Old 04-30-2011, 02:02 PM   #101
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: intro + 66 black bagged long fleet
Nice looking truck keep up the good work..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-01-2011, 08:06 PM   #102
coda13
your truck owns! very nice work.
coda13 is offline   Reply With Quote
Old 05-01-2011, 08:56 PM   #103
c10Mang
c10Mang's Avatar
Just found this build.. Looks great so far!! Can't wait to see it done
c10Mang is offline   Reply With Quote
Old 05-01-2011, 09:52 PM   #104
coulter
coulter's Avatar
thanx man!!! ur truck is a beauty!!!
i got a little bit more done
started working on my fenderwells
still gotta make the end caps then finish welding and start smoothing
put the motor in for a test fit.. everything fit great except the drivers side header is just a tad low so im gonna cut it down a lil
mmmm look at this nasty silicone disaster!!!! lol
btw the mounts are just a tubular mount kit i found on ebay.. came with the tranny crossmember to. i bolted them to the forward holes and everything looks like its gonna clear good
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 05-01-2011, 11:16 PM   #105
FRENCHBLUE72
PROJECT 7DEUCE
Im thinking you may wanna keep your eye open for a set of finned or at least some nicer valve covers. With those headers and the rest of the work you have done the valve covers just look out of place. Just my.0321 cents worth.
MEMBER #6377
Project "7DEUCE"
Old 05-02-2011, 12:03 AM   #106
coulter
coulter's Avatar
ya i bought those just for temporary cause they were cheap... but they got dented up when the motor fell of the engine stand... i just ordered these
Old 05-02-2011, 11:10 AM   #107
coulter
coulter's Avatar
was pretty lazy yesterday so i didnt get much done
pulled the heads off to check it out..
i took a better pic of the mounts
it was too late last night to start cutting and grinding but i did go ahead and get my lines drawn for where im gonna cut my rear tubs
this crappy rainy weather makes it hard to get motivated to work
Old 05-02-2011, 09:53 PM   #108
chad64chevy
chad64chevy's Avatar
ya, i know what you mine about the weather, i'm a lil south of you!! nice work so far!! i got some rear wheelwells you can have to make those front wheelwells!!
chad64chevy is offline   Reply With Quote
Old 05-02-2011, 10:01 PM   #109
FRENCHBLUE72
PROJECT 7DEUCE
Those finned covers are gonna look *****en..
MEMBER #6377
Project "7DEUCE"
Old 05-02-2011, 10:46 PM   #110
DRTYRAT30
Jesse
DRTYRAT30's Avatar
I havent checked in on your build in a while. Your a wild man, its looking bad a$$ bro. you have a great vision and the skills to make it happen. Oh and i love those XS's also...
Jesse
DRTYRAT30 is offline   Reply With Quote
Old 05-03-2011, 08:05 AM   #111
coulter
coulter's Avatar
ya i should have just bought those in the first place instead of being a cheap ass...lol pretty sure im gonna get the matching air cleaner to
Jesse
thanx man ur truck has been pretty inspirational in this build along with alot of other badass rides on here!!!
im really glad i found this site!!! its been a big help
Old 05-05-2011, 03:23 AM   #112
coulter
coulter's Avatar
got some new goodies
lokar 23 inch double bend
shiney alt bracket
cpp sway bar kit
finned vc's from the bay
universal 26x19 aluminum rad
getting an idea for mounting
Old 05-05-2011, 02:42 PM   #113
SulphuriousSam
SulphuriousSam's Avatar
Just wanted to say I've been watching your build and it's coming together into one sick ride. I hope you take it to a show nearby so I can see it up close when you're done!
1966 C10 LWB, 283, 3 on the tree (lots of work to do!) http://67-72chevytrucks.com/vboard/s...d.php?t=471348
2001 Suburban daily driver
2008 HHR (wife's ride)
SulphuriousSam is offline   Reply With Quote
Old 05-05-2011, 03:00 PM   #114
coulter
coulter's Avatar
o ya u know it!!! im im shooting to have it driveable by the end of july (hopefully) im gonna try to make it to as many as i can that arent too far away... dont wanna take a super long trip in it till i make sure i got all the bugs worked out
Old 05-05-2011, 03:55 PM   #115
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
shiney alt bracket
cpp sway bar kit
Were dis you.get the rad from
Sick5 is offline   Reply With Quote
Old 05-05-2011, 06:46 PM   #116
FRENCHBLUE72
PROJECT 7DEUCE
Nice new shiny parts...
MEMBER #6377
Project "7DEUCE"
Old 05-05-2011, 08:10 PM   #117
coulter
coulter's Avatar
here u go sick5 http://stores.ebay.com/KMJ-PERFORMAN...=p4634.c0.m322
Old 05-05-2011, 11:42 PM   #118
redneck6
bad ass truck man , looks sick as all hell , got a ? for you and the masses , if you sectioned ur cross member and or a small z of the frame would it lay rocker in the from ??
64 chevy c10 swb fleet small back window , in progress 454/400 swap , disc front disc rear , and just geting it on the road .
09 ford f350 cc swb 4x4 6.4l , to haul the others home .
2011 chevy hhr not mine but love the milage ..
redneck6 is offline   Reply With Quote
Old 05-05-2011, 11:53 PM   #119
coulter
coulter's Avatar
ya my frame is about 2 inches off the ground with 2.5 drop spindles and sitting on lower control arms.. so it wouldnt take a huge z with drop spindles.. i think most people do a 3 inch z..
Old 05-06-2011, 11:12 AM   #120
creep
Registered Loser
creep's Avatar
With the frame flat on the ground the pinchwelds on mine are about 1/8"-1/4" from the ground. That is with brand new urethane body mount bushings, older broken in rubber bushings may get you closer if not touching.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 05-08-2011, 05:02 AM   #121
coulter
coulter's Avatar
got the rear tubs trimmed down today
Old 05-09-2011, 12:29 AM   #122
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Awesome work!! I'm really diggin' it!!
Alan's Classic is offline   Reply With Quote
Old 05-09-2011, 01:37 AM   #123
Slammed66
Needs a Big Block
Slammed66's Avatar
Sick dude, looks awsome!!!
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 05-09-2011, 11:05 AM   #124
66redw/white
made in america
66redw/white's Avatar
nice truck man! i need to bag mine bad. you do some sweet work.
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes.
sounds good
1964 c10-283 powerpack, 3 on the tree
2004 corvette- lowered, borla, tuned. slow
my old girl
1966 c10- 305v8, t-5 sold
66redw/white is offline   Reply With Quote
Old 05-10-2011, 12:07 PM   #125
low 90
nice truck for sure! if you dont mind me asking where did you get the motor mounts from?
low 90 is offline   Reply With Quote
