. My intention with it is simply unbolt the whole bracket, drop it, and remove the battery.
Now cut it out of steel:
Old 07-25-2023, 09:07 AM   #1181
SCOTI
SCOTI's Avatar
My duallys setup is similar in intent but different in execution.
I bolted in two vertical uprights to have 'guides' for the batt box/tray to attach to.
The vertical uprights of the batt box/tray have 3/8" square nuts welded on the inside & the uprights bolted to the frame have slightly oversize 1/2" holes drilled in them.
You can muscle the batt (bolted into the box/tray) up into place by hand, but I found the AGM 34/78 batt was a wee bit heavier vs the standard lead/acid type I used for testing/validation.
I just put a fresh batt in & did the install w/a floor jack. Batt/box/tray slides up between the two frame guides. Adjust the height until I can get the 4x 3/8" bolts in place through the uprights into the box/tray. Tighten the hardware.
Your set-up is def more appealing to the eye vs. mine that's for sure. Having stuff laser or waterjet cut sure makes a difference.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-25-2023, 11:07 AM   #1182
SkinnyG
SkinnyG's Avatar
I actually recently ran across a thread where you shared the battery mount in your squarebody!
Old 07-25-2023, 12:06 PM   #1183
SCOTI
SCOTI's Avatar
I was going to mount it like your plan. I drilled the holes in the frame but found it cumbersome to get the bracket aligned w/the battery in place. So... Plan-B was mounting the 'guides' (1.5" x 3/16 angle) to the frame & running the box/tray bolts through the extended material on them. That made things much easier for me during install/removal validations.
Those AMG batteries feel a lot heavier (~10# ?) vs the lead/acid one I used initially for testing things.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-26-2023, 12:39 AM   #1184
SkinnyG
SkinnyG's Avatar
I am confident enough that I have the in-cab wiring done, that I wrapped the wiring.
A while back I bought one of these trinkets - freaking awesome for troubleshooting, but ALSO for initial testing of circuits:
My truck came with a later 2-speed wiper/washer switch in the glovebox. I still have the 1-speed motor, but chucked the single-speed knob in the lathe and drilled a 3/16" hole through the center, and I machined a wee 3/16" "button" with a 1/4" shoulder, back drilled to fit the switch pin. Now I have a washer button!
The wipers do work - do they always operate a little "disconnected" from each other? I mean, they do their thing, I was just hoping for more symmetry.
I installed pin-switches for the courtesy lights (and alarm). That was tricky fishing the wire out through the hole. Works, anyway.
Also added a toggle switch for the air ride compressors. I mounted the switch inside the "ashtray" which I altered to house the air ride pressure gauges.
Ran alternator power and fuse panel power lines. Also bought a wack of 1ga wire to go to the battery, now that I've decided where to mount it.
Now I need it back in the air to run the wires underneath.
So much work; so much to do.
Old 07-26-2023, 02:33 AM   #1185
Braunschweiger
They are doing a fantastic job,
I can't wait to see the truck running.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 07-27-2023, 10:44 PM   #1186
SkinnyG
SkinnyG's Avatar
I meant to powdercoat this, but had extra primer in the gun already:
Old 07-29-2023, 12:59 AM   #1187
SkinnyG
SkinnyG's Avatar
The truck came with a later windshield washer equipped wiper switch in the glopvebox. Good luck finding the 60-63 knob with a button. So I made one out of the existing knob:
Old 07-29-2023, 01:57 AM   #1188
Braunschweiger
Thanks for showing me,
I was already wondering how my wiper system is supposed to work, I'll probably take over your patent. Thanks for that.
Greetings Harald
My 62 build thread
Old 07-29-2023, 02:13 AM   #1189
SkinnyG
SkinnyG's Avatar
Shoulder is 1/4" OD, pin (button) is 3/16" OD. Drilled in the back one size bigger than 1/16" to slip over the pin. No real measurements, cut to fit.
I still have the one-speed motor, but one of the pins is "hot" in both speed positions, so that one goes to the motor. The switch has two positions, but the speeds are the same between the two.
Old 07-29-2023, 10:38 PM   #1190
SkinnyG
SkinnyG's Avatar
Taillights are wired, as is a trailer light plug.
Battery mount is set in place near the back of the frame under the bed. Positive cable is done. Need more #2 wire for a decent ground.
Air ride compressors are now hooked up, run through a relay and a pressure switch. Looks like the pressure switch is 200PSI. That should be fun.
Stereo amp wiring is run up to the cab.
Old 08-01-2023, 10:48 PM   #1191
SkinnyG
SkinnyG's Avatar
Air lines, and stereo amp wire plumbed into cab. Need more DOT hose to plumb the air ride gauges.
Old 08-03-2023, 12:43 AM   #1192
SkinnyG
SkinnyG's Avatar
Air ride works. Two Viair 400's drain the battery fast. One air leak that I'll need to fix.
I ran -8 from the tank through a bulkhead fitting into the cab, into a log that splits into four 1/4" lines to manual valves, T'd to a gauge and run to each bag. It actually lifts quite satisfactorily. At 200psi in the tank.
Old 08-03-2023, 09:04 AM   #1193
joesscamaro
If you have a chance, I'd love to see that bulkhead/log fitting that you mentioned running into your cab with. That took a bit of mapping out on my truck as I ran each individual line inside my cab and trying to make sure the air lines were tucked out of the way from heat sources. Turned out fine but running one in to that splitter sounds like a good option.
Old 08-03-2023, 09:58 AM   #1194
SCOTI
SCOTI's Avatar
I need higher psi switches on my dually. The 120# limit is barely adequate for that heavy front end. It's on the current 'list-o-things'....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-04-2023, 01:56 AM   #1195
SkinnyG
SkinnyG's Avatar
Manual paddle valves for reliability and simplicity. Modified an -8AN bulkhead fitting to be a bit shallower. The gray is etching primer over the drilled holes. You are asking about the 4-into-1 manifold.
Old 08-05-2023, 12:41 PM   #1196
SkinnyG
SkinnyG's Avatar
Old 08-05-2023, 12:41 PM   #1197
SkinnyG
SkinnyG's Avatar
Old 08-06-2023, 01:57 AM   #1198
SkinnyG
SkinnyG's Avatar
Windshield squirter didn't squirt.
Had to fabricate a new button - the button wasn't able to push far enough.
Here is what worked:
3/4" long
1/4"OD shoulder 1/16" thick, drilled 1/8"DIA only 1/8" deep
3/16" shaft for the remainder, rounded tip.
Drill the non-squirting knob 3/16" right through the center. And, like, use a lathe for this.
Old 08-07-2023, 09:16 PM   #1199
SkinnyG
SkinnyG's Avatar
Wiring is done.
Stereo is in and working
Cooling system holds water.
I've been over-thinking the engine oil cooler for three years. Today I bent up two little mounting brackets, and once they come out of the powder coating, the cooler will be ready to hang.
I -think- all I need to do is throw in a new battery, pressure test the fuel system, pressurize the oil system, and it should run.
I'm scared spitless.
Old 08-07-2023, 09:25 PM   #1200
caseyjones
It’s gonna be so awesome!
caseyjones is offline   Reply With Quote
