Old 07-31-2011, 08:29 PM   #101
lowdown72
lowdown72's Avatar
Re: 67 C20 LB Conversion to C10 SB Fleet.
trucks looking great keep up the good work
72 c-10 67 clipped 327 th400
lowdown72 is offline   Reply With Quote
Old 08-07-2011, 12:59 AM   #102
mr.chevy
mr.chevy's Avatar
Thank You!
Originally Posted by 67chevy1series View Post
ok its a deal lol
Did it just for you.
Rolled it Out Today!
Well although not to much looks different I managed to do quite a bit today. I Put the doors back on and then mounted the front clip. I had bought some new hood hinges a while before I bought this truck and decided to use them thinking that I remembered them working well on my old truck. I was wrong. I could not get the hood lined up one bit. It just kept getting worse and worse. So I put the GM ones back on and well you can see the photos of how well it went off. I also rolled the truck out of the garage and the C20 frame into the garage which is pretty hard by your self. I then had to cover up the bare metal from the chop down. The close up photo is of the best seam and has no filler on it. I think it looks good.
PS I sprayed the orange fender with primer, It was to distracting.
Ben
Its a 67 Chevy C10 now, and its short now too.
Here is my 1967 Chevy C10 Shortened Build Blog
http://boyescustoms.blogspot.com
Here is my 1967 Chevy C10 Shortened Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=433535
mr.chevy is offline   Reply With Quote
Old 08-07-2011, 01:01 AM   #103
mr.chevy
mr.chevy's Avatar
here is the ones of the cut seam.
Ben
Old 08-07-2011, 02:15 AM   #104
VA72C10
VA72C10
VA72C10's Avatar
Looking GREAT!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 08-07-2011, 03:06 AM   #105
sodak68
sodak68's Avatar
When I started reading this I thought it was this truck http://cgi.ebay.com/ebaymotors/1967-...item19c79f67ec .
sodak68 is offline   Reply With Quote
Old 08-07-2011, 04:34 AM   #106
67chevy1series
67chevy1series's Avatar
wow really awesome! yours 67s better then mine lol
67chevy1series is offline   Reply With Quote
Old 08-08-2011, 06:55 PM   #107
mr.chevy
mr.chevy's Avatar
Originally Posted by VA72C10 View Post
Looking GREAT!!!
Thank-you
Wow that was uncanny! Seems just like mine.
Thanks, and while I do like mine, I don't think its better than yours.
Ben
Old 08-17-2011, 02:03 AM   #108
67chevy1series
you think so? i dont see it your body is clean!
Old 08-17-2011, 10:57 AM   #109
mr.chevy
mr.chevy's Avatar
Yeah I did luck out with a pretty clean body but the camera hides a lot of stuff. You would be surprised.
Ben
Old 08-18-2011, 03:21 AM   #110
71Sleeper
71Sleeper's Avatar
Your build is coming along nicely....Is that a 4 speed tranny your running?
71Sleeper is offline   Reply With Quote
Old 08-18-2011, 06:13 AM   #111
heeroyue2002
fat old dude
heeroyue2002's Avatar
its coming along nice
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 08-18-2011, 11:06 AM   #112
mr.chevy
mr.chevy's Avatar
Thanks, Yeah its a new process 833 If I remember right, with an overdrive. Should make it drive nicer than the stock LOW gear trans.
Thanks.
Ben
Old 08-18-2011, 06:51 PM   #113
67chevy1series
really? wow i never would have thought...
Old 08-19-2011, 01:31 AM   #114
71Sleeper
71Sleeper's Avatar
[QUOTE=mr.chevy;4851708]Thanks, Yeah its a new process 833 If I remember right, with an overdrive. Should make it drive nicer than the stock LOW gear trans.
Thanks, I am wanting to change my 3 speed out too. What did you get the tranny out of?
Old 08-19-2011, 02:03 AM   #115
mr.chevy
mr.chevy's Avatar
Thanks, I am wanting to change my 3 speed out too. What did you get the tranny out of?[/QUOTE]
No Problem. Actually I believe it came out of an early 80s 2 wheel drive Chevy Diesel. When I got it on a local classified ad it was already out. The problem with these transmissions are that they have a special bell housing. So if you get one then you need to make sure the bell housing is coming with it. I had to hunt for months for mine. Really its a lot like a muscle car trans. Also if you set out looking for one the steel case is the one that you want. Not the aluminum one. The steel one I guess is really tough but not the aluminum one. I would just do a Google search on it see what you can find. The Price was right, I believe including the bell housing I am into mine 150 Bucks, and that's not bad.
Did a search and found the article I read before I bought mine
http://www.classicjunkyard.com/new_process_a833.htm
Ben
Old 08-19-2011, 10:46 AM   #116
FrankieD
FrankieD's Avatar
I was putting the truck 4 sp back in mine now I see this and my mind is changing so I Googled the 833 and found this very intersting read, you will see why you won't brake it go to this section
Strength Considerations
http://www.slantsix.org/articles/4-s...fourspeed1.htm
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 08-25-2011, 01:30 AM   #117
mr.chevy
mr.chevy's Avatar
Yeah I knew it was strong. That's cool. didn't know all that though.
Ben
Old 08-25-2011, 01:50 AM   #118
Chop Top Ford
Clean welds and it looks original. Kudos on not butchering it. You do nice work man!
'67 C-10 Longbed (DD-Work in Progress)
'28 Ford Model A Tudor (My 2nd Wife)
'07 Yamaha R6s (Full Custom)
'03 Chevy Express 2500 (Tow Vehicle)
Chop Top Ford is offline   Reply With Quote
Old 08-25-2011, 09:43 AM   #119
71Sleeper
71Sleeper's Avatar
http://www.classicjunkyard.com/new_process_a833.htm[/QUOTE]
Thanks for the info. I will be starting my search. Sounds like the way to go.
Old 09-10-2011, 08:47 AM   #120
REEDS 72
REEDS 72's Avatar
Looking real good cant wate to see the outcome cool old trucks
REEDS 72 is offline   Reply With Quote
Old 09-24-2011, 08:43 AM   #121
RCbowtie69
RCbowtie69's Avatar
Looking good,keep on truckin'
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 10-01-2011, 05:41 PM   #122
mr.chevy
mr.chevy's Avatar
Thanks everyone for your comments and compliments. So this is when I say I have done nothing this last month or so. But the good news is that I cleaned up my shop, that always gets me excited. I need to get the other frame cut down so i can get the rest of the body in the shop for the winter and start working.
Thanks again.
Ben
Old 10-03-2011, 03:03 AM   #123
71Sleeper
71Sleeper's Avatar
Need to hurry...winter is almost here...
Old 10-03-2011, 05:31 PM   #124
mr.chevy
mr.chevy's Avatar
I know! Seriously coming fast too. And I went and got sick. Bleh!
Ben
Old 10-04-2011, 12:57 AM   #125
71Sleeper
71Sleeper's Avatar
Just pop a few pills and get back to it! I know you can! I don't want the next post I read saying something like this "Well guys I didn't get the shop cleaned out enough to bring my truck inside for winter and now it is covered up by all the snow". LOL
1967, c10, c20, conversion, shortbed
