Old 08-16-2012, 05:47 PM   #101
MTCHEVY
MTCHEVY's Avatar
Re: Any pictures of Stepsides with Coys C5?
sub
-M.J.
1968 Stepside
MTCHEVY is offline   Reply With Quote
Old 11-25-2012, 10:48 AM   #102
darkhorse970
darkhorse970's Avatar
Dragging this discussion back up for some opinions...my current setup is '68 stepside, 4.5/6 ECE drop, early (narrower) rearend converted to 5 lug, no tubbing or major trimming on rear fender lip. I want to run either 17x9.5 or 18x9.5 wheels on the rear *(275-285 wide tire)...so will 4.5 BS be enough?
To add another wrinkle to this equation, I'd like to be able to swap these wheels onto my '63 short fleet (w/ 4/6 drop & narrow 5 lug rearend setup).
BTW, 68stepbed, I really like the stance and overall look of your truck! its been one of my major influences to keep the '68 as a stepper.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 11-25-2012, 12:40 PM   #103
68Stepbed
68Stepbed's Avatar
First off, I want to say Thank You!
Second, from the figuring I did, 4.25" bs would be optimal for a 9.5" wheel with the narrower rearends.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 04-14-2013, 01:58 AM   #104
RdoubleU
RdoubleU's Avatar
Just wanted to finally give an update to my wheel choice and specs
Thanks to all the help and discussion on this thread I was able to research, learn, and correctly measure for my wheels and they fit great. I have about .5" of even clearance on each side of my rear tire inside the stock fender and bedside, may try to go with a hair wider tire when the time comes but no complaints as it and no rubbing front or rear
I went with AR Salt Flats with Toyo Proxes ST II's and added my specs to the summary sheet (Coys were out stock of the Matte version and had no clear timeline of when they would get another shipment at the time)
Also wanted to give a big thanks to Travis here on the board with Pro Performance he was also a big help and worked with me alot on picking out the right style wheels
'68 SWB Stepside - Inline Long Six 250 C.I. (LS250): http://67-72chevytrucks.com/vboard/s...ferrerid=83901
RdoubleU is offline   Reply With Quote
Old 04-14-2013, 02:09 AM   #105
SCHRUMGMC
SCHRUMGMC's Avatar
What type of Wheels, are on that Truck ?
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 04-14-2013, 02:19 AM   #106
RdoubleU
RdoubleU's Avatar
American Racing Slat Flats
Old 04-14-2013, 02:21 AM   #107
SCHRUMGMC
SCHRUMGMC's Avatar
Oh alright, I had never seen them before..Nice truck
1971 GMC Sierra
1959 GMC 100
Old 08-11-2014, 08:52 PM   #108
David121582
Good collection of info thx guys
David121582 is offline   Reply With Quote
