Old 06-14-2013, 07:05 PM   #101
Johnnyfever
Re: 1970 Project Build
I stopped by the local NAPA this morning (which is in a store that's at least 100 years old) to pick up new bumper bolts for my new bumper which was another great deal from auto metal direct. While there I picked up a box of 15 alignment shims and they are probably from the 1950's. This box is old. As soon as I made it back I had to assemble the interior. I like the new creature comfort look and feel. Integrated cup holders in the center seat, fold down console, and integrated seat belts all make it feel like a new truck. Not to mention how comfortable the seats out of late model (1999-2006) chevys are.
Johnnyfever is offline   Reply With Quote
Old 08-17-2013, 09:20 PM   #102
Johnnyfever
Ok, it's been a while since I've been here. I took a month and a half away from the truck. Decided to try something that not too many people have tried. Modifying an S10 tilt steering column to fit. I'm not 100% sure this will work, but I'm trying to make it work. I plan on shaving the key hole since I think it belongs on the dash in these trucks. That means losing the steering wheel lock and a few other things in the column. First was to remove the flange where it attached to the junkyard donor truck floor and then start dis assembly.
Yes, it's a Short Wheel Base, not a Short Wide Bed.
Old 08-17-2013, 09:22 PM   #103
Johnnyfever
A little more dis assembly and a few parts that need to be tossed. Just the key hole part and the steering lock pin.
Old 08-17-2013, 09:26 PM   #104
Johnnyfever
And on to the process of shaving the key hole. First I removed the key hole lip with a hack saw. Then sanded it down smooth, filled it with a scrap piece of sheet metal steel cut to fit, and then the JB Weld. The next step was Rage Gold. This project might be a little strange, but I wanted to give it a try.
Old 08-17-2013, 09:28 PM   #105
Johnnyfever
Then I smoothed it all out, primed it, and next is the coat of semi-gloss.
Old 08-17-2013, 09:29 PM   #106
Johnnyfever
I almost forgot that I received my billet radio plate from mahanian. Looks great. My dash is already cut in strange places around the radio knob holes so this will dress it up nicely.
Old 09-27-2013, 10:29 PM   #107
Johnnyfever
Purist don't look! I didn't modify the truck only the column. S-10 column installed and I'll be installing the power steering pump/box tomorrow - of course football will get in the way at some point, but we all have our priorities. The column modification and install was pretty simple and I like the look, especially with the ignition key shaved.
Old 09-28-2013, 08:51 PM   #108
bonnieclyde100
what year s-10 did it come from?
bonnieclyde100 is offline   Reply With Quote
Old 09-28-2013, 10:35 PM   #109
Johnnyfever
It's out of a '92, but all of them are pretty much the same. The full size trucks from that era are all the same too, but may be slightly longer, but I'm not 100% sure.
Old 09-28-2013, 10:38 PM   #110
Johnnyfever
I installed the power steering box today and took the rest of the bed apart. Now I have to hammer the bed floor and bed wheel wells out and get started on the bed body work.
Old 09-29-2013, 01:00 AM   #111
67c10rustbuket
67c10rustbuket's Avatar
I dig the column swap. Nice!
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 10-12-2013, 09:43 PM   #112
Johnnyfever
Today I picked up an intermediate shaft from a 1997 tahoe since the old 1970 and 1972 parts wouldn't work. I used the entire setup, splines connection, rag joint, and all......bolted right to the 1972 steering box, into the 1992 S10 steering column, and works like a charm. Tomorrow I'm hooking up the pump and testing this thing out.
Old 10-13-2013, 12:16 AM   #113
bonnieclyde100
thats cool i cant wait to see if it works. how does the column length compare to your original ? will the steering wheel be the same distance from you or is there more room between you and it?
Old 10-13-2013, 04:08 PM   #114
Johnnyfever
It's all in and done and I took if for a 2 mile ride - with POWER STEERING! It shifts into gears better than ever with the S10 column. The tilt makes it much nicer getting in and out. The only issue that I see with using the S10 column is those trucks are made with the seating much lower in the cab of the pickup and the extra clearance gained when raising my steering all of the way up from "drive" position is about 3" - 3.5". This works great for me, but it's not as much clearance as the original tilts. I like my upgrade more, but hey, it's MINE! And to answer your other question, the steering wheel is about the same distance from the dash and seat as the original - within an half inch. I could have moved it a little closer or farther away if needed.
Old 10-13-2013, 08:23 PM   #115
bonnieclyde100
thanks now i have more options besides spending almost 1000 dollars on a column and intermediate shaft
Old 10-18-2013, 06:30 PM   #116
Johnnyfever
I figured I would show a few pics of my 2 mile drive. Well at least the start and finish. Granny came along for the trip. Her only issue was there wasn't a window and it's "messin' my hair up".
Old 10-19-2013, 11:49 PM   #117
bonnieclyde100
well i went to the junk yard today and got my column from a s10 blazer from the early ninetys. and two intermediate shaft to see which one i like better.
Old 10-20-2013, 10:54 PM   #118
Johnnyfever
Are you keeping the key or shaving it? Let me know if you need any additional pics.
Old 10-21-2013, 07:46 PM   #119
bonnieclyde100
not sure wheather to keep they key or not. they look better in the dash but there is added security with it in the column and steering lock also. were you able to use the s10 nuetral safety switch as is or did you have to modify it?also any ideas on a gear indicator on the column to know what gear you are in? also were you able to use your stock seal and retainer from the firewall? i could use a picture of the column under the dash exiting the the firewall.
Old 10-26-2013, 01:18 PM   #120
Johnnyfever
Here are a few more pics of the column install on the engine side of the firewall....this is before I cleaned everything up and painted it all. I used a small diameter brake booster to give more room for the shift lever on the column. If you have the original type standoff bracket then I don't think it's an issue.
Old 10-26-2013, 01:22 PM   #121
Johnnyfever
And now I'm getting the bed floor fitted and straightened. There are a few more pinholes in the floor than I had hoped. I'm in the market for some corrugated repop sheet metal. I'll have to visit my friends at AutoMetalDirect ASAP!
Old 10-26-2013, 06:51 PM   #122
bonnieclyde100
are you going to try to come up with some kind of gear indicator for the column?
Old 10-30-2013, 10:12 AM   #123
Johnnyfever
I am modifying an indicator to work on this column. It will have to attach to the rigid section of the column behind the rotating shifting portion and extend over the shift rotating collar portion. The indicator will be mounted on that rotating portion and be visible behind the glass. I plan to use a low light LED to light it up.
Old 11-23-2013, 03:59 PM   #124
bonnieclyde100
well i guess it doesnt matter whether or not i want to keep the key in the column because i cant use it or the high beam switch because the rods used to make them work would be trapped between the column and the dash when i mount the column in the truck so i guess i will be loosing both. it would have been nice to at least keep the high beam switch.
Old 12-04-2013, 10:43 PM   #125
bonnieclyde100
well i finally got my s10 column mounted in my truck.
