Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-19-2009, 06:01 PM   #101
Super73
Super73's Avatar
Re: Engine Analyzer and Drag Analyzer.. Willing to put your info in.
Softballnrd,
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 01-19-2009, 08:25 PM   #102
70c10
67-72 Addict!
70c10's Avatar
Shaun, thanks alot for taking the time to run this for me! I have three questions about the program:
1. Can you tell me why it says in the notes- Spark Knock? I've never experienced that and I run 42 total degrees.
2. Says my A/F mixture is very poor?
3. Am I reading the graph correct in that my optimal 1-2 shift is at 6000 and my 2-3 is at 5900?
Thanks again!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-19-2009, 10:25 PM   #103
ProStreet71
Hello Super73, here are my engine specs....
Bore= 4.155
Stroke= 3.75
race tolerances
Mechanical water pump
Mechanical fan
Head data:
Motown 220 Iron
2.08 1.60 valves
11.4 compression
Flow
Int. Exh.
.050 31 23
.100 60 50
.200 123 109
.300 177 142
.400 222 185
.500 243 187
.600 260 195
Carb= 850 Quick Fuel annular boosters, mech sec.
Headers= Hedman elite 1 3/4, 3 in collector, length best guess 30 in
Cam= Comp extreme energy XR292r solid roller
@ .050 254.in 260.ex
lift .582in .588ex with 1.5 rockers
intake centerline 106
LSA 110
Rockers 1.65in 1.5ex
Vehicle data
1971 swb tubbed
weight= 3900
F/R bias= do not know
trans= TH350 with TCI super streetfighter 3500
gear= 4.56
Diff= factory posi
tire size= Hoosier drag slick 31x14x15 O.D. 31.2 tread width 14
If its not too much trouble could you see what it would do with the AFR 210 Eliminators? Here is the flow numbers.
.200 139 110
.300 199 158
.400 249 192
.500 279 210
.550 289 214
.600 295 220
.650 299 222
.700 301 224
ProStreet71 is offline   Reply With Quote
Old 01-19-2009, 11:56 PM   #104
Super73
Super73's Avatar
Thanks again!
1) What fuel do you run? I have it running 91 octane.
2) Not too sure..
3) I need to go back on everyones ET's as I forgot to let it tell me optimized shift RPM for 1-2 and 2-3.. I'll try and knock that out tonight after dinner as it won't take long having all of your guys data saved.
Old 01-20-2009, 02:02 AM   #105
Super73
Super73's Avatar
Ok.. Everyones shift points are more or less optimized now and the ET's you see should be a good baseline..
Old 01-20-2009, 02:22 AM   #106
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Do mine do mine do mine!!
Engine info
http://www.gmperformanceparts.com/En...9712&engCat=sb
ZZ4
4.00 Bore
3.48 Stroke
Factory tolerances
Reverse rotation stock serpentine water pump
Dual LS1 fans
Head data:
1.94 intake / 1.50 exhaust
Cylinder head part number: 12256463 - L98 Corvette head
Cylinder head type: aluminum : 58cc chambers
Compression: 10:1
Dual plane: RPM air gap intake
Edelbrock 1406 mechanical secondaries (1407 avaliable too)
Header Data:
¾ length Chevelle 2.5 tube
¾ length header
X-pipe, dual Magnaflow exhaust, not cats
Cam info: Duration at .050": 208 degree intake / 221 degree exhaust
Total Lift and based on what rocker ratio: 1.5 ratio
Intake centerline: 208 degree intake / 221 degree exhaust
.474 intake / .510 exhaust
What rocker are you using? Stock ZZ4 rocker
Blower/turbo?
Dual snorkel 4” ram air box
Vehicle Data:
Total weight: 4200
Front/Rear weight bias : C10 – 83
What trans you are running: 700R4
Size converter (STR if you have it): 2500
Gear ratio:3.08 ratio
Differential: open
Tire size: 255/60R15
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 01-20-2009, 08:38 AM   #107
softballnrd27
Always a work in progress
softballnrd27's Avatar
Sweet! Thanks alot for the numbers. I can't wait to get my motor done.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 01-20-2009, 11:36 AM   #108
70c10
67-72 Addict!
70c10's Avatar
2) Not too sure..
Thanks again for running my numbers
Jim
Old 01-20-2009, 04:38 PM   #109
Super73
Super73's Avatar
All of you are welcome.. I will try and get the others done in the next couple of days...
