Old 11-20-2007, 11:36 AM   #101
cayoterun
Junior Member
cayoterun's Avatar
Re: GMC V-12 powered '91 Chev crewcab
Got some questions:
#1: What's the highest ratio rear end gears available for Chevy 1 tons? I'd like to get up as high as 3 if possible.
#2: Would the '78? cab/chassis complete rear end be a direct swap out to the '91 dually FRAME? or is the frame widths different?
With a 2400rpm max on the v-12, I hope to use a 5spd overdrive tranny and increase the rearend ratio enough to get 80mph @2400.
I have a 3spd over auxillary tranny available, but would like to stay away from the extra driveshafts, length in the drive line, and keep the whole drive line as simple as possible.
It's for sure I have no worries about torque or power to pull high ratios, but need gears stout enough to stand a 20,000#max cgvw occasionally, so trying to stay with all 1 ton components.
Maybe, just maybe, this week we can fire the old motor, and then start the search for clutch/driveline. I want to have all that matched up and assembled in the shop floor before attempting to sit the package in a frame. I'm guessing all combined is going to weigh 2,000# or more.
Couldn't resist: My son noticed yesterday my dog (Scooter) would match my truck.
I guaroontee the pic hasn't been messed with, he's half Beagle and half mini-weenie. He had an encounter with a rattlesnake awhile back, (Rattlesnake won) but is ok now.
Enough trivia for today
Thanks,
Cayoterun
Cayoterun
Okla. Panhandle
I think I'll do it myself and pay the extra $500.
cayoterun is offline   Reply With Quote
Old 11-20-2007, 06:57 PM   #102
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
3.21's are as low numerically you can get for the 14 bolt. I put 3.21's in my 88. The spring pads are alot further apart on my '88 than on a 73-87 one ton. 73-87 3/4 tons have spring pads further apart than the same years of one tons, but still nowhere near the 88-up. Shock mounts are different on 88-up also.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 11-20-2007, 07:57 PM   #103
cayoterun
Junior Member
cayoterun's Avatar
Good News: I checked the gear calculator and a 5spd over/w 3.21 gears gives 81mph @ 2400 & 64mph@1900rpm. That gives inter-state speeds, so that's plenty for me.
I think I want the narrow frame for this as it would give more options of bed type we use. Bed would go on frame last.
We may be stretching the '78? flatbed frame instead of the '91.
I suppose you saw all the scenic wonders of western Ks. by now?
Thanks,
Cayoterun
Cayoterun
Okla. Panhandle
Old 11-20-2007, 08:56 PM   #104
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
It's like a big desert compared to around here. I don't think I seen any groundwater until at least 100 miles east of Garden City. Dry river beds, no ponds... yet a local says they have large deer around there. I don't see how, when there is no water, or trees for cover. I never thought there were many trees here, but I think there are more trees within a 5 mile radius of my house than a 100 mile radius of that town. The things that really stuck out were LPG powered big blocks for well pumps instead of diesel, and a liquor store on every block
I found it odd when I moved here, only 140 miles from my hometown. A spring in my yard that runs 365 days a year, and crawdads that come up thru holes in my yard. I find it fascinating how much things change with such little distance.
Old 11-20-2007, 09:23 PM   #105
cayoterun
Junior Member
cayoterun's Avatar
My son-in-law got his deer last night here on the place. It was a white-tail and weighed 140#, field dressed. He was kinda
disappointed, as he has killed as big as 180# field dressed. Some bigger have been killed.
Mule deer are some bigger than that.
How does that compare to east of here?
Cayoterun
Cayoterun
Okla. Panhandle
Old 11-20-2007, 09:37 PM   #106
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Dunno, I'm not a deerhunter- unless you count the one I almost got with my pickup last week. It was funny- a small buck come up out of the RH ditch, just missed the bedside of my truck as I went by, and jumped up & cleared my empty car trailer just catching its hoofs on the LH trailer fender. It did 1/2 a barrel roll, landed on its side on the highway & jumped up & took off. They are thick around here. Can't make a trip to town without seeing a dead one on the highway.
Old 11-22-2007, 08:17 AM   #107
Storm Chaser
Storm Chaser's Avatar
Have you thought about maybe using a crew cab frame, and just sitting the cab back towards the bed? Just an idea that struck me...
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 11-22-2007, 09:29 AM   #108
cayoterun
Junior Member
cayoterun's Avatar
Are you thinking of doing that with the crewcab cab? If so, what would it look like.
