Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 02-14-2011, 10:32 PM   #101
bigbadchev72
People know me
bigbadchev72's Avatar
Re: jimmy build
Got a buddy that did it to his mud truck. Looks a little off though.
Make a post on pirate or ck5 offering to swap your drw to srw hubs. There are a ton of people doing it. You need the drw hubs to run the hummer beadlocks.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 03-10-2011, 02:36 AM   #102
madkmart
Re: jimmy build
any updates what axles will you be running and im curious why are going to them thx
madkmart is offline   Reply With Quote
Old 03-14-2011, 11:36 PM   #103
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
no major updates
the girlfriend and I are getting ready to move so moneys focus on the house
i had to change to power steering pump again due to same screeching noises but turns out it wasn't the pump so now I'm looking into the water pump... we'll see if that works.
As far as the axle choice I chose to go with a front Dana 60 out of a early Dodge (was cheep [$650 with 4.56s] and minor minor difference from Chevy Dana 60) with 4.56s because of the pure stoutness of the axle.
For the rear axle I went with an Eaton H052 from a 72 Chevy utility truck because I feel that the Eaton is an awesome axle. all steel housing, similar design as a 9 in, and more ground clearance (not a huge difference but definitely noticeable) than a 14 bolt without sacrificing the strength similar to that of a 14 bolt. the only two downsides to Eaton's are very limited aftermarket support and limited factory gear ratios. but if your like me, Eaton's in there stock form are beef enough for what I need it for, and you can usually find one with 4.56s stock pretty easily.
here is a pic reference
Dana 60(its upside down in this pic)
and the Eaton
my jimmy build
http://67-72chevytrucks.com/vboard/s...d.php?t=352536
70 beast is offline   Reply With Quote
Old 03-27-2011, 08:38 PM   #104
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
not a big update but I did fix the power steering pump for the 3rd time
in other news my gf and I found our new place and put our deposit down so come mid next month this will be moving into our garage and going under the knife for a thorough paint job, Dana 60 swap, budget shackle flip with 56's, and steering upgrades
here it is after a good power washing
Once I finish up with the move, Ill update with plenty of pics
my jimmy build
Old 03-28-2011, 12:11 AM   #105
dan42
dan42's Avatar
Re: jimmy build
Lookin' good - hope your move goes smoothly and we're looking forward to seeing the new paint -
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 04-25-2011, 12:30 PM   #106
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
well i got it into the garge...let the teardown begin
it was a tight squeez even with the rollers
got the 60 out and onto some stands to do the inspection. everything looks good. no excessive scaring on the kingpins, no noticble play on the springs and everything feels nice and tight. gears are in great shape too.
just waiting on a free weekend to go to my buddies shop to finish milling down my hubs so i can swap it in.
do the "To Do" list:
1. mill D60 hubs to SRW
2. swap in D60 (make top spring plates)
3. do 52" front swap
4. budget shackle flip with 56" rears
5. rock sliders
6. hook up all gauges (only have 1functioning right now)
7. bedline the inside
8. paint.... on the fence on what color to do still but leaning towards some sort of blue again.
should keep me busey for the next few months
my jimmy build
Old 05-14-2011, 12:11 AM   #107
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
not a huge major update but Im almost got all the stuff i need to rework the suspension.
mixture of of stock K5 hanger parts and new DIY4X lower portion for the front and super budget rear shackle flip
and got the fog lights moved to their new spot....for now
my jimmy build
Old 05-18-2011, 01:12 PM   #108
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
Got the 60 all cleaned up and painted.
Waitin on the hubs n crossover arms now
my jimmy build
Old 05-25-2011, 12:59 AM   #109
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
start of the new paint.
got a set of srw D60 hubs lined up so the 60 will be one step closer
my jimmy build
Old 06-07-2011, 11:36 PM   #110
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
updates...
got the swr hubs and all buttoned up
out with the old
6" springs vs. stock 52's
new spring hanger
and did the pass. side...just got the tailgate and hood to go
gonna go make some top plates and shackles next week and get the 60 bolted up and get this thing rolling again
my jimmy build
Old 06-25-2011, 08:51 PM   #111
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
Works been slow on the jimmy.
Hopefully I can get the front end all bolted up and rolling again by next weekend
Only change is the tailgate and got the shackles done
my jimmy build
Old 06-29-2011, 01:55 AM   #112
jimmypop
Re: jimmy build
sub
jimmypop is offline   Reply With Quote
Old 06-29-2011, 09:13 PM   #113
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
went to a local Pick n Pull and found myself a 68 camper special with a no spin so i said...what the hell...went to check out and lucky for me they couldn't figure out what to use in the comp for it so i got it for $10 bucks!!!!!
now the decisions whether to keep it for this, my S10 sas project (running an Eaton rear) or sell it.... decisions decisions decisions.
my jimmy build
Old 07-13-2011, 12:55 AM   #114
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
Re: jimmy build
The epicness of the picture with skateboards under the axle on blocks is overwhelming, cheers to you sir, and sweet score on the 68! Your build is coming along great, keep up the good work..