Old 01-21-2009, 01:40 AM   #110
'72 Shorty
I finally got an avatar
'72 Shorty's Avatar
Thumbs up Re: Engine Analyzer and Drag Analyzer.. Willing to put your info in.
Hey super73, here's another one for ya when you get time.
Engine info
Bore 4.030
Stroke 3.48
tolerances: more race.
Electric Water pump? mech water pump
Electric Fan? Yes
Head data:
*----* Intake and Exhaust Valve size 2.055/1.60
*----* Head flow numbers
I E
.200 127 114
.300 178 145
.400 216 164
.500 249 172
.600 268 174
at 28" H2O
Compression ratio 10.7:1
Type of intake Single plane Edelbrock victor
Carb or TB Demon 750 Mech
Header Data:
*----* Tube Diameter 1 5/8
*----* Tube length to collector 30"
Cam info:
http://www.compcams.com/Cam_Specs/Ca...?csid=236&sb=0
Duration at .050" 250/260
Total Lift and based on what rocker ratio 532/555 1.5
Intake centerline 106
LSA 106
What rocker are you using? 1.5 roller
Blower/turbo? no
Vehicle Data (I am going to try to keep this simple and use my aero for the most part).
Total weight 3680
Front/Rear weight bias ~~60/40
What trans you are running Th350
Size converter (STR if you have it) 10"
Gear ratio 3.73
Differential Eaton Posi
Tire size http://www.mickeythompsontires.com/s...ETStreetRadial
295/65R15 Mickey ET Street radial
Are you running N20? no
-72 C-10 short step (straight line only)
12.922/102.28
-69 C-20 on Propane (DD)
-69 C-10
-56 Mack B-753LS (tow rig)
-94 Chev K2500 Short Ex-Cab
-89 Isuzu Trooper...Kinda
-03 Kawasaki KFX-400
-05 Suzuki DRZ-400S
'72 Shorty is offline   Reply With Quote
Old 01-21-2009, 01:19 PM   #111
Super73
Super73's Avatar
Need to know stall speed.
Old 01-21-2009, 05:43 PM   #112
Sinister-65
Sinister-65's Avatar
Thanks super73
Its easier to beg for forgiveness than ask permission.
Sinister-65 is offline   Reply With Quote
Old 01-22-2009, 12:57 AM   #113
dave38
Dave38
Thanks Super 73, just have a question I noticed 70c10s times were a lot faster than mine. Do you think I could get faster times out of my truck if I went to a smaller cam and made more torque?
How about the xr288hr
http://www.compcams.com/Cam_Specs/Ca...?csid=189&sb=2
or maybe even smaller?
Thanks again
dave38 is offline   Reply With Quote
Old 01-22-2009, 02:29 PM   #114
Garagedude
Garagedude's Avatar
Hey Super 73 can you run my motor please.
Engine info
Bore .040
Stroke - 3.48"
Factory tolerances or set up more as a race motor? Factory
Electric Water pump? Mechanical water pump high performance though
Electric Fan? 16 electric cooling fan with an aluminum radiator
Head data:
*----* Intake and Exhaust Valve Size – Unsure of the size they are stock heads the number is 333882
*----* Head flow numbers –
Head numbers are 333882
Intake flow 137.3 CFM
Exhaust Flow 95.4 CFM
Type of intake- Holley dominator intake with a two inch carb spacer
Carb or TB – Holley 650 single pumper vacuum
Header Data:
*----* Tube Diameter 1 ½” summit headers
*----* Tube length to collector (this can be your best guess, but the more accurate, the better)
Propably around 16-20” they are 3 inch collectors.
Cam info:
Link to MFG's web page or cam card would be best but..
Duration at .050" INT - 224 EXH – 231 LOBE SEP 110.0 Gross valve lift - INT - .477 EXH - .480
Lobe lift @ .050 Intake .3180 Exhaust .3200
Intake centerline – 106.0
LSA
Blower/turbo?
I need to know size and PSI you are running.
Intercooler? Air to Air or Air to water?
Total weight The title says 3500 pounds but I think it is more than that maybe 3700
Front/Rear weight bias Not positive the back is a lot lighter than the front the back bed is all cut out but the fuel cell tubs and battery are back there
What trans you are running TH400 Stock
Size converter (STR if you have it) Stock convertor
Gear ratio 3:73
Differential Eaton Posi, Richmond gears, Wildwood Disk Brakes, and a bearing cap support pan
Tire size Hooser 31x18.5 on a 15” rim
Are you running N20? If so, how many stages and how big are they?
