06-16-2010, 05:03 PM | #101 |
Redefining LowBudget
Re: 1970 cst lwb project "Cheap Build"
I guess I need to add a pic of the rear suspention for referance a few people have asked what gets the Pro Streets under it with out rubbing
notice the P bar and how long it is and the way when its dumped the U bolts just fit between the rails |
07-24-2010, 08:58 AM | #102 |
Wish me luck I'm diving under the hood for the transplant
stay tuned it maybe a bit before I can upload pics Last edited by Hottrucks; 07-25-2010 at 09:38 PM. |
07-24-2010, 09:04 AM | #103 |
VA72C10
Best wishes
it had to be done...
Looking for a 67-72 swb or blazer project in or around VA. |
07-24-2010, 09:34 AM | #104 |
454 MAKES IT ROAR
We'll be waiting!
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
07-24-2010, 11:25 AM | #105 |
Grandpa in the rustmobile...
good luck I said the same thing like 3 weeks ago im still not done!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
07-24-2010, 01:14 PM | #106 |
Ok started it about 9 ..it's now 1 the old motor is out and frame lip is flat and clean I'm going to get the other engine hoist from the neighbor...keeo in mind this is a one man show!!!
I have taken some pics and will instert them when I can breath!! its 87* and almost 70% humidity things will slow a bit but I hope to have it in and out once today..this will alllow me to bolt things up like factory after I tack weld things in and repaint the fire wall...thats my goal for toady...it maybe a late night!!!!!
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
07-24-2010, 06:18 PM | #107 |
ok my butt is dragging...but heres where I stand
the otor has been mocked up and the motor mount are in..it was close but I didn't have to tune the firewall either which was nice the TH350 that was in the truck that I used for a guide is out!!! along with the motor..I just can't bring myself to put it back in with out cleaning up the engine bay..so after a shower I'm going to hike out to Dads to get the presure washer the plan is to wash the hell out of everything then head out get a few cans of paint and an elbow for the heater hose some 3/16th fuel line bythe time I get home it should be dry and I can at least give it a quick sanding and a coat of paint I'm wooped something tells me that a 9 pm bed time will be to late!!
07-24-2010, 08:35 PM | #108 |
hey hotttrucks, make a stop at the dollar general get as man cans of 1.25$ oven cleaner as you can carry out it helps a ton!! I just did this myself,
fyi oven cleaner taks paint off, becareful
07-24-2010, 08:54 PM | #109 |
thanx I have it sprayed down with casreol super clean it workd really well the power washer is set up so I'm going to hit it firat thing then go get the paint when I get home it will be dry..I'll sand it and give it the once over//then watch the paint dry...
07-24-2010, 09:25 PM | #110 |
hows the castrol super clean compared to purple power or the like? I saw some at walmart and thought of tryin it but didnt..
07-25-2010, 07:56 AM | #111 | |
havn't tried it but I use the Castrol for cleaning heavy equipment and it works very well just be sure what your using it on you only care about clean not the finish because it will eat alot of stuff Last edited by Hottrucks; 07-25-2010 at 09:34 PM. |
07-25-2010, 09:48 AM | #112 |
454 MAKES IT ROAR
I hope that camera has been busy too.....sounds like you've made good progress mate.
07-25-2010, 11:13 AM | #113 |
Oh yeah, I ruined my shiny carb and valve covers with purple power...i just wonder if it works any better or is the same thing...haha better be working the camera to
07-25-2010, 12:12 PM | #114 |
Motor and trans are in !! now to start hooking all the stuff up....maybe a fire in the hole today???
Heres a teaser you picture whores!!! Last edited by Hottrucks; 07-25-2010 at 09:00 PM. |
07-25-2010, 09:28 PM | #115 |
it lives
07-25-2010, 09:38 PM | #116 |
VA72C10
07-25-2010, 09:56 PM | #117 |
nice man!!! what the heck is it lol?!?!?
07-25-2010, 10:09 PM | #118 |
Its A 500 Caddy!!!!!!!
all the stories I heard about beating the fire wall back and such where all for not ..by using the stock TH 350 to line up the caddy when I finallly got the motor in and out and replaced the TH350 with the TH 400 (longtail shaft) everything lined right up..the trans linkage and tranny lines the X memeber moved back ( I need to get a new tran mount from the Caddy) the fan is getting a 2" spacer it clears the Radiator by about 1" I even reused the stock throttle rod..the hard part is moving the Alt wiring to the otherside.. its going to be real slow the next few days (I'll keep the camera going) I'm going tp measure up the DS tomorrow try to clean up the rest of the wiring and get some trany fluid in it....also I'm going to install the fan and water pump/alt belt....then I'm going to tackle some rust isssues...I hope to have it complet by the weekend..exhaust is going to slow me down too!!!
07-25-2010, 10:32 PM | #119 |
sweet dude!!!!!!
07-26-2010, 12:32 AM | #120 |
500=
Good choice!
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
07-27-2010, 07:50 PM | #121 |
Ok ITS ALL IN!! it goes for exhaust on friday al I need to do is put the trans mount in and I'll give it a yard drive!!! it has to go about 1 1/2 miles to the exhaust shop with open exhaust!!
Anyway I made up a new front driveshaft out of an old one I had laying around I'm going to have a 1 piece built....DON"T TRY THIS AT HOME I dont think I did bad It took me 3 days for the motor swap put on a new fender paint the firewal and under carrage..not bad for a 1 man show..with help I could do i easily in 2 short days
07-27-2010, 09:21 PM | #122 |
looks grea!!!!! I cant wait for my motor to get in, im slower than you are...and its my DD LOL
07-27-2010, 10:35 PM | #123 |
I cant wait for this beast to turn those big @$$ rear meats.
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
07-28-2010, 12:39 AM | #124 |
VA72C10
nice work!!!!
looking forward to a video
07-28-2010, 11:02 PM | #125 |
I might give it a little love but I think I'll wait till I get the 1 piece Driveshaft before I stab at the new Wrinkle Walls!! it goes friday for the exhaust then I can tune it ?? I want to hit the car show saturday and theres atill a few loose ends like hooking up the trans switch and getting the hood on ..I also need to flush the block it seem like theres a bunch rust in the block because the water is all dis colored..I'm going to hit it with some CLR and figure out how to hook up the heater since theres no return on these motors
