Old 09-16-2013, 10:13 PM   #101
mikeleeshields
mikeleeshields's Avatar
Re: My first C10 build, can't wait.
Originally Posted by Xeen View Post
The engine looks great.
It's always exciting when paint starts going on.
Yes it is. The only thing that scares me is all the body work in store yuck. I am so ready for my Porterbuilt stuff I can't take it lol.
1970 SWB Got My PB Suspension It's On Now- 1970 SWB - Porterbuilt to the Extreme
Mike
mikeleeshields is offline   Reply With Quote
Old 09-18-2013, 07:51 AM   #102
mikeleeshields
Got a couple coats of Epoxy primer on the bare metal last night. It is gonna rain in the next couple days and I couldn' afford to let it sit any longer.
Mike
Old 09-18-2013, 04:41 PM   #103
Xeen
Xeen's Avatar
Have you flap disked the welds on the bedside yet, I was hoping to see the bare metal after you leveled it out.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-19-2013, 06:57 AM   #104
mikeleeshields
I have not touched the bedsides yet. I may get around to them again this weekend. I will post some pics afterwards. I don't know how much bare metal there will be considering the previous body person used a gallon of filler on the bedsides.
Mike
Old 09-19-2013, 08:56 AM   #105
Xeen
Xeen's Avatar
(Sigh) I wish it was illegal for idiots to breed, then we wouldn't have to deal with things like that.
The only thing you have to decide is what is worth more to you, your time or your money because they will likely take a whole lot of time to fix.
Old 10-01-2013, 12:24 PM   #106
mikeleeshields
I spent Friday night fixing rust inside the rear window sill. I dont have any completed pics yet, forgot to take them. But here is what I had to repair. That is a lot of welding for what you get out of it. I will get some pictures of the completed stuff tonight.
Mike
Old 10-01-2013, 12:25 PM   #107
mikeleeshields
GOOOOOD NEWS. I just got confirmation from Dave at Porterbuilt that my extreme front and rear goods should be shipped out this week. A long time coming. I can't wait until they get here. I should have lots of updates then.
Mike
Old 10-02-2013, 08:48 PM   #108
mikeleeshields
Got the window sill just about finished up.
Mike
Old 10-02-2013, 08:51 PM   #109
mikeleeshields
The next thing to repair. Hopefully one of the last things I have to repair related to rust.
Mike
Old 10-02-2013, 09:01 PM   #110
Xeen
Xeen's Avatar
Yikes talk about a tragic attempt at repairing the cab corner, who ever did that should never be allowed to do body work again, ever...
Old 10-02-2013, 09:04 PM   #111
mikeleeshields
Ummm you can't even see how warped and how much filler I had to grind away. I was going to attempt to repair the hole but I figure it is just as much welding to replace the entire thing.
Mike
Old 10-02-2013, 09:11 PM   #112
Xeen
Xeen's Avatar
Yeah I'm realizing just how tragic the bodywork really was, it's like a greek tragedy, but hey you are doing it right and when you get done you will have a really great solid truck you can be proud of and I'm enjoying watching the build.
Old 10-02-2013, 09:17 PM   #113
mikeleeshields
Thanks Brian. Well it should get exciting next week because I should get some suspension parts. I can't wait.
Mike
Old 10-07-2013, 09:04 AM   #114
mikeleeshields
Spent the weekend welding up the firewall. I shaved all the holes and the wire channel. I don't know how I want to go about shaving the fuse block side. Should I cut out the entire side, the protrusion and all or just shave the holes?
Mike
Old 10-07-2013, 09:06 AM   #115
mikeleeshields
I went ahead and flattened the hump portion of the wire track also. Now it is flay across.
Mike
Old 10-07-2013, 09:07 AM   #116
mikeleeshields
Finally started laying down some filler. It finally feels like some progress.
Mike
Old 10-07-2013, 04:45 PM   #117
Xeen
Xeen's Avatar
This is a personal preference thing, for me the factory unsmoothed firewall isn't a big deal but for some others it really bothers them, I would just plug all the holes I'm not going to use and call it good but that's just me.
Keep in mind there is alot of stuff covering up that side of the firewall so you won't really see much of it, also that protrusion is your parking brake mounting location so you can't eliminate it or the parking brake assembly won't fit correctly at the dash support without a modification to the parking brake assembly.
Old 10-08-2013, 04:00 PM   #118
mikeleeshields
I finished shaving the firwall completely. I decided to take the e-brake hump out and shave the entire right side. I think it looks good. I will get an aftermarket e-brake if i decide to put one on. I also fixed the rocker panel too. The only rust I have left to fix now is on the inside of the cab on the interior roofline by the mirror and visors (that should be fun).
Mike
Old 10-08-2013, 04:18 PM   #119
mcbassin
Still Learning
mcbassin's Avatar
Very good progress on the body work. Nice job fixing that window frame and on the firewall. I know how time consuming this stuff can be. Snap a before pic and an after pic and it looks so easy anyone could do it..... Keep up the good work.
mcbassin is offline   Reply With Quote
Old 10-08-2013, 04:49 PM   #120
Xeen
Xeen's Avatar
Hey man I don't want to mess with your plan here or tell you how to ride your horse, but you shouldn't accept that cab corner the way it is.
The entire thing needs to be cut out and replaced because the P.O. didn't butt weld in the patch panel.
I know it is extra work but cab corners are cheap and the results will be worth it.
Tabco makes the best fitting patch panels on the market.
http://tabcobodyparts.com/
Old 10-08-2013, 05:05 PM   #121
mikeleeshields
I know I'm still debating on whether to cut t out or not. Still pondering it. No offense taken here at all. I will probably cut it out though. When I really look at it again and realize how crappy it really is. We will see.
Mike
Old 10-08-2013, 05:07 PM   #122
mikeleeshields
Thanks Mike. It definately is a lot harder and more time consuming than a couple before and after pics haha.
Mike
Old 10-08-2013, 11:29 PM   #123
mikeleeshields
As everyone says Christmas came early. I didn't know santa's real name was Nate Porter. Lol. I wanted to state how good the quality of these parts really are. The welds are perfect.
Looks like I know what I'm doing this weekend.
Mike
Old 10-08-2013, 11:35 PM   #124
Xeen
Xeen's Avatar
Very nice!
I bet you are grinning from ear to ear and with good reason.
I can't wait to see it go together.
Old 10-08-2013, 11:39 PM   #125
mikeleeshields
Any fellow ohio members wanna help put this fine equipment on lol.
And yes I was quite happy when I pulled in the driveway today
Mike