MSD distributor
Accel 8.8 wires
Electric fuel pump with 6 an fuel line to carb
Blower style pulley system to reduce belt slip
Please understand that while I enjoy doing this, I may not get to it right away. Also, please understand, garbage in, is going to be absolute garbage out.
Garagedude is offline   Reply With Quote
Old 01-24-2009, 01:24 AM   #115
'72 Shorty
'72 Shorty's Avatar
Sorry, brain fart, I thought I put that in there. 3800RPM
12.922/102.28
-69 C-10
-05 Suzuki DRZ-400S
Old 02-06-2009, 09:04 PM   #116
ProStreet71
Hey Super73, I would like to make a change to my post on my head specs. I just purchased a new set of AFR 227 Race port heads.
227cc intake runner
80cc exhaust runner
65cc combustion chamber
2.10 intake valve
1.60 exhuast valve
Flow:
.200 150 114
.300 215 162
.400 259 204
.500 293 220
.550 302 225
.600 309 229
.650 313 233
.700 315 236
Thank you for your time.
Old 02-08-2009, 01:46 PM   #117
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
engine data
1979 350
bore: 4.060
stroke: 3.480
factory tolerances
belt driven water pump
electric fan
Head data
1967 283 powerpack heads slightly ported
Intake: 1.72
Exhaust: 1.50
head casting # 3884520
compression: 10.65 to1
intake http://www.jegs.com/i/Edelbrock/350/7101/10002/-1
Carb: 600 cfm holley vacuum secondaries 4160 series
header data
1 5/8 primary tubes 32 inches long 3 inch collector
cam data
http://cranecams.com/?show=browsePar...tType=camshaft
vehicle data
1964 chevy c10 shortbed
says 3400 on title not sure on aproximate weight
115 inch wheelbase
th350
2500 stall converter
3.73 gears
12 bolt detroit locker
30x9x15 m/t et drags
http://www.jegs.com/i/Mickey+Thompson/672/3066/10002/-1
thanks
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 01-27-2010, 11:33 PM   #118
Jim_PA
Engine info
Bore 4.030
Stroke 3.75
6.0" rods
Factory tolerances or set up more as a race motor? more like race (I think?)
Electric Water pump? NO
Electric Fan? clutch fan for now
Head data:
*----* Intake and Exhaust Valve size 2.05/1.6
*----* Head flow numbers (Please provide them or a link to MFG's website, I don't want to have to search for info. If these are stock heads, try to give me a casting or something)
AFR eliminator 195 Street #1034
Compression ratio 11.05:1
Type of intake (Single plain, dual plane, again link if you can find it).
Carb or TB (Is it a vacum carb?)
dual plane performer RPM Qjet #7104 Personally, I'd argue a Qjet is more like a mechanical secondary than a vacuum secondary.
Header Data:
*----* Tube Diameter 1 5/8 Thorley Tri-Y #372Y
*----* Tube length to collector (this can be your best guess, but the more accurate, the better) It varies with the Tri-Y ---
Cam info:
DV282-06HRH - Hydraulic Roller (This is from a D.Vizard book, cam is made by Lunati)
Adv. Duration 282/282
Duration at .050" 231/231
Total Lift and based on what rocker ratio .589/.589 1.65
Intake centerline 102
LSA 106
What rocker are you using? 1.65
Here's some calculations I've already done:
Advertised Duration: 282 / 282
LSA/ICL 106/102
Intake Open BTDC: 39
Intake Close ABDC: 63
Exhaust Open BBDC: 71
Exhaust Close ATDC: 31
Overlap: 70
Total Cam Adv: 4
Piston to deck .010
Gasket thickness .028
head gasket bore 4.030
Head CC volume: 65
Piston volume: 5cc
ADV intake Closing angle:63
Dynamic Stroke Length: 2.96350
Distance of piston from BDC: .78649
Calculated DCR 8.96
Blower/turbo?
I need to know size and PSI you are running. NO
Intercooler? Air to Air or Air to water? NO
Total weight 3860 with driver
Front/Rear weight bias '68 C10 (70/30??? Sorry, don't know )
What trans you are running (Gear ratio if different than stock)
Super T-10 2.64/1.75/1.34/1.00
Gear ratio 3.73
Differential (Open, production posi, spool) production posi
Tire size (height, width and type, again if you have a link to the MFG's page, even better).
