Old 08-21-2016, 09:31 PM   #101
85raiderburban
85raiderburban's Avatar
Re: The first ever 73-91 Burb post your ride thread!
cleaned up the new tires I bought for her, the others were dry rotted. The red LED digital gauge is for trans temp (700r4 swap). I replaced that one with a needle one now. The other is a tach. LED lighting for the cluster also.
*UNDER CONSTRUCTION*
'80 Suburban C20 (C6P) (Silverado)
- '68 472 (Edelbrock 1813, PH8026 LT's, H pipe) / '91 4L80 (manual shift,vac modulator, 350 converter) / 14B FF 3.21 G80 34' s/ '96 GMT400 interior
85raiderburban is offline   Reply With Quote
Old 08-21-2016, 09:51 PM   #102
85raiderburban
Swapped out the Edelbrock 1406. It wasn't supplying enough air/fuel for the 454. '86 non cc Quadrajet off of an RV 7.4 is now in it's place with an adapter plate to the (Edelbrock c454) intake. The power steering filler neck is from a newer Trailblazer. Throttle/TV cable set up with $8 bracket. Factory carbed air cleaner from another parted truck with hose to the front grill for forced air induction. It fits under the hood with about half an inch clearance
Old 03-26-2017, 04:15 PM   #103
basher13
Cool Re: The first ever 73-91 Burb post your ride thread!
New to me, had to make sure the 4wd worked!
basher13 is offline   Reply With Quote
Old 03-27-2017, 01:20 PM   #104
basher13
Back in November exploring the other side of the state.
Old 04-07-2017, 09:33 AM   #105
Nodnarb76
Nodnarb76's Avatar
very cool!
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 04-09-2017, 01:50 PM   #106
basher13
What's the WARN motto? Go Prepared! Well I didn't...putting together my recovery kit today. Good times!
Old 04-09-2017, 02:31 PM   #107
Country Suburban 4x4
Country Suburban 4x4's Avatar
My 1983 GMC K2500 Suburban. 29,000 original miles currently, 350 bored 30 over, edelbrock aluminum heads and intake, comp cam roller rockers, headers, mild cam. TH400 tranny, GM 14 bolt rear, Dana 44 front, 4.10 gears with an NP208 transfer case. When I get done with college next year, I will be pulling the engine and most likely building a 383 stroker, but I've got some time to plan. I've had this truck since I got my learner's permit at 15 years old and it has been a blast building it with my father, lots of great memories. The old burban goes by "Clifford".
The day I became the 2nd owner:
Here she is now:
'83 GMC K2500 Suburban 4x4
2000 Chevrolet Silverado 1500 Z71 4x4
God Bless America!!!!
Country Suburban 4x4 is offline   Reply With Quote
