Old 06-26-2010, 09:42 PM   #101
85burb
85burb's Avatar
Re: 85 burb meets 6.0 lq4
You put one like that or a different type. Our 68 had on and it ran good. Never actually drove one befor and after install. Would you say the tapered hole kind or the open one is better? That one in pic is about $170 would it be worth that? Heard they help with low end power.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 06-26-2010, 10:01 PM   #102
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I bought one from Summit that had an aluminum frame and plastic inserts....so you could run it open, split, or ported. It wasn't that expensive either.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-26-2010, 11:28 PM   #103
85burb
85burb's Avatar
I will have to look of one like that. Sounds cool.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-29-2010, 08:42 PM   #104
68GMCCustom
My intake is finally on its way!!! I can't wait to see it!
Kurt,
Your Order: 12345, Has Been Shipped.
Order Shipped Via: - UPS Ground Excludes AK,HI,PR,APO,AE
The tracking number for your package is: 123451234512345
You can track your order on-line by clicking here
Kurt -
Old 06-30-2010, 08:11 AM   #105
85burb
85burb's Avatar
YAY how exciting. I will be ordering mine next week. Not the GM one too pricy and dont think they make a duel for my heads. I also found that carb spacer with 3 different incerts for it. May also get that.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-30-2010, 12:48 PM   #106
68GMCCustom
I need to get my tail in gear. My drop spindles arrive today. I've got the front crossmember apart...just need to clean it up and paint it, then I can install it in the frame....and then I'll put the motor and trans in...and start building the front end...stitch the trailing arms so I can paint and install those, same with the rear end, etc. etc. etc.
I see how people get dis-interested in their projects if it goes too long. For some folks long term is in the original plan, but it also makes you want to give up as it begins to seem like..."it will never get finished".
Kurt -
Old 06-30-2010, 08:39 PM   #107
85burb
85burb's Avatar
I know how you feel. I dont even get to see my engine every day or even every week. Probly has ben 4 weeks sence i last laid eyes on my engine. That is what happened when i tryed my hand at paint work. Now i have lots of primer spots and one side panel that looks like a zebra. I am focusing better now. I hope any way. Should order manifold monday or so and other things.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-30-2010, 08:54 PM   #108
68GMCCustom
vendor/product issues....pending results.
Kurt -
Old 06-30-2010, 09:04 PM   #109
85burb
85burb's Avatar
WOW that does blow. Got jacked on price and product. Dont think i would order from them again. Seems to be a patern to me. That is why i try to get most my stuff from big name companys. Has seemed to work good so far for me. I have goten every thing from summit i beleave for my engine. The flywheel and cam will not come from them and i got jacked on flywheel. The cam will prob come from sd.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 07-02-2010, 12:51 PM   #110
68GMCCustom
its here!!!!!!
Kurt -
Old 07-02-2010, 10:12 PM   #111
okieraptor
okieraptor's Avatar
That intake sure is pretty. Makes me want one.
82 chevy longbed(grey truck)first truck when i was 15!
okieraptor is offline   Reply With Quote
Old 07-02-2010, 10:53 PM   #112
85burb
85burb's Avatar
WOW looks great. Cant wait to get my intake. Of course my motor is not that clean. How can i clean it to look close to that?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 07-03-2010, 01:10 PM   #113
68GMCCustom
Well...that motor is brand new.
For a dirty motor....I use Simple Green. Protect what you don't want to get wet, the pre-wet any plastic areas before applying (SG can stain at 100%), saturate the metal areas with simple green, let set...then hose off with high pressure. Really bad spots may take a 2nd application or even a little scrubbing.
Kurt -
Old 07-03-2010, 01:17 PM   #114
68GMCCustom
for a carb'd L92/LS3 headed motor that will see strip use but still needs to be able to drive on the street to get there, I think a dual plane(1500-6500rpm) is a better choice then the single plane(3000-7000rpm)...unless your building a motor for the track use only. I don't plan on turning more then 6500-6600rpm anyway.
Kurt -
Old 07-03-2010, 01:21 PM   #115
85burb
85burb's Avatar
The only prob i have with that is my storage unit that houses my engine does not have water. What can i use to get it clean for paint. The motor is not horrable it is just sandy with light grime on some spots.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 07-03-2010, 02:36 PM   #116
68GMCCustom
Get yourself a couple of rolls of the disposable HD shop towels. Dilute the SG to like 50%, spray on...wipe off. Use wire brush as needed.
You could take some water in a gallon milk jug or two...for final rinse?
Kurt -
Old 07-03-2010, 08:34 PM   #117
85burb
85burb's Avatar
I will try that. Thanks. What cam are you getting?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 07-03-2010, 08:41 PM   #118
MONTEZ
If you want to make it look even more oldschool look at www.mastmotorsports.com. They offer bracket to relocate the coil packs to the rear of the heads and long plug wires. They also offer valve cover that look more like they would belong on a carb engine.
Smoke Tires, not Drugs
MONTEZ is offline   Reply With Quote
Old 07-03-2010, 10:46 PM   #119
85burb
85burb's Avatar
Holy crap did you see the hildorn drive by wire system. Almost fell out of my seat. Almost rethunk my intire build. Sure it is like 98 million bucks.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 07-03-2010, 11:35 PM   #120
68GMCCustom
you mean this?
its cool....so is the Harrop system, tho they had another I can't find:
still knocking around different cams. wanting big...but not too big. Looking at over .600 lift instead of the .566/.568 Comps trying to sell me.
Kurt -
Old 07-04-2010, 01:32 PM   #121
85burb
85burb's Avatar
WOW yes them. They hot. Man if i had that kind of money i would deff go for that. I am still thinking of the GM Hot Cam. Do you think that cam will be good for my combo?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 07-04-2010, 04:05 PM   #122
68GMCCustom
yes...unless you got a custom ground for your app.
Kurt -
Old 07-04-2010, 04:49 PM   #123
85burb
85burb's Avatar
Oh ya happy 4th of july!!!!!!!!!!!!!!!!!!!!!!!!!1
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 07-04-2010, 05:18 PM   #124
68GMCCustom
for sure.....happy 4th!
Kurt -
Old 07-04-2010, 06:56 PM   #125
Cherub
Cherub's Avatar
Originally Posted by 68GMCCustom View Post
its here!!!!!!
MMMM square port
Cherub is offline   Reply With Quote
