11-12-2019, 09:11 AM | #1201 |
Re: "Project Orangepeel" 52 A.D
Thank You!
mark
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
11-12-2019, 04:00 PM | #1202 |
I wandered over here from the SquareBody section and got caught up in your build. All 40 pages of it. Tons of creativity and high-quality execution here. Thanks for taking the time to let us in on it.
11-12-2019, 08:20 PM | #1203 |
Thank You Very much!! Very kind of you.
Mark
11-18-2019, 10:32 PM | #1204 |
This is a quick shot of the design of the panel.
It will be 2 pieces when all done. Erin Ruddy from Ruddymade Interiors will be helping me with the design of the actual panel. I'll get more posted later. Mark
11-19-2019, 09:17 PM | #1205 |
wow!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
11-19-2019, 10:42 PM | #1206 |
Thanks Russ!
I'll be getting the panels finished up this week I think, so I'll have a bunch of pics to show how it's all made. Stay tuned.... Mark
11-21-2019, 10:51 PM | #1207 |
pic 1. Here is the panel that (Erin) made for me.
It's made from 1/4" acrylic and the plastic sheets I bought earlier. After he made the basic shape it was glued together and body filler to smooth out and blend. Pic 2. Here it's a bit clearer on how the panel is layered. The section that has the voids or circles are for the 1/4" magnets. I will glue in magnets to both the insert and main panels. Pic 3. Here I'm showing how I used pan head bolts to mount the panel to the door. Pic 4. Then I sanded the panel to prep it for filler. Pic 5. After taping the insert panel to protect it from filler I used Upol fibral To make the first layer to mold the 2 panels together. More to come. Mark
11-22-2019, 09:32 AM | #1208 |
You do nice work!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
11-22-2019, 07:03 PM | #1209 |
Thanks Robert!
Abig help with the main design and making of the insert panel was made by Erin (Ruddymade interiors) Mark
11-22-2019, 11:04 PM | #1210 |
Pic 1. So since we had a spare set of doors laying around I took advantage of this and brought them home to my shop so I could do all the filler work off the truck.
Pic 2. In this shot you can see the insert is able to pop out of the area where the filler was added. This insert gets bolted in place when assembled. Pic 3. The insert back in place and I also added a 1/4" round bar at the lower section and this will be permanent. It will add a bit more detail.and depth to the panel. Till next time.... Mark
11-24-2019, 01:19 PM | #1211 |
Pic 1. After I put the rod on with epoxy I then started to blend it with fibral.
Pic 2. Then moved on to the filler to blend it in further to the insert panel This will make it flow a bit better. Pic 3. In this shot it shows the bar really good, thus will add another level of detail to the panel. Mark
11-25-2019, 07:22 PM | #1212 |
pic 1. Here the panel has been sprayed with high build primer. That way I can block them out real nice.
Pic 2. After sanding the panel and the insert to see how it looks . Pic 3. I put the panel back on the door to check final fitment And also to see how the lower accent panel would look. Mark
11-25-2019, 08:20 PM | #1213 |
Wow!
11-25-2019, 10:10 PM | #1214 |
good googly moogly its a master class
11-25-2019, 10:33 PM | #1215 |
Thanks Robert and Russ.
Don't know if it's a master class, just doing my best to make it look nice. Thank you for the compliments Mark
11-25-2019, 10:33 PM | #1216 |
Post Whore
Nice Mark...real nice...
11-26-2019, 08:49 AM | #1217 |
Thanks Greg
Mark
11-28-2019, 12:35 AM | #1218 |
pic 1. So finally it was time to wrap these in some vinyl.
Me and Dad went over to Erin's and he was going to give us a lesson on how he does things. Pic 2. Here Erin is covering the first panel. Starting from the center and moving out. Pic 3. The panel all covered. Now the insert needs to be covered. Pic 4. The insert was then reduced to have material put on it and to be able to fit into the panel snugly.
11-28-2019, 09:43 PM | #1219 |
Looks clean and simple. A lot of the aftermarket panels out there look too bulky. well done.
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90 http://67-72chevytrucks.com/vboard/s...d.php?t=746958 |
11-28-2019, 10:40 PM | #1220 |
Thanks Kevin!
Mark
11-28-2019, 10:48 PM | #1221 |
Pic 1. Here he is covering the insert panel.
Pic 2. The final product. Super Happy with the panel and design, really clean. Pic 3. This is a closer look at the material used on the insert. It is NOS (new old stock) 48 Buick fabric, this will in turn tie in with the Buick headlight bezels. Mark.
11-28-2019, 11:53 PM | #1222 |
Post Whore
looks great Mark
11-29-2019, 12:13 AM | #1223 |
gorgeous work, really clean idea!
11-29-2019, 09:01 AM | #1224 |
Thanks Greg
Thanks Russ Mark
11-29-2019, 10:20 AM | #1225 |
Those door panels cam together awesome!
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
