Closed Thread
Old 03-12-2010, 02:08 AM   #101
jetfixr
Re: LFD's gas pedal adapters (71-72 gas pedals in 67-70's)
I was looking at the lokar cable for this mod. Problem is lokar has a clevis attached to the pedal end, the stock pedal is not meant to have a clevis attached to it. The stock pedal is set up to have a the cable thread thru it. There is a little pastic bushing on the pedal and a lead bead that is crimped on to the cable to hold it in place. What would be the best way to adapt it?
jetfixr is offline
Old 03-12-2010, 10:12 AM   #102
Sinister
Between Trucks...
Sinister's Avatar
You can cut and weld the pedal arm and drill it for the clevis. Or I think somebody, (Hartrod?) removed the clevis and just used the cable end on the stock pedal. I cut and welded mine.
Beat it to fit,
Paint it to match...
Sinister is offline
Old 03-12-2010, 03:27 PM   #103
6772owner
Gearhead
6772owner's Avatar
I used the Lokar cable as well, I just pulled the cable all the way out of the sheath and fed it thru the stock pedal eyelet and back in the sheath. The cables pre crimped end then just rides up against the stock plastic insert for the original cable and has worked fine for me.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline
Old 03-12-2010, 08:59 PM   #104
cobrajet21
cobrajet21's Avatar
I'll take one. paypal sent,
http://67-72chevytrucks.com/vboard/s...d.php?t=288820
68 Chevy CST project
02 Chevy Silverado Ex.cab
71 Ford Torino Cobra
cobrajet21 is offline
Old 03-13-2010, 11:15 PM   #105
travlinman
can this be used on a 68 burb with a straight 6 ? interested it it will fit/work..
thanks
94 ls swap silverado
65 Pontiac
78 c30 crew cab dually (parted and gone)
82 c30 crew cab dually ( now building )
91 r30 crew cab dually (parted and gone)
69 swb-sold
71 lab sold
all in progress......__
..........._______ |__\__
..........|__(O)______(O)] ........................
travlinman is offline
Old 03-14-2010, 11:30 PM   #106
RED67
Forever Grateful
RED67's Avatar
$$$$$$ sent
R.I.P Dad 04-07-42 - 05-27-09
RED67 is offline
Old 04-16-2010, 12:38 PM   #107
Beelzeburb
Devil's in the Details
Beelzeburb's Avatar
Mine is finally in place and working like it should. It took a lot of tweaking, grinding and a little bending but it has the full range of motion, doesn't bind and it lets the pedal sit at a stock angle.
For as much work as it took to use my original '70 pedal linkage I should have probably just purchased a '71-'72 setup.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread
Datsun 240Z, 510 2 door and an old Honda motorcycle
Beelzeburb is offline
Old 05-05-2010, 03:40 PM   #108
70stroker
70stroker's Avatar
I am converting over to a 71-71 on my 70gmc. Do you have any of these left?
Whats the reason needed for this adapter. whats different between the cabs?
thanks
70stroker is offline
Old 05-05-2010, 11:43 PM   #109
ripdog28
ripdog28's Avatar
thanks
No difference in the carbs, just makes it a more reliable/cleaner cable rather then the bar for the throttle. Older models had a bar and not this cable.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline
Old 05-07-2010, 04:04 PM   #110
70stroker
70stroker's Avatar
ripdog i said whats the difference in the cabs. I have a 71 pedal assembly on its way from a board member, my question is do i need this adapter that lfd is selling? why or why not?
Old 05-07-2010, 07:00 PM   #111
ripdog28
ripdog28's Avatar
lol sorry, no difference in the CABS, just how the pedal mounted. This is all included in the kit. The pedal mounted to the floor prior to 71 and had a bar, not a cable. They use the same three mount holes.
69 c-10 BBC
ripdog28 is offline
Old 06-04-2010, 09:46 AM   #112
BIG ORANGE
BIG ORANGE's Avatar
Pay-Pal sent!!! thanks
Donnie Snipes
Things happen for a reason!
BIG ORANGE is offline
Old 06-04-2010, 09:52 AM   #113
67cheby
67cheby
67cheby's Avatar
got mine , Thanks
67cheby is offline
Old 06-05-2010, 08:06 PM   #114
Rokcrln
Rokcrln's Avatar
Donnie Snipes
Git it and I need to cut out another round of mounting plates in the morning and get them in the mail Monday. I have three orders this week and only had 1 plate left from the first batch I made up.
Thanks guys,
Kevin
LFD Inc.
Rokcrln is offline
Old 06-05-2010, 10:38 PM   #115
Number98
Prestige Worldwide
Number98's Avatar
Add another set to the list...
Paypal Sent!
Number98 is offline
Old 06-06-2010, 12:00 PM   #116
Rokcrln
Rokcrln's Avatar
Paypal Sent!
Heading out now to cut them out and package them all up!
Kevin
LFD Inc.
Rokcrln is offline
Old 06-06-2010, 02:48 PM   #117
Rokcrln
Rokcrln's Avatar
Cut, punched, drilled, packaged and labeled ready for my wife to drop them off at the post office in the morning. I have 9 more sets ready to go out as well for the next guys so it would only be a 1-2 day wait before being sent out.
Thanks guys.
Kevin
LFD Inc.
Rokcrln is offline
Old 06-21-2010, 09:13 PM   #118
WHAMMYBAR66
WHAMMYBAR66's Avatar
I just ordered one ! I am tired of my Blazer applying the throttle to itself when I am creeping through a parking lot.. thanx !
WHAMMYBAR66 is offline
Old 06-21-2010, 11:19 PM   #119
roadking-111
roadking-111's Avatar
Paypal sent.
roadking-111 is offline
Old 06-29-2010, 11:35 PM   #120
WHAMMYBAR66
Wanted to make sure my Pay Pal order went through.. I ordered on the 21st, thanx !
Jeff Steele
Old 07-14-2010, 10:24 AM   #121
Warrens69GMC
Warrens69GMC's Avatar
Payment sent
Warrens69GMC is offline
Old 08-23-2010, 11:50 AM   #122
PipsC10
PipsC10's Avatar
Pay-pal payment sent, Thanks!
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702
2006 Toyota Tacoma double cab 4x4
PipsC10 is offline
Old 09-30-2010, 11:31 PM   #123
Rokcrln
Rokcrln's Avatar
Sold Out!
I will be making more but for now I am out of stock. When I get enough interest in a 4th run I will get the material and cut them all out.
Thanks,
Kevin
LFD Inc.
Rokcrln is offline
Old 10-01-2010, 11:15 PM   #124
68anniversary
Count me in when you make another round. Thanks
68anniversary is offline
Old 10-02-2010, 03:08 PM   #125
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Have you shipped mine?
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline
Closed Thread
