Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 08-07-2012, 09:32 AM   #101
PD1292
PD1292's Avatar
Re: 72Jimmy 1st attempt at rust removal
I took the rest of the stuff off and out of the dash and off the firewall so i could blast and then prime the firewall dash and the windshield frame. All looked pretty good.
PD1292 is offline   Reply With Quote
Old 08-08-2012, 12:54 AM   #102
PD1292
PD1292's Avatar
e primed under the dash, windshield frame, and fire wall as well as the front floors. Also the girls picked a color today, and i painted the hump to see if it was too dark. I think it will be good.. on to the pics
Old 08-08-2012, 12:56 AM   #103
PD1292
PD1292's Avatar
also primed and painted all the under dash stuff black
Old 08-26-2012, 08:11 AM   #104
PD1292
PD1292's Avatar
The PO as I said before had not taken very good care of this truck. There was a hole dented into the side just behind the drivers side door, and a hole for the trim as well. i was just going to weld it up but I had the original door skin left from the drivers side door so i cut a patch out of it and put it in place of the damaged parts.
Old 08-26-2012, 08:15 AM   #105
PD1292
PD1292's Avatar
I had already used the stud welder to pull all the long dents down the side of the drivers side so i sanded it all down to bare metal did some body work and then e-primed and high build primed it. this is after some block sanding.
Old 08-26-2012, 08:24 AM   #106
PD1292
PD1292's Avatar
I also finally got the back bumper to release. PO had built and welded a bumper to the frame. I think i want a chrome one to match the front so I cut it off. WOW what a chore. I liked the bumper because it had a receiver welded into it so i could tow stuff but it was not the best looking thing. If i dont get a chrome one right away I marked where the frame holes were so i could put some holes in the mounts and bolt it up instead of welding it.
Old 08-26-2012, 08:30 AM   #107
PD1292
PD1292's Avatar
I also lifted the body off the frame, pulled it up to the front garage and then put the other frame I found off of a farm and put it under the body. This will be better as the other frame does not have anything in it and will allow access to the underside, and front (no engine in the way) also it can roll around easily. I am going to try and paint in the front garage and have to take it around an entire block to get there, so the wheels and tires on the back will help for stabilization.
Old 08-26-2012, 08:56 AM   #108
PD1292
PD1292's Avatar
I got some parts in the other day as well. This is one of them. It was just the bezel and i took the best parts out of several others I had to make one good one.
Old 08-26-2012, 09:02 AM   #109
PD1292
PD1292's Avatar
I had taken some of the body mounts loose to work on the body work on the passenger side and drove it around a bit before i took it apart so much i could not drive it. I found out what was banging so loudly. A frame mount had been broken off the frame. Ill just cut the rivits off of the other frame and bolt it to this one.
Old 08-27-2012, 09:03 AM   #110
bambbrose
Instrument cluster looks amazing. Great work cleaning it up
bambbrose is offline   Reply With Quote
Old 08-27-2012, 10:55 AM   #111
PD1292
PD1292's Avatar
Thanks, I have a lot of other parts as well that came in, but they area all boxed up and have not taken a picture of them yet. Trying to get this thing ready for paint
Old 08-27-2012, 11:39 AM   #112
thor
thor's Avatar
You'll be ready for paint in no time. Nice work.
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 08-27-2012, 11:56 AM   #113
PD1292
PD1292's Avatar
I am beginning to wonder. just when i think i am close, i find another part that needs some attention. I dont want to rush it but I am tempted to paint.
Old 09-04-2012, 11:07 AM   #114
PD1292
PD1292's Avatar
I decided to do some internal frame coating from Eastwood. I ordered their gun as well, because it had the long extention tubes.
You can see that it ran out of the rocker panel after and during the spraying.
Old 09-04-2012, 11:09 AM   #115
PD1292
PD1292's Avatar
The nozzle with all the holes is the one I used. I was pleased with it. thought it would just spray out streams of the stuff but it sprayed in a mist. Very good coverage, i hope!!
Old 09-04-2012, 11:11 AM   #116
PD1292
PD1292's Avatar
I coated the rockers and the windshield frame. It leaves a waxy substance after about a few hours, and I dont know what it will do after it dries. Hopefully I will remember to update as to what it does
Old 09-04-2012, 11:14 AM   #117
PD1292
PD1292's Avatar
I also sanded and then sandblasted the front fenders, and the rear wheelhouses.
Old 09-04-2012, 11:19 AM   #118
PD1292
PD1292's Avatar
Then yesterday I did the body work and primed the fenders and the wheel houses. Epoxy prime and then high build.
Also made a tow bar type thing that bolts to the radiator mounting positions and rests on the first cross member and allows for towing the frame around. I needed this because there are no front springs due to some one stealing them from the alley... lovely!!.
Old 11-12-2012, 12:48 PM   #119
PD1292
PD1292's Avatar
Finally getting some color. I picked another color, and base coat/clear coat paint. Here are some pictures. some before and after..
Old 11-12-2012, 01:01 PM   #120
fxdxharley
Just a nother gear head
fxdxharley's Avatar
that blue is awsome! great choice. what color is it? looks close to the color of my harley.
2013 HD FLHX
2000 chevy 2500 6.0l 4x4 3dr
2000 harley fxdx
71 Jimmy 4x4- future crawler/ woods rig
71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589
fxdxharley is offline   Reply With Quote
Old 11-12-2012, 01:37 PM   #121
PD1292
PD1292's Avatar
Its called luxo blue, zenon blue or heritage blue. I found it on a 2013 GMC Z71 truck at the dealership.
Old 11-12-2012, 06:49 PM   #122
99-LS1-SS
99-LS1-SS's Avatar
Nice blue. What color are you going to paint the top?
My 1972 2WD Blazer build
1984 K10 beater truck
99-LS1-SS is offline   Reply With Quote
Old 11-12-2012, 09:21 PM   #123
PD1292
PD1292's Avatar
Yes I like this color much better. More Dimension than the single stage blue I had picked before. Dont know what color to paint the top. I like white but my wife says it makes it look like old truck. Possibly black or the blue. I just think the dark color on the top will make it really hot in the summer... Barry
Old 11-13-2012, 10:21 AM   #124
Wasted Income
Boosted Member
Wasted Income's Avatar
Looking good!
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-25-2013, 09:20 AM   #125
Low Elco
WOW, that came out nice! Have you gotten any more done? Great work!
Low Elco is offline   Reply With Quote
