Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 01-08-2014, 02:32 AM   #101
Captainfab
60-66 Nut
Re: Power Brake Booster Adapter Bracket
PM replied to
Originally Posted by Clrussell View Post
Sent ya a pm
Old 01-09-2014, 06:18 AM   #102
Trucolur
Will this put you back up front so I can keep tabs on you and your nice fab work!!
Trucolur is offline   Reply With Quote
Old 01-10-2014, 02:36 AM   #103
Captainfab
60-66 Nut
It will for just a short time with as busy as this classified section is. You can always find this thread again by either subscribing to it, or simply follow the link to it from my signature line.
Old 01-14-2014, 07:34 AM   #104
Clrussell
Clrussell's Avatar
Received my bracket in the mail yesterday! Looks great! Thanks again! Now I've just gotta find time to put it on.
61 apache
Clrussell is offline   Reply With Quote
Old 03-17-2014, 03:48 PM   #105
Bennett68C10
Bennett68C10's Avatar
PM sent
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 03-17-2014, 11:23 PM   #106
Captainfab
60-66 Nut
PM replied to
Originally Posted by Bennett68C10 View Post
PM sent
Old 03-18-2014, 02:33 PM   #107
Bennett68C10
Originally Posted by Captainfab View Post
PM replied to
Payment sent, thanks again.
Keith
66 Suburban
IG: bennett68c10
Old 03-26-2014, 11:04 AM   #108
ChuckBrick
Hey, just getting started on a build of a '70 Long bed stepside. What exactly is the advantage of using this setup?
ChuckBrick is offline   Reply With Quote
Old 03-26-2014, 11:15 PM   #109
Captainfab
60-66 Nut
The purpose of my '67-'72 brake booster bracket is to get the booster and master cylinder closer to the firewall instead of hanging way out there. You do not have to use a newer booster if you don't want to. The '67-'70 is one of the compatable boosters. But if you are going to upgrade to front disc brakes, that would not be the one that I would choose. If you do go with a newer brake booster, you can find one in just about any wrecking yard or parts store.
Old 04-06-2014, 12:16 AM   #110
Captainfab
60-66 Nut
I have 2 of these '67-'72 booster brackets that are zinc plated. The price is the same as the powder coated version which is $61.50 plus $11.65 for shipping.
Old 04-11-2014, 11:04 PM   #111
Captainfab
60-66 Nut
One zinc plated booster bracket left
Old 04-16-2014, 01:59 AM   #112
68anthony
68anthony's Avatar
Does this set up work for disk/disk? I want to use the same power booster as all of you are talking about. I am running a ls5.3. w/ a 4l60e.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=606231
68anthony is offline   Reply With Quote
Old 04-16-2014, 10:26 AM   #113
Captainfab
60-66 Nut
This booster bracket will work for all types of braking systems. You will just need to use a master cylinder and prop valve for a disc/disc system with the booster that you select. Some guys recommend a dual diaphram for a disc/disc system.
Old 04-16-2014, 05:38 PM   #114
ChuckBrick
Getting ready to install a setup on my 70 LB stepside. I'll post pics as I get it done and let everyone know how the conversion goes. Got my brackets from Captainfab for the Impala rear disc setup and the booter bracket as well. It's 4 wheel manual drum now. Got a pair of 2 1/2" drop spindles that'll be here tomorrow. Gonna use a Wilwood adjustable proportioning valve.
Old 07-29-2014, 02:03 PM   #115
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Sending PM for a pair of brackets
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 08-23-2014, 11:45 PM   #116
Captainfab
60-66 Nut
I still have one zinc plated booster bracket.
Old 09-18-2014, 10:12 PM   #117
Zeroman
Zeroman's Avatar
Subscribed
What do you have available?
Zeroman is offline   Reply With Quote
Old 09-19-2014, 01:22 AM   #118
Captainfab
60-66 Nut
I still have the zinc plated booster bracket as well as several in bare steel. I am currently out of the satin black powder coated booster brackets but I will be getting more done.
Originally Posted by Zeroman View Post
Subscribed
Old 09-19-2014, 08:52 PM   #119
Zeroman
Zeroman's Avatar
What would the cost for zinc plated shipped to 77095?
What would the cost for bare steel shipped to 77095?
Old 09-20-2014, 12:50 AM   #120
Captainfab
60-66 Nut
The total price for the zinc plated booster bracket is the same as in post #110 above.........$73.15. The price for the bare steel booster bracket is the same as in post #1 of this thread.......$66.65.
Old 09-29-2014, 07:56 PM   #121
70shortstep
Registerd User
70shortstep's Avatar
I have a i6 250 and have read that I will need an offset breather if I go with a booster. If I use your bracket will my factory breather clear.
John
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=613398
70shortstep is offline   Reply With Quote
Old 09-29-2014, 11:47 PM   #122
Captainfab
60-66 Nut
I haven't received any feedback nor any personal experience with a I6 and my booster bracket. I made some measurements and I think that if you used a 9" diameter booster, it would fit with your stock air cleaner. If you have power steering, you could always go hydroboost.
Old 10-15-2014, 11:22 AM   #123
Dale_Brown
Do you have this bracket with a hydraulic clutch bracket?
Dale_Brown is offline   Reply With Quote
Old 10-15-2014, 08:22 PM   #124
Captainfab
60-66 Nut
You must not have received the PM I sent you last night?
Yes I do make a hydraulic clutch conversion for the '67-'72 trucks. I do not have a pic of it on this computer. I can get a pic tomorrow when I am at my shop. It is basically the same as what I make for the '60-'62's and '63-'66's. The price is the same as well.
Old 10-16-2014, 10:13 AM   #125
Dale_Brown
Thanks!