The main things that's pulled me toward the '62 GMC are sentiment, (first owner good friend), current title and tags, and year model is close to when motor was new ('64).
I measured the frame and wheel widths on the '79 yellow/black flatbed and the wheels and frame are about 9" narrower than a dually. I'm thinking now, I'd like the narrow set-up better.
I'm bouncing around like a ping-pong ball on what to mount the motor/tranny in, so all suggestions are appreciated.
I'm just now ready to start trying to find clutch/tranny/gear ratios that will match inter-state speeds and fit on the motor, which looks like it's not going to be easy. I'm learning these motors are pretty well a breed all their own.
If someone out there has some 3.21 (or close) gears they'd sell for a 14bolt chevy rear end, I'd sure be interested.
Thanks,
Cayoterun
Cayoterun
Okla. Panhandle
Old 11-23-2007, 04:30 AM   #109
cayoterun
Junior Member
cayoterun's Avatar
702 V-12 for sale on the 6066GMCguy site from a truck. Site message# 33586. Lots of pics
Cayoterun
Cayoterun
Okla. Panhandle
Old 11-23-2007, 11:40 AM   #110
Storm Chaser
No, I'm not thinking of doing it with the crew, I just thought if you could score a crewcab frame somewhere, it might save you some framework due to the extra length.
If you were to find, say, a 73-87 crew frame, you could mount your bed where it goes on the frame, then add your cab where it goes in relation to the bed, and then you'd have a whole lotta frame left forward of the firewall to get your engine mounted. The hard part would be stretching the fenders and hood. The frame would be uncut, really, so there wouldn't be the headaches of making sure everything is OK for it to go down the road straight. Just thought it might save you some time, money and headache.
1988 R2500 Crew Cab
Future plans-
Old 11-23-2007, 01:40 PM   #111
cayoterun
Junior Member
cayoterun's Avatar
I gotcha'-- Measure and work from back to front. Then since the hood and clip has to be stretched, fill in the remaining space. Right?
I assume from your last post, they made crewcabs back as far as '73. I don't remember. That's where you guys help get my head outside-the-box. We don't have hardly any salvage yards here, so I'm limited to farmers pastures mostly.
The whole neighborhood is getting caught up in this old motor, but since they hav'nt been used for 20+ yrs, we've all forgotten how to work on them, mainly the timing, even with service manuals, it's still tricky.
Back then, they could jerk a distributor, fix it, have it back running in an hr, holding a flashlight in their mouths at 3:00 in the morning. We are getting good laughs at how old we're getting.
Thanks for a new look at this,
also thanks to all of you guys for having patience with this old guy that's had a stroke, left with limited vision, forgetful, crippled up, but thankful for the can dos, not the can't dos. Life is good.
Cayoterun
Cayoterun
Okla. Panhandle
Old 11-26-2007, 02:13 PM   #112
cayoterun
Junior Member
cayoterun's Avatar
THE DRAGON BREATHS FIRE AND THUNDER ONCE MORE!!! YEEEHAAA
Didn't let it run more than 2-3 seconds. no water & want to try to get video as it burns all the oil, mud dobbers, and dead mice out I missed.
Cayoterun
Maybe short video Sunday if Son is off work.
I had to tell somebody,---- my wife didn't seem too impressed.
Cayoterun
Okla. Panhandle
Old 11-26-2007, 03:04 PM   #113
spudz
spudz's Avatar
Hot Damn!
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 11-26-2007, 06:41 PM   #114
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
Congrats!! I have a suggestion for a name for it. Balaur. It's a multi-headed dragon of mythical lore. Thought it was fitting.
Darrin
1955 Willys CJ-5 all original and the oldest CJ-5 on the road.
2001 Dodge Neon (wife's car)
1995 Jeep Grand Cherokee Limited Edition SOLD
1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD
1993 S-10 4X4 Tahoe SOLD
Sign up with the Contact List
RIP ESLL
Mickey_D is offline   Reply With Quote
Old 11-27-2007, 09:21 AM   #115
Storm Chaser
Way to go!
As I read your post, I pictured that mad scientist running around his lab yelling "IT'S ALIVE! IT'S ALIVE!"
We definately wanna see a video clip!
1988 R2500 Crew Cab
Future plans-
Old 11-27-2007, 09:53 AM   #116
cayoterun
Junior Member
cayoterun's Avatar
Mickey D, I hope Balaur ain't some dirty word in some strange language, cause it might show up in some pics!