Hoosier 18120: 26X9 D06 compound 26.1" diameter 9.0" wide
Jim_PA is offline   Reply With Quote
Old 02-17-2010, 01:11 PM   #119
Jim_PA
Any chance of doing mine? Thanks-!
Old 02-17-2010, 01:49 PM   #120
nomrlz
nomrlz's Avatar
can you advance/retard cams to see how it affects the output? be curious to see the differnce in my that and bigger rockers on my 383 LT1 build. also not sure if an LT1 ported stock intake is considered single or dual plane
nomrlz is offline   Reply With Quote
Old 02-18-2012, 11:29 PM   #121
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Finally found your thread. You mentioned you could run my combo....info below. Thanks in advance! Would be interested in what your program comes up with for power numbers. Also if it helps...out of only 2 shake down runs with no changes/no tuning (and probably off) ran 8.4676@82.80 - w/1.9446 60' - 5.4809 330'
Engine info
4.00
3.622
Factory
Electric Water pump? No
Electric Fan? Yes
Head data:
2.16 in. / 1.59 ex
stock L92 flow
9.65:1 comp.
LSX dual plane
Carb - 750cfm Street HP
Header Data:
1 7/8" Tube Diameter
30"? Tube length to collector (this can be your best guess, but the more accurate, the better)
Cam info:
LSr273
223/231@.050"
.610/.617 1.7:1
107* icl
112 LSA
factory
Vehicle Data
est 3850lbs
est - 60/40?
200-r4
2500 stall
3.73
eaton posi
315/60-15 MT ET Street d/r - too tall for my gear ratio
no NOS
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-20-2012, 02:06 PM   #122
69Beauty
69Beauty's Avatar
Engine info
Bore 4.06
Stroke 3.48
Electric Fan? No
Head data:
1.94 IN 1.5 EX Intake and Exhaust Valve size
Pretty much stock vortec head. (062's) did a little exhaust work but nothing to major.
Compression ratio 9.73
Type of intake Weiand Stealth Dual Plane vortec Intake
Rebuilt Qjet. Flows around 800cfm
Header Data:
1.75 Tube Diameter
Around 24" i think. Tube length to collector
Cam info:
Link to MFG's web page or cam card would be best but.. Lunati 60103
Duration at .050" 227IN 233EX
Total Lift and based on what rocker ratio .489IN .504 EX
LSA 110
What rocker are you using? 1.5 rollers
Vehicle Data 69 custom 10 long bed.
Total weight around 4000lbs
Front/Rear weight bias No idea probably 60/40
What trans you are running 700r4
Size converter 2800 stall w/ lockup
Gear ratio 3.73
Differential posi
Tire size 28x12 on back 28x8 or so on front.
1969 C-10 LWB 388 SBC Vortec Heads 10:1 Lunati 60103 cam Weiand intake Quadrajet Carb 12 Bolt 3:73 posi 700r4 Hedman Headers
1998 Dodge Ram 1500 Reg. Cab Long Box 4X4 5.9L 183k miles
1956 Ford F-100 Longbed with Original 272 and 3OTT
1995 C1500 ECSB 6.5 Diesel 4l80e (Camper puller)
1997 Dodge 3/4 ECLB V10 (MPG machine)
69Beauty is offline   Reply With Quote
Old 03-17-2012, 08:50 PM   #123
68GMCCustom
still doing these? if so, my info is above. If it makes a difference...I am getting ready to go to an OEM efi type setup with truck intake and 50# injectors.
Kurt -
Old 03-17-2012, 09:55 PM   #124
Boostedbowtie
I'm interested also if you have time .
Engine info
Bore : 4.30
Stroke : 3.73
race motor
mechanical water pump
electric fans
Head info
intake valve : 2.050
exhaust valve : 1.600
9:1 cr
single plane intake ( vic jr )
Carb 750cfm
Header info
1.75 tubes , 3" collector , 2,5" crossover
Cam info
1.5 rocker
Power adder
80mm turbo , 22psi
water/air intercooler
Vehicle Data
4450lbs
54% front
46% rear
TH400
9.5" converter ( around 2800 stall )
3.73 gear ...... Dana60 ..... truetrac dif
31 x 10.5 x 15 Tire size
Boostedbowtie is offline   Reply With Quote
