Old 10-29-2011, 06:11 PM   #101
FLcustom10
Re: Slowly I build a truck
Locking in the steering column, and a quick reminder of how far it's come.
FLcustom10 is offline   Reply With Quote
Old 10-29-2011, 06:33 PM   #102
dmwphoto
dmwphoto's Avatar
nice work man
dmwphoto is offline   Reply With Quote
Old 10-29-2011, 08:05 PM   #103
VA72C10
VA72C10
VA72C10's Avatar
Looks great!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-29-2011, 09:33 PM   #104
PHAT TONY
PHAT TONY's Avatar
When somebody says "nice truck", you can certainly take pride in saying "Thanks; it was Dads and I rebuilt it"! Really good and thorough work; looks awsome.
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 10-30-2011, 07:54 PM   #105
FLcustom10
Thanks guys!
Starting on the engine. It's a 307, but it was running fine when I parked it.
I got this intake manifold for $50.00 and had it bead blasted. He said he was sure it was clean, but I blew it out again with compressed air when I got home just to be sure there weren't any stray beads left inside.
Old 10-30-2011, 07:58 PM   #106
FLcustom10
New intake manifold installed:
Old 10-30-2011, 08:03 PM   #107
FLcustom10
New Holley carb, valve covers, and getting ready for motor mounts:
Old 10-30-2011, 08:11 PM   #108
FLcustom10
New motor mounts: I tried to just jack the engine up to replace the mount, but I could not get it to line up with the brace. I wound up having to take the brace off, attach that to the motor mount, then attach the entire thing back to the frame.
Old 11-06-2011, 10:51 PM   #109
FLcustom10
Thanks to LockDoc for supplying the missing pieces to my steering column.
Old 11-06-2011, 10:52 PM   #110
FLcustom10
Starter cleaned up and installed:
Old 11-06-2011, 11:03 PM   #111
FLcustom10
I was beginning to question whether this heater box would attach, but I heated up the rubber seal with a heat gun and put some weight into it and it went on OK.
Old 11-06-2011, 11:13 PM   #112
FLcustom10
Painless Wiring Maxi Fuse and alternator wiring:
Old 11-06-2011, 11:15 PM   #113
FLcustom10
Routing spark plugs:
Old 11-06-2011, 11:23 PM   #114
67cheby
67cheby
67cheby's Avatar
super nice/ clean work
67cheby is offline   Reply With Quote
Old 11-06-2011, 11:34 PM   #115
fakerwade
fakerwade's Avatar
very nice work!
Wade
JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!!
Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570
Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro
fakerwade is offline   Reply With Quote
Old 11-07-2011, 01:20 PM   #116
just samples
Where do you buy most of your parts? could you give a some good websites, i know LMC, Summit, Classic industries.
just samples is offline   Reply With Quote
Old 11-07-2011, 02:34 PM   #117
oldman3
oldman3's Avatar
Everything looking super nice....Jim
oldman3 is offline   Reply With Quote
Old 11-07-2011, 02:37 PM   #118
FLcustom10
Thanks guys!
I try to buy as much as I can at the swap meets. I go to the Moultrie Ga
swap meet in November or February:
http://www.moultrieswapmeet.com/
I always look for Tim Christian or Top Banana.
www.topbananaparts.com
I get alot of it from E-bay.
I'm so frequent at O'Reily's auto parts on the corner that they tell me they missed me if I don't show up for one of the weekend days. Pep Boys or Advance Auto or Carquest will have things that O'Reily's doesn't so I try not to lock myself into one store. I've had to learn the same thing with Lowes and Home Depot.
Wes at www.classicheartbeat.com is always helpful.
I've bought from vendors on the site and from the parts board.
Summit Racing http://www.summitracing.com/ is one of my favorite places to order from because they usually charge a flat $9.95 handling fee instead of shipping and it arrives Fedex the next day.
Jegs www.jegs.com
www.manestruckparts.com
www.lmctrucks.com
www.brotherstrucks.com
www.inlinetube.com
www.stockinteriors.com
www.truckandcarshop.com
www.classicindustries.com
I'm sure I'm missing some. I try not to focus on what it's costing. I know I could have bought a truck that's already restored for what I'm spending, but this is a once in a lifetime experience, and I'm learning so much.
Old 11-13-2011, 09:47 PM   #119
FLcustom10
I bought a distributor tune-up kit, but I wound up breaking a bolt while trying to remove the weights and center-plate, so I had to buy a new distributor. I think it's for the best. It was educational to learn about the module and advance curve kit, but it was an expensive lesson.
Old 11-13-2011, 10:20 PM   #120
FLcustom10
I was having a hard time figuring out how to hook up the throttle linkage and kick-down cable. I finally went with this bracket from Summit Racing:
http://www.summitracing.com/parts/SPE-24283/
At first I couldn't make a Holley connector fit through the slot on the kick-down cable, so I tried a screw and nut, but that didn't work well so I used a dremel tool to make the connector a little bit smaller and then forced it through with some pliers.
Old 11-13-2011, 10:25 PM   #121
Hollywood Knight
Junior Member
Hollywood Knight's Avatar
Very nice and great detail
Hollywood Knight is offline   Reply With Quote
Old 11-13-2011, 10:51 PM   #122
FLcustom10
I took the gas tank to a radiator shop to be cleaned and I polished the outside some.
Old 11-13-2011, 10:56 PM   #123
FLcustom10
New filler neck grommet thanks to Wes at Classic Heartbeat. New sending unit.:
Old 11-13-2011, 10:58 PM   #124
67cheby
67cheby
67cheby's Avatar
looking great !! keep up the good progress
Old 11-14-2011, 10:19 AM   #125
oldman3
oldman3's Avatar
Nice job....Jim