I admit it was a good feeling, brought back lots of memories from the past almost 43 yrs since I heard her fire the first time. Lots of changes and water under the bridge since then. I lived and worked for the first owner as a kid, treated me like a son, taught me much, even offered to help me thru college--they're gone now. Lots of great people pass thru our lives. 'nuff of that.
Cayoterun
Cayoterun
Okla. Panhandle
Old 11-27-2007, 10:07 AM   #117
watahyahknow
watahyahknow's Avatar
better go like a mad sientist saying its alive its alive then runnin around like dexter screaming my hair is on fire my hair is on fire
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 11-27-2007, 11:28 AM   #118
cayoterun
Junior Member
cayoterun's Avatar
No hair problem---Ain't got none
Cayoterun
Cayoterun
Okla. Panhandle
Old 11-27-2007, 03:03 PM   #119
neev_nav
Flying Dutchman
neev_nav's Avatar
That's awesome! Can't wait to see/hear it run.
94 Chevy Ext. Cab 4x4 350 (My baby)
"Women carpool. Men convoy."
neev_nav is offline   Reply With Quote
Old 11-27-2007, 04:12 PM   #120
cayoterun
Junior Member
cayoterun's Avatar
BALAUR, attempted flight, low batteries, cold weather. Practicing posting videos. Failed for today. Tried 27 ways that didn't work. These motors were notorious for being hard starting.
It's name for today was-- Oh baloney.
When I scatched her name with soapstone on the surge tank, wiped the dust off, and it had anti-freeze checked 10-31-85 with tire chalk, so we know she was in service then. 21yrs not bad.
Cayoterun
http://www.youtube.com/haystack155
Cayoterun
Okla. Panhandle
Old 11-27-2007, 07:13 PM   #121
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
Nope, not a dirty word as far as I know. Just the name of an old Romanian legend.
http://en.wikipedia.org/wiki/Balaur
I so wanted to hear that start in the video!!
Darrin
RIP ESLL
Old 11-27-2007, 08:51 PM   #122
cayoterun
Junior Member
cayoterun's Avatar
It says they could have up to twelve heads. I hope she isn't too evil.
I wonder if those 12 heads could be represented with 12 exhaust pipes sticking straight up.
Thanks for the name.
Cayoterun
Cayoterun
Okla. Panhandle
Old 11-27-2007, 09:06 PM   #123
Lated
Lated's Avatar
Ever thought of running it on propane? Theres a set of propane carbs on ebay http://cgi.ebay.com/ebaymotors/GMC-V...spagenameZWD1V
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown
'70 SWB Step-Side (More rust than metal)
Lated is offline   Reply With Quote
Old 11-27-2007, 09:50 PM   #124
cayoterun
Junior Member
cayoterun's Avatar
Those are natural gas/propane carbs on it now. I put new propane diaphragms/venturas in. It had burned natural gas all it's working life. When we get a side view, you'll see the propane regulator hanging on the right side of the motor with the propane line going forward and out the shop door. We're just using a propane bottle outside for safetys sake. The fuel supply line carries tank pressure up to the regulator. Pressures up to 250# in summer. It's steel braided line.
It hasn't burned any gasoline in it's life.
I've always liked propane as fuel, but I grew up around it, too. Plan to use it if we ever get it in a truck.
Thanks,
Cayoterun
I looked at your e-bay ad, and I've never seen a set-up configured like that. That sure don't mean there's not alot around. All that was used here will look like the ones on my motor.
I have another V-12 in the shop for parts that has an after market adapter that uses one 4-barrel gas carb. Only one of those I've ever seen. This doesn't have a carb on it, just adapter.
Cayoterun
Okla. Panhandle
Old 11-28-2007, 04:36 PM   #125
cayoterun
Junior Member
cayoterun's Avatar
Well, now I know how the dog feels that caught the car.----What are we gonna' do with it?
The vapor coming out the radiator outlet is not a sign the motor is hot. Probably just gunk getting hot next to cylinders in water jacket.
I was able to hold my hand on the exhaust manifold when we shut it off.
Sounded good, had 40# oil pressure and was burning propane.
I think the name just fits.
Next is rig up a temporary radiator, lots of tinkering and matching a clutch/tranny.
Thanks, everyone,
Cayoterun
Cayoterun
Okla. Panhandle