Eturnit3 is offline   Reply With Quote
Old 07-14-2011, 12:06 AM   #115
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
Hahah yah my dad thought the wieght of the truck was on it but then he seen the jack stands. I was surprised the boards came in as handy as they've been with this project haha.
As far as an update, ill be picking up the ubolt plates, and a bigger ubolt so i can button up the front. Then i need to price some metal for crossover arms so i can get some steering going on this.
my jimmy build
Old 07-29-2011, 12:15 AM   #116
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
Got some ubolt plates and a large ubolt the other day from WFO concepts in auburn ca. Very well built pieces and awesome customer service!!!
Painted them up today and buttoned the front up and got it sitting on all 4s again.
Might have to move my front mount forward to get a better shackle angle and tire clearence.
Ill roll this thing out tm morni g amd get picks before i take it apart again to fix the front mount hahah.
my jimmy build
Old 07-30-2011, 12:03 PM   #117
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
Pics
my jimmy build
Old 08-02-2011, 12:24 PM   #118
CussinDusty
CussinDusty's Avatar
Re: jimmy build
Looks great! Nice progress
http://i957.photobucket.com/albums/a...sty/sig2-3.jpg
87' Blazer
36"TSL SX,
Bedline'd Interior,and bumpers
Heddman Long Tubes,True Dual Flowmaster 40's
4:11's locked
Build Thread-
http://www.fullsizechevy.com/showthr...r-Build-Thread
CussinDusty is offline   Reply With Quote
Old 08-10-2011, 09:25 PM   #119
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
Comparison
then
now
then
now
my jimmy build
Old 08-11-2011, 08:13 AM   #120
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
Re: jimmy build
glad to still see the slots! atleast on the front, I'd get rid of those steelies out back! haha
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 08-11-2011, 08:25 AM   #121
motornut
78K & 79C Jimmys
motornut's Avatar
Re: jimmy build
looks very rearview mirror intimidating cool!
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 08-14-2011, 01:21 PM   #122
70 beast
Certified Hobbiest
70 beast's Avatar
56's installed
Yesterday was a good day!
Picked up my lil brothers yesterday to give me a hand swapping the springs and hangers out. took about 4-5 hours total. I gotta remove the drive shaft today because I think its limiting the travel being that the slip has bottomed out but I need to install some zero rates to push the axle back 1.5" or get some of ruffstuff's multi-position spring perches.
anyways....PICS
here you can notice the back end is higher than the front....i think the drive shaft is preventing the springs from settling all the way
now i need to move the front spring hangers forward and move on to the gas tank (needs a float, the filter sock, and needs to be reinstalled.
my jimmy build
Old 08-15-2011, 12:30 AM   #123
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
Did some tinkerng with the front suspension today.
Moved the front hanger forward ~2.5" to get a better shackle angle...worked pretty well IMO.
Also took off the rear drive line, which was bottomed out and preventing the rear suspension from compressing anymore. decided to rum a zero-rate and RuffStuff multi-position spring perches to move the axle back ~3"
shackle angle (looks good now)
front hanger moved forward
Pass. side
driver side
my jimmy build
Old 09-07-2011, 08:22 PM   #124
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
Did some laboring on this pig on monday...seemed fit since it was labor day hahah.
Didnt get everything that I wanted but I did get the rear springs flipped around (56s are offset 26/30, so I put the long side forward to move rear axle back 4") and I got the gas tank in with a functioning sending unit so now my gas gauge works!!!!!
Still gotta get the oil pressure line hooked up.
Also went to PnP on sunday...got a 2wd sector shaft, pitman arm off a heep XJ, a tierod assembly off a late 80s K5, and ordered my crossover arm and cap...all for $140. So once its all said and done, I should be ~$180 into my crossover steering which isnt bad.
Ill push the truck out in the next few days to get a new side shot with the rear axle move...working from 7am-4pm and school from 5pm-11pm sure does put a hinder on workin on the truck but its worth it in the end. Posted via Mobile Device
my jimmy build
Old 09-12-2011, 02:12 PM   #125
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
might have to get a zerorate for when the spring compresses, it'll be into the rear fender, but Ill trim that some more and see what my clearances are
my jimmy build
