Old 11-07-2010, 11:47 PM   #101
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Project -underfunded - '68 shortstep/carb'd LSx/200-4r build
more progress........amongst other things..I put it on the ground to check the stance and it looks great and is even level from side to side I think.
rear wheel cylinders, front 1.25" sway bar, steering gear box (rack and pinion on hold until later date), front suspension and steering bolts torqued, lubed the new front ball joints and LCA's. Thats all I can think of But I'm sure there was more.
pics to follow tomorrow...for now I'm tired and taking a shower then hitting the sack!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-08-2010, 11:35 PM   #102
68GMCCustom
front sway bar mounted:
fuel tank hole needs to be patched:
cleaning up the firewall (should have been done before moving the cab...but you take help when you can get it)
oh...and its on the ground:
and how its sits:
front crossmember at roughly 8.50"
cab height just under 12"
oh...and here's a better shot of the CPP panhard bar mount:
Kurt -
Old 11-09-2010, 11:02 PM   #103
68GMCCustom
budget got another small shot in the arm...getting ready to order pushrods, headers, exhaust, driveshaft, plumbing, etc.
Going to try to finish before thanksgiving...we'll see!
Kurt -
Old 11-10-2010, 12:17 AM   #104
85burb
85burb's Avatar
Good to here. Hope to see running video sooon... What size pushrods does your enging come with factory?
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 11-13-2010, 03:22 AM   #105
kvn1011
Kvn1011
kvn1011's Avatar
nice build!
nice truck!!
subscribed!!!
kvn1011 is offline   Reply With Quote
Old 11-13-2010, 05:30 PM   #106
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Great work buddy! Keep it up.
--Josh
Old 11-13-2010, 08:22 PM   #107
68GMCCustom
thanks guys!
Whose everyone using for driveshafts? Denny's? Inland Empire? I need to have one built for roughly 500-600hp...and don't want to break the bank, but don't want it to take forever either.
I'll spring for the super double throwdown "bling" driveshaft when I'm making 1000hp.
Kurt -
Old 11-15-2010, 11:57 PM   #108
68GMCCustom
Been busy as heck with personal life....but did manage some progress!
I ordered the 7.375" chrome moly pushrods today from Trend and the ceramic coated Dynatech 1 7/8" primary 3" outlet LT headers (for a 2nd gen LSx f-body) from Speedway.
Over the weekend I managed to get the column to steering box link painted and installed, as well as the CPP power booster/master cylinder/prop. valve combo. Seems to hang down though...instead of being more level. I also painted the valve covers and cleaned up the firewall. I'll try to get pics tomorrow.
Kurt -
Old 11-16-2010, 09:31 PM   #109
85burb
85burb's Avatar
Those look great!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 11-17-2010, 12:04 AM   #110
68GMCCustom
Thanks! Got the word they are already on thw way, as are the p-rods. I need to order a drive shaft now....who's got the best for the least?
Kurt -
Old 11-18-2010, 05:17 PM   #111
68GMCCustom
Headers are here and I must say....they are nice! Can't wait to try them on...hopefully they'll fit w/o grinding half the frame away.
Kurt -
Old 11-19-2010, 12:13 AM   #112
68GMCCustom
Headers are in....and they fit! Barely...but they fit w/o cutting or grinding and look great. I wish maybe they were about 3" higher off the ground...but they don't hang down past the oil pan/front control arms.
just out of the box:
installed:
hardware included...even 02 plugs.
am I happy with them? Heck ya! Another thing went well today....got my pushrods in. So I'll be buttoning up the motor best I can this weekend.
Still need to order the driveshaft and some 2.5" exhaust pipe (a buddy gave me some turbo mufflers). Also need to sort out the plumbing and wiring...but its getting closer to running!
Kurt -
Old 11-19-2010, 12:17 AM   #113
VA72C10
VA72C10
VA72C10's Avatar
very nice! And like you said, they don't hang down lower than the oil pan so they're good to go!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-19-2010, 01:56 PM   #114
71cadc10
71cadc10's Avatar
those do look to fit great! Is the 2nd gen Fbody supposed to be the best fit, vs say 1st gen Fbody or Nova ones?
That's a great price too for coated 1 7/8 tubes
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 11-19-2010, 03:04 PM   #115
68GMCCustom
Thanks! Not sure on the 1st gen f-body headers...but I have heard they work. I'd had a set of 2nd gen sbc headers that fit OK...so I felt safer ordering those.
Kurt -
Old 11-19-2010, 04:40 PM   #116
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Read the entire thread today, it's definitely an interesting build! Look forward to hearing this beast come alive for sure!
I couldn't belive the truck was coming apart in the before pictures!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 11-19-2010, 08:28 PM   #117
85burb
85burb's Avatar
Those look great. hope mine fit that well.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 11-21-2010, 01:13 AM   #118
68GMCCustom
more updates....
got my pushrods out....
put them in...
and installed the coil packs (after installing valve covers)
did something to my back (again) today...hope I can keep on schedule for a fire up before months end! still need to order more dang parts....I can only imagine the list if I was doing a 100% rebuild.
Kurt -
Old 11-21-2010, 01:22 AM   #119
85burb
85burb's Avatar
Them valve covers really look great. Everything looks great. So does it matter what order you tighten down the rockers on these motors sence the are nonadjustable any way or do you need to still follow the right order.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 11-21-2010, 01:33 AM   #120
68GMCCustom
Thanks!
not sure....went from the middle out just for the heck of it, trying to make sure the bar underneath the arms didn't bind or something...otherwise just tighten them down to 22ft lbs.
Kurt -
Old 11-21-2010, 01:35 AM   #121
68GMCCustom
also.....I will be upgrading the valve covers when I move the coil packs behind the heads...so what you see now is temporary.
Kurt -
Old 11-21-2010, 01:48 AM   #122
85burb
85burb's Avatar
I will also be moving my coils after a while. My boss at work is putting them on his inner fender i think. But that is on a el camino. Would make for long plug wires on our trucks.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 11-21-2010, 12:57 PM   #123
68GMCCustom
there are adapter that mount to the back of the heads...4 on each head bracket.
Kurt -
Old 11-21-2010, 05:25 PM   #124
85burb
85burb's Avatar
Who sells them. Have seen them at mast but they changed the site up and now i cant find anything.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 11-21-2010, 05:39 PM   #125
68GMCCustom
Mast has a complete kit with MSD wires but its a bit spendy.
I've been thinking of going with these:
http://www.automotivedesigneng.com/p...coil_pack.html
Kurt -
