Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 05-11-2009, 08:13 PM   #101
IAFF2407
IAFF2407's Avatar
Re: Overhaulin' - Seattle style
I'll have some pics up later for the 3rd row seats floor, haven't taken any yet. I bought the floor from the wreckers for $200 (brackets included) also included them cutting the floor out. They wouldn't let me do it for safety reasons. the rear upper shock mounts are part of the floor. it was kind messy so I use a cut off wheel to clean it up and cut to size. If you use a plasma cutter and make it as straight as possible it will make easier for later welding. I then bought some angle iron and welded that square, placed the floor piece in, welded that to the frame as clean as possible. I bolted the complete pan to the existing rear seatseat belt mounts (when tightening the bolts down you will pull the pan down off the your new frame if it isn't welded solid, use spacers where needed). for the front bolts that need to be mounted through the wood deck, I used a 6 X 6 1/4 plate underneath. most important is where you chose to place the seat if you use the exixting seat mount bolts, you don't want the lining up with you striker brackets where the suitcase seats lock in.
All in all, much quicker then trying to custom flush mounting the brackets and the pan with the wood floor. It will all be covered by carpet
Al.
1972 GMC Sierra
1972 GMC Super Custom Suburban
IAFF2407 is offline   Reply With Quote
Old 05-11-2009, 08:24 PM   #102
IAFF2407
IAFF2407's Avatar
forgot to mention, you will need to cut off some of the bottom side of the double wall floor pan for it to sit level.
1972 GMC Sierra
Old 01-15-2015, 01:50 PM   #103
madmaxburban
Originally Posted by IAFF2407 View Post
more pics,
Livrat showed me how to take off the front clip in one piece, in under an hour. this alone was worth it.
Would love to know how u got that front clip off
madmaxburban is offline   Reply With Quote
Old 01-26-2015, 01:52 PM   #104
65 C20
Check post 22 in this thread.
65 C20 is offline   Reply With Quote
