Old 01-02-2012, 11:12 PM   #101
E911manager
Re: 64 chevy swb on a 94 chevy caprice frame w/ lt1
Before I pulled the cab off for the 5th time, i made a rough template to restructure the firewall. Moving the motor back was going to be a lot of work on the Caprice frame.. It could have been done but everything, including the shifter linkages line up.
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline   Reply With Quote
Old 01-02-2012, 11:20 PM   #102
E911manager
Working on that hole... I had a 2 foot by 2 foot piece of 20 gauge bent at a 45 degree bend at about 11 inches down then another 45 degree at about 16 inches. Had about an hour left before leaving for the weekend so I started cutting into it..
Old 01-02-2012, 11:25 PM   #103
E911manager
Cut, weld, hammer, block/hammer, cut, weld, hammer, block/hammer, cut, weld, hammer, block/hammer, cut, weld, hammer, block/hammer... My first attempt at any light metal welding.. It seems to have went pretty well.. Now some body filler and sand fill sand fill sand fill...... That will be next weekend..
Old 01-02-2012, 11:30 PM   #104
E911manager
And this is what the inside looks like... I will work on it some more when I get the cab back on or at least level.. Working with the cab tilted was hard on a fat guy... I will work on filling the other small holes later in the week. I am keeping the square hole for a vintage AC....
Old 01-03-2012, 05:59 PM   #105
2001shadowace
2001shadowace's Avatar
Its looking good!
2001shadowace is offline   Reply With Quote
Old 01-03-2012, 07:43 PM   #106
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
I am trying to see the point of doing that. What are you trying to do? Make a cleaner firewall since the motor sits slightly forward?
Not critisism, just wondering what the method to your madness is.
So far, your creation is pretty cool.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 01-03-2012, 08:06 PM   #107
E911manager
Yes, fill in the hole. It was going to be a big undertaking to move the motor "up and back" 2-3 inches. I thought of several ways and landed on this one. It looked like some yayhoo put a truck on a car chassis. So decided to smooth it out!!
Old 01-08-2012, 11:05 PM   #108
E911manager
Here is a pic with the gas tank hung in place..
Old 01-08-2012, 11:11 PM   #109
E911manager
Old 01-08-2012, 11:25 PM   #110
E911manager
Well this took about 5 hours. I used the caprice brake booster. I drilled new holes then cut the caprice firewall out and welded it over the 64 firewall to make a smooth clean finish. I will take a pic of it with the booster off when I get the inside mocked up. The caprice pedal mount is the backing plate for the booster. The pedal, rod, booster and switches all matched up so I used it.. The pedal will need to be cut, extended and bent around.
I cut the rear part of the truck pedal assembly basically in half, keeping the front part to mount steering column to. To make sure all the wiring connectors cleared, I had to relocate one of the brake switches (not sure if it a neutral lock out or the brake lights). It is actually a tight fit with all the wiring connectors on the column but it seemed to fit.
Old 01-09-2012, 12:36 AM   #111
66-PMD-GMC
66-PMD-GMC's Avatar
That looks pretty clean.
Nice .. very nice
Projects..
440CID 2X4 Pontiac
Old 01-09-2012, 10:05 PM   #112
bondo510
Now what frame are you going to use on the caprice? This is a great build! If you part that caprice body out I may need some stuff!
bondo510 is offline   Reply With Quote
Old 01-10-2012, 12:00 AM   #113
Bears63
...just another truck junkie..
Bears63's Avatar
I really like the lengths you are going to in order to have it looking clean and "natural". All that extra effort is going to pay off in the finished project, that's for sure.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 01-10-2012, 03:24 PM   #114
E911manager
Yes it is getting parted out when I am done. I already have some interest on this site for the chrome fender trim.
I have been using the trunk as my outside tool box (REDNECK). I told my wife that I am so fond of it that I may torch off the back half and keep it in the back yard to store tools in... I think my neighbors love it they will even love it more when it is a perminent structure...
Old 01-10-2012, 03:29 PM   #115
E911manager
Nice .. very nice
Thanks, it is coming together. I am starting to find when I move something a little is sure messes with other things a lot... Like the brake assemblies location in comparison to the column and the columns location to the booster.. Less room there then what I had sketched out in my mind!!!
Old 01-10-2012, 03:33 PM   #116
E911manager
Man Bears, I needed to hear that.. Thanks!!!
Old 01-10-2012, 03:41 PM   #117
Pop's C-10
Pop's C-10's Avatar
nice work
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 01-10-2012, 03:51 PM   #118
E911manager
I am eyeing up the carprice under dash heat and AC and thinking it would work.... Especially since I flattened out the firewall... HMMMM!!! Save me a thousand bucks and could get parts at the local auto parts store..
Old 01-11-2012, 11:27 PM   #119
E911manager
Originally Posted by Pop's C-10 View Post
nice work
Thanks Pops.
Old 01-13-2012, 01:25 AM   #120
C@rnut001
Good luck on using the AC and under dash heat. I think you are doing a great job of putting the truck on the newer caprice frame. Keep it up
C@rnut001 is offline   Reply With Quote
Old 01-13-2012, 03:07 PM   #121
E911manager
Thanks Owen.. 3 day weekend coming up so I hope to make some good progress..
Old 01-16-2012, 02:01 PM   #122
punk17
punk17's Avatar
Good job on the truck ! Lot of hard work. But will be worth it.
punk17 is offline   Reply With Quote
Old 01-16-2012, 09:55 PM   #123
E911manager
Well it won't work. It is to thick!! I eyed up the caprice firewall and thought about cutting out the part around the AC and meshing it into the 64's firewall. But..... Decided to just smooth it off and go with a old air unit.
Old 01-16-2012, 09:56 PM   #124
E911manager
Thanks punk 17.
Old 01-16-2012, 10:05 PM   #125
E911manager
Worked some more on the firewall this weekend. Filled the rest of the holes including the wiring harness hole. I cut a new one out a little bigger and under the inner fender bolts.
I also tore deep into the caprice. I pulled the entire wiring harness out and started making plans on how to use it. The power doors, windows and mirrors harness is plug and play so 2 connectors and it goes away. It won't be the prettiest truck under the hood but it will function!!!
Next goal.... Started before March 1st!!! We shall see.
