Old 04-14-2014, 04:40 PM   #101
fast&low
Re: Pic Request: Rally wheels on a dropped truck
275/60R15,275/70R15 is the biggest & widest you can go safely or without it looking funny on an 8" wide wheel.
What size are you running & what size are you looking to move up to?
fast&low is offline   Reply With Quote
Old 04-14-2014, 05:00 PM   #102
67 cst swb
67 cst swb's Avatar
Ok, I know you've heard 100's of suggestions...
So, here is mine:
Front - Truck Rallye
7" wide Rallye
w/ 225/75R15 tire 28.25 tall
or
w/ 225/70R15 tire 27.4 tall
Rear - Truck Rallye
8" wide Rallye
w/ 265/70R15 tire 29.6 tall
or
w/255/70R15 tire 29.05 tall
or
w/275/60R15 tire 27.99 tall
This has always been my set-up of choice...
FYI... the stock 235/75R15 tire is 28.87 tall
Where to Find Rallye Wheels
5 lug
7" wide - 73-late 80's Van only
8" wide - 73-late 80's 2wd pickups & some Van's
6 lug
7" wide 73-late 80's 4x4 Blazer only
8" wide 73-late 80's 4x4 Pickup & some Blazer's
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red
67 cst swb is offline   Reply With Quote
Old 04-14-2014, 05:17 PM   #103
fast&low
X2
That's the same tire set up I'm running 225 front 275 rear
Old 04-14-2014, 10:39 PM   #104
77 shorty
77 shorty's Avatar
Im running 225/75-15 front in back right now.. Im ok with the fronts but I want some more width in the back. Im thinking 275/60-15 in the rear... but maybe ill go 275/70's instead to keep them as tall as the fronts
1977 K10 shortbox Scottsdale 4x4
1988 C30 Crewcab Silverado
1987 K10 longbox Silverado 4x4
1969 GMC 1500 4x2
77 shorty is offline   Reply With Quote
Old 04-14-2014, 11:13 PM   #105
7d1truckguy
7d1truckguy's Avatar
Here is my 71 gmc with chrome 15 inch rallies
7d1truckguy is offline   Reply With Quote
Old 04-14-2014, 11:26 PM   #106
OregonNed
OregonNed's Avatar
I wanted to same look on my 68, so I made it so a month or two ago. I bought Corvette Style, 7" up front, 235/70/15 and 8" in the back, 275/60/15. The derby caps are Metal. Love the results!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 04-14-2014, 11:33 PM   #107
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Got Corn?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 06-04-2014, 01:38 PM   #108
77 shorty
77 shorty's Avatar
new tires
1969 GMC 1500 4x2
Old 06-04-2014, 01:58 PM   #109
Sklptrljay
Sklptrljay's Avatar
Give you any ideas?
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 06-04-2014, 07:31 PM   #110
Joe Pass
Joe Pass's Avatar
Nice truck
Joe Pass is offline   Reply With Quote
Old 06-04-2014, 08:53 PM   #111
Sklptrljay
Sklptrljay's Avatar
I was referring to the sign above the truck!
Old 06-04-2014, 11:12 PM   #112
dlct3
2.5" drop spindles, 4" rear 15x8" 4" backspacing 255/60 fronts & 15x10" 5" backspacing 275/60 rears.
20x10 & 20x8.5" Billet Rally's on order!! Cant wait
dlct3 is offline   Reply With Quote
Old 06-05-2014, 09:12 AM   #113
Fitz
Originally Posted by Longhorn Man View Post
not a fan of car rallys myself... but the truck rallys look nice on these rigs...
there's plenty that look better, but these give a stock vibe, while looking good, and look better than the hubcaps that are usually found on them (or lack of caps)
I do like that Burb.
Fitz is offline   Reply With Quote
Old 06-05-2014, 12:25 PM   #114
Lees68GMC
Lees68GMC's Avatar
Cheap, 15 X 8 Chrome Rallys (Discount tire) with 4 inch back space 2-1/2 front drop, removed a coup[le of leafs outta leaf springs in back. Free hub caps, no beauty rings
275-60-15 BFG radial TAs
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline   Reply With Quote
Old 02-02-2015, 04:38 AM   #115
68Redhead
Will 15x8 rally wheels rub the lower control arm with 2 1/2" drop spindles? I'd like to convert my '68 to front discs. I have 2" front drop springs already (not installed) but read they aren't the ideal way to lower the front. I'm thinking of running 255/70 all around. It seems I've read the LCA interferes with rallies but that might have been when I was looking to put them on my '94.
68Redhead is offline   Reply With Quote
Old 02-02-2015, 05:26 AM   #116
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I called ECE a while ago with the same question as I had 255/70 15's on 15 x 8 rallys on all 4 corners on a stock height long box truck. I asked Mark at ECE if I put a 2 1/2 inch droppd front spindle up front with a 4 inch drop spring in the rear would the front tires rub on turns, and he said they may or may not. If you used a 245/60 15 up front or all the way around I am 99 % sure there would beno rubbing issues.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-02-2015, 09:41 PM   #117
1968aj
heres mine. still under construction. my junkyard rally wheels. 8,s on front and back
1968aj is offline   Reply With Quote
Old 02-02-2015, 11:24 PM   #118
bobshotrodblazer
BigBlockBobby
also under construction
Bob
bobshotrodblazer is offline   Reply With Quote
Old 02-03-2015, 12:39 AM   #119
Ironangel
Ironangel's Avatar
BFG 275/60-15's all around on a 4-4 drop...
"Two Seventy Two's"
02 3/4 ton Express
Old 02-22-2015, 05:44 PM   #120
69 GMC Daily Driver
69 GMC Daily Driver's Avatar
My 70 Short on American Racing Rally's
20x8.5 and 20x10.5
[IMG][/IMG]
70 GMC Serria Grande Short
70 Chevy C/10 Short LS Powered
72 Jeep J2000 4X4
86 El Camino (22k original miles)
69 GMC Daily Driver is offline   Reply With Quote
Old 02-22-2015, 06:02 PM   #121
tommys72
tommys72's Avatar
That sir is amazing ⬆
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 02-22-2015, 06:15 PM   #122
jondancer
Whoa , that's nice. Never seen that one before
jondancer is offline   Reply With Quote
Old 02-22-2015, 06:18 PM   #123
Boog
laying low
Boog's Avatar
x2. That is a good look right there. Different color combo and the wheels.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-22-2015, 06:45 PM   #124
scotts72
scotts72's Avatar
I like Red but have to say that color is pretty sweet!!
scotts72 is offline   Reply With Quote
Old 02-22-2015, 07:45 PM   #125
69 GMC Daily Driver
Thank you Tommy
Thank you Jon
Thank you x2 Boog
72 Jeep J2000 4X4
