Old 10-16-2011, 02:39 AM   #101
litew8
litew8's Avatar
Re: Project "My Happy Mess"
Installing the intake -
Tackeling the (front) frame before dropping the block/transmission (after lines).
Proper breathing apparatus and ventilation used and recommended.
Coat 1 complete, moving onto the 2nd coating -
Finished. Will hit the underside with rubber in a can before engine/transmission.
Real quick...
Pan/transmission before -
After -
First coat Zero Rust Red for oil pan (second coat will be a black of a different product) -
Cast
south side!
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 10-16-2011, 07:45 AM   #102
oldman3
oldman3's Avatar
Looks like you've been busy, nice.....Jim
oldman3 is offline   Reply With Quote
Old 10-16-2011, 09:08 AM   #103
99-LS1-SS
99-LS1-SS's Avatar
You're making good progress. I wish I was moving along like you are. The sandblasting was the way to go.
99-LS1-SS is offline   Reply With Quote
Old 10-16-2011, 05:54 PM   #104
litew8
litew8's Avatar
Thank you.
The experience gained growing up wrenching on cars/engines helped put things into better perspective/execution for a first restore. Sand blasting def. cost me, but now as I undercoat I can see the payoff
So far today, I've undercoated (zero rust) the rest of the underside. In an hour, I'll be spraying under body rubber/liner to top it off for good.
Old 10-17-2011, 03:42 PM   #105
litew8
litew8's Avatar
Undercoated
Weekend update -
Got the oil pan and tranny pan painted. Used bed liner.
It filled in the pits on the oil pan nicely, looks new now.
Here's the brand shock I'm using. Monroe Reflex.
Finished spraying the underside with rubber/liner.
This is not the same liner I used for the oil/tranny pans,
and looks A LOT better in person.
Recap: underside has primer, 2 coats Zero Rust and a thick layer of bed liner!
If this doesn't extend its life, I don't know what would.
Sweet!
Have some touch-ups to do with the liner still.
Otherwise, the brake/tranny lines should arrive tonight.
Get those in, then we can place the engine/tranny.
Once this hurdle has been jumped, on to the sheet metal...
Thanks for looking all!
Old 10-17-2011, 04:17 PM   #106
VA72C10
VA72C10
VA72C10's Avatar
Looks good!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-17-2011, 04:21 PM   #107
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice progress and it's looking great!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 10-17-2011, 04:45 PM   #108
oldman3
oldman3's Avatar
Looks good....Jim
Old 10-17-2011, 07:18 PM   #109
litew8
litew8's Avatar
I've already been offered a 70 (?) Nova trade (while the truck is disassembled). lol
Old 10-18-2011, 09:35 PM   #110
litew8
litew8's Avatar
Got brake/transmission lines. Finished undercoating the cab. Picked up my cleaned (blasted) parts.
Old 10-21-2011, 04:23 PM   #111
litew8
litew8's Avatar
Been a great afternoon w/good weather here.
Got things painted and put together. Ran into an issue where my water pump doesn't mount due to it hitting the timing chain cover. :/ wth
Old 10-21-2011, 08:37 PM   #112
bollybib
bollybib's Avatar
Originally Posted by litew8 View Post
I need a sound off of people still following this thread.
Just so everyone knows, my project name "my happy mess" was ripped from an internet race horse naming site that generated different names. I thought it was fitting because 1) I had bought the truck from a girl that raised horses and 2) I want it to go fast and 3) It's a mess!
Update pics coming up.
I've been following. I should post now and again to say so tho. I enjoy watching your engine build a lot cuz I've never done one..,some day I hope. Nice work.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 10-21-2011, 10:55 PM   #113
VA72C10
VA72C10
VA72C10's Avatar
Looks great! I've heard issues with mounting a short water pump with a billet timing chain cover. I've seen guys grind down the nuts on the back of the water pump for it to fit. The only other options is going back to the steel cover or a chrome one.....or going with a long water pump but that means different pulleys/brackets...
Old 10-22-2011, 03:14 AM   #114
litew8
litew8's Avatar
Thanks! Glad the info can be useful to others. Thank you for looking, feedback welcome good or bad.
@va Don't have the old to compare, given as core exchange. Before taking drastic measures, we decided to replaced bolts on the back plate with round head screws and it fit like a glove. Then we find out that the original (1991 gm goodwrench crate engine), freshly painted, pulley bolt pattern is LARGER than that of the water-pump's mount.
More pics later. Lesson learned and note to self - always compare (first) pulley with water pump pulley mount before purchase.
Old 10-22-2011, 04:05 AM   #115
litew8
litew8's Avatar
I think I need this type with a universal bolt pattern for the mount where there's a set of holes in a larger diameter. Maybe my 91' engine is a GenII?
http://info.rockauto.com/getimage/ge...TFW43106-1.jpg
Old 10-22-2011, 04:28 AM   #116
litew8
litew8's Avatar
Sure enough...
Old 10-22-2011, 11:21 AM   #117
Dieselwrencher
At least it's an easy fix. Swap your round head bolts in the new pump and install the new pump. I've had to take a grinder and grind down the back plate on the water pump before to get them to fit. Your truck is looking awesome! I love the look of your heads. Saweet!
Ryan
Old 10-22-2011, 04:18 PM   #118
litew8
litew8's Avatar
Thanks Ryan. I've already got it taken care of (as of 1/2 hour ago). Used the bolts that came with the ARP kit for the pump. Went and bought some others for the pulley. I should have referenced the 91' crate engine when purchasing the water pump. Got the right one this morning and installed. This one come closer to mounting without having to switch out the back plate bolts. It's a very tight/snug fit and the top back plate bots smash into the timing chain cover slightly, but are unnoticeable. Next thing to not fit right - the wire loom kit (arrives mid week). Watch and see, some dumb reason and they won't work with stock exhaust manifolds mounted, even though all the desc. mentions is 1955 to date.
Pics later.
Old 10-22-2011, 04:36 PM   #119
oldman3
oldman3's Avatar
Isn't it fun working on these old trucks, look at all the chances we get to change things...Jim
Old 10-22-2011, 08:35 PM   #120
litew8
litew8's Avatar
Old 10-23-2011, 03:21 AM   #121
litew8
litew8's Avatar
A quick fyi comment - I'm pretty certain my 91' crate engine was sold as a direct replacement for the original 71' engine (trucks). Which is why the majority of my accessory parts resemble the originals.
Old 10-23-2011, 03:31 AM   #122
litew8
litew8's Avatar
Prior pics
Old 10-23-2011, 11:21 AM   #123
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
looking pretty good man
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 10-23-2011, 12:56 PM   #124
litew8
litew8's Avatar
Put some calyx on the master cylinder, prob. should have just painted it or left it patina look much like the upper portion of the firewall will remain. Some small areas on the engine may need touched up w/paint. Notice, the alt. bracket isn't on right - I didn't do it. Almost certain now the plug wire looms in route aren't going to work. And the clearance from the exhaust manifolds to the heads better not cause any grief with fitting the valve covers (also in route)
Old 10-23-2011, 02:31 PM   #125
JDeere550
JDeere550's Avatar
hey this is a nice build, that engine is a bute. i havent read much but i look at the pictures ! and i was just wonderin why you didnt put headers on more over the exhaust manifolds, just keeping an original look to 'er?
1970 C/20 4x4, 350, sm465, np205(She tipped over... total rebuild from the frame up!)
ya gotta keep on keepin' on,
Life's a garden, dig it!
JDeere550 is offline   Reply With Quote
