Old 01-15-2010, 11:45 PM   #101
70 Suburban
Rods
Re: Tommys66 Build
I like that cooler... I have one from a mack truck that is water cooled, but im not sure how to feed it water?
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 01-16-2010, 10:26 PM   #102
tommys66
Re: Tommys66 Build
Thanks. I got the idea from 68shortstep. On yours, could you not series the water thru it from your heater core lines?
I love the smell of lead paint!
tommys66 is offline   Reply With Quote
Old 01-16-2010, 10:47 PM   #103
70 Suburban
Rods
Re: Tommys66 Build
i thought about that but if I use the heater box from the 08 sub it has a water shut off for the heater so it would slow the flow for the cooler
Old 01-17-2010, 04:11 PM   #104
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: Tommys66 Build
Originally Posted by tommys66 View Post
Can someone tell me which is the pressure and which is the return on this powersteering sector?
If I can remember to look at mine I'll let you know. Of course I have forgotton what color my truck is, since I haven't seen it in a long time.
I did find this on post #1434 in my build Joe231 said this
the low pressure fitting was smaller than the high pressure side.
Here is a LINKY to hose placement.
Alan's Classic is offline   Reply With Quote
Old 01-17-2010, 09:43 PM   #105
70 Suburban
Rods
Re: Tommys66 Build
havent solved the heater/cooler issue but im starting on the a/c tomarrow
Old 01-17-2010, 10:04 PM   #106
tommys66
Re: Tommys66 Build
thanks, I checked the link and it clearly shows the return on the front port and pressure on the port furthest from the cab.
Old 01-26-2010, 10:06 PM   #107
tommys66
Re: Tommys66 Build
welded a few patches in the dash. I am going to put an a/c vent where the ash tray was, and a different a/c control panel where the origional was. Any ideas for the vent? not sure what i want.
Old 01-26-2010, 10:26 PM   #108
70 Suburban
Rods
Re: Tommys66 Build
i think i am goin to use the stock 08 vents for where the stock vents were
Old 01-26-2010, 11:58 PM   #109
Alan's Classic
Re: Tommys66 Build
Old 01-27-2010, 11:08 PM   #110
tommys66
Re: Tommys66 Build
Good Idea, only if I had a complete donor truck.
Old 01-27-2010, 11:10 PM   #111
70 Suburban
Rods
Re: Tommys66 Build
I do take advantage of that.. I had to find away to get the vents in and use the dash data switch.. so i went with that.
Old 01-27-2010, 11:19 PM   #112
tommys66
Re: Tommys66 Build
I seen some cracks in the paint on the roof skin, so I investigated with a grinder and this is what I found!
Old 01-27-2010, 11:29 PM   #113
tommys66
Re: Tommys66 Build
I had a good roof skin on my parts truck, so I clipped the cab to get the top down to a good working level. I sandblasted the roofskin and primed, then I removed It from the old cab section. I measured 1 1/2" all the way around on my good cab and cut the skin off of it. The donor roof skin fit down on the good cab really well. Looked like a couple of mouse condos in the void between the inner and outer skins! I will use 3M metal bond to glue the skin on.
Old 01-27-2010, 11:34 PM   #114
70 Suburban
Rods
Re: Tommys66 Build
thats the ticket there
Old 01-28-2010, 12:33 PM   #115
daverod
SSN 706
daverod's Avatar
Re: Tommys66 Build
Sweet. At first I thought you were insulating your roof with mouse nests. Nice work.
daverod is offline   Reply With Quote
Old 01-28-2010, 09:18 PM   #116
tommys66
Re: Tommys66 Build
maybe I should?
Old 01-28-2010, 10:47 PM   #117
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: Tommys66 Build
You couldn't tell it was dented from the underside?
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 01-28-2010, 11:01 PM   #118
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: Tommys66 Build
seems lke a lot of work
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 01-29-2010, 12:28 AM   #119
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: Tommys66 Build
Very impressive!
Joey~AP is offline   Reply With Quote
Old 01-29-2010, 11:31 AM   #120
tommys66
Re: Tommys66 Build
there is a void between the inner and outer skin. so no, couldn't tell from inside.
Old 01-29-2010, 11:33 AM   #121
tommys66
Re: Tommys66 Build
took a couple days, but wasnt too bad. I replaced it cause I didnt want this area comming back to haunt me. Being that its the roof it catches all the weather.
Old 01-29-2010, 11:34 AM   #122
tommys66
Re: Tommys66 Build
Originally Posted by Joey~AP View Post
Very impressive!
Old 02-01-2010, 06:37 PM   #123
nomrlz
nomrlz's Avatar
Re: Tommys66 Build
WOW! great build and even better documentation. we just bought a 5.3 for my boys truck saturday but are way aways from doin the swap. gonna look for an LS camaro tank too. thanks for the swap ideas. i really didn't wanna buy a $500+ gas tank.
nomrlz is offline   Reply With Quote
Old 02-01-2010, 07:35 PM   #124
tommys66
Re: Tommys66 Build
thanks, and good luck. I don't have all the answers for the swap, but if you get in a bind don't be afraid to ask.
Old 02-01-2010, 10:02 PM   #125
Alan's Classic
Re: Tommys66 Build
Nice job on the roof!!
