Old 02-23-2011, 08:09 PM   #101
lnwlfbsktbll
lnwlfbsktbll's Avatar
Re: Project 6.0 (my '87)
I think I'm leaning either vette ls2 or an f-body pan. Anybody use an aftermarket sheet metal pan? Don't wanna go with a modified stock pan because of oil capacity reduction.
'87 SWB GMC LY6/6L90E
'70 JEEP CJ5... My new toy
'06 Hyundai Accent... DD
Build thread located at http://67-72chevytrucks.com/vboard/s...5708&posted=1#
lnwlfbsktbll is offline   Reply With Quote
Old 02-23-2011, 08:45 PM   #102
lnwlfbsktbll
Or maybe the c5 vette pan. Anybody use an Ls motor from one of those cars?
Old 02-25-2011, 05:39 AM   #103
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Go look in the Lsx swaps thread in the Engine section and take a look there --- I think there is a list of what works there.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 02-25-2011, 12:26 PM   #104
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
The stock LY6 pan worked fine in my chassis...it won't fit in yours?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-25-2011, 12:34 PM   #105
lnwlfbsktbll
Oh, no it fits fine. Ample room in all directions my problem is it hangs lower than I like. I'm going to have a dropmember made kinda like the porterbuilt one but not as expensive. Being that the pan is just about the lowest point up front already I'm a little uncomfortable with that.
Old 02-27-2011, 04:41 PM   #106
lnwlfbsktbll
A picture is worth a thousand words so they say.
Old 03-14-2011, 10:20 PM   #107
shenk10
shenk10's Avatar
hey I was wondering which adapter plates you used and how you fixed your problem that you had. I bought the swaptech adapter plates, which look like the ones you got but want to be sure. My engine is not lining up with the motor mounts so I was thinking maybe we had the same problem. Also do you happen to know what part number is on your clam shells?
Jordan
1972 Chevy K5 Blazer, 6" Lift, 35x13.5R15, 6.0/6L80E/NP205
1982 Chevy C10 SWB, 2006 LS2/4l70e
In progress....
http://67-72chevytrucks.com/vboard/s...d.php?t=439860
shenk10 is offline   Reply With Quote
Old 03-14-2011, 11:18 PM   #108
my4by2
my4by2's Avatar
Mast Motorsports now sells a "universal" LS oil pan they custom built that is supposed to clear like 90% of the applications out there. May want to check into that. Also, Pacific Fabrication sells a VERY nice LS engine crossmember which is what I used on my project. Build's coming along good though man - keep the pics coming!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 03-17-2011, 04:08 PM   #109
lnwlfbsktbll
I fixed the motor mount problem by going back to o'rielly's and having them get me the right part. The mounts they had listed for an '87 didn't match what my truck had so I went back and got ones for an '86. Thanks for the input on the oil pan, I'll have to check it out.
Old 03-19-2011, 07:08 PM   #110
shenk10
shenk10's Avatar
Sorry for asking so many questions but are those the swaptech mounts? I got oe replacement motor mounts and checked them with the '86 and they seem to be identical, so I dont know what is going on. The company thinks it might be engine brackets (clam shell motor mounts) so I might try that next.
Jordan
In progress....
Old 03-19-2011, 08:38 PM   #111
lnwlfbsktbll
I used the clam shell portion of the mount that was on my small block and yes they are swaptech adapters. The problem I had was with the motor mount insert part. I could get it to bolt onto the frame brackets, but it was upside down from how the old ones were. I took the old ones and new ones back to the store to see if they could match a part for me. The first ones I got had me using the opposite 3 mount holes that it should have been.
Old 03-19-2011, 09:07 PM   #112
shenk10
shenk10's Avatar
okay thank you for the help, if your truck is still apart could you see what the number is on your clam shell portion of the mounts, just to be sure that is the same as yours. Thanks for all your help
Jordan
In progress....
Old 03-19-2011, 09:15 PM   #113
lnwlfbsktbll
It is still apart, but the motor is on the chassis. I'll try to find it tomorrow in the light if I remember though.
Old 05-09-2011, 02:01 PM   #114
shenk10
shenk10's Avatar
any luck on the engine shell number?
Jordan
In progress....
Old 05-09-2011, 02:42 PM   #115
lnwlfbsktbll
Oh, sorry man I haven't even touched my truck since you asked. I picked up a jeep that's been gettin what little funds I have after dropping money into a house savings. I'll try and check'em when I get home.
Old 05-09-2011, 05:30 PM   #116
shenk10
shenk10's Avatar
its okay, I haven't been home until now to work on my truck anyway
Jordan
In progress....
