Old 01-26-2014, 10:48 PM   #101
lynnfield
The Waco Kid
lynnfield's Avatar
Re: First Steps LS Swap......
I was already running an aluminum radiator, this is what I came up with for the steam port. I called engineered cooling products to see if there would be any problems with removing the heater hose connection and welding in an aluminum bung with NPT threads. They talked with their engineer, called me back and said it would cause no problems at all.
lynnfield is offline   Reply With Quote
Old 01-26-2014, 10:51 PM   #102
lynnfield
The Waco Kid
lynnfield's Avatar
I ordered this weld in bung from Jegs, and I have it fit and ready for the weld shop this week. It was a bit nerve racking enlarging the hole while trying to stay off the transmission cooler directly behind it. Once it gets back I have a 1/8 NPT thread to a 5/16 hose barb that will go in. Greg
Old 01-26-2014, 10:57 PM   #103
lynnfield
The Waco Kid
lynnfield's Avatar
I have a question, if I needed a manifold vacuum port, can I break this tab off and put it on this port? Is it that simple?
Old 01-30-2014, 09:49 PM   #104
lynnfield
The Waco Kid
lynnfield's Avatar
Radiator is back from the weld shop!
Old 01-30-2014, 10:10 PM   #105
truckdude239
truckdude239's Avatar
Yes just break tab and u have vacumm
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-30-2014, 11:14 PM   #106
ls1nova71
ls1nova71's Avatar
Yes, it's that simple. That's the vacuum source for the HVAC system in vans since they don't use servo actuated blend doors.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-01-2014, 12:45 AM   #107
lynnfield
The Waco Kid
lynnfield's Avatar
Worked on the front half of the fuel line today. I am using the fuel line from the donor truck, only a few tweaks and it went right in.
Old 02-01-2014, 12:48 AM   #108
lynnfield
The Waco Kid
lynnfield's Avatar
I had to make this one bend here
Old 02-01-2014, 01:01 AM   #109
lynnfield
The Waco Kid
lynnfield's Avatar
and had to tweak it a little to get it off the pinch weld where the toe board meets the fire wall.
Old 02-01-2014, 01:05 AM   #110
lynnfield
The Waco Kid
lynnfield's Avatar
I was able to use the mounting hardware from the donor truck. The bolt for the large bracket matched up to an existing frame hole, but I had to drill one for the alignment tab. The small straps went right in place of the clips for the tail light harness.
Old 02-01-2014, 01:10 AM   #111
lynnfield
The Waco Kid
lynnfield's Avatar
The fuel line bracket at the transmission had to be cut down. The way it was originally mounted, the fuel line was more towards the top of the transmission.
Old 02-01-2014, 01:14 AM   #112
lynnfield
The Waco Kid
lynnfield's Avatar
I had the fuel tank LineX coated, it's ready to be picked up in the morning. I'll start on plumbing the back half next. Greg
Old 02-01-2014, 10:36 AM   #113
oldman3
oldman3's Avatar
nice job on the install of lines...Jim
oldman3 is offline   Reply With Quote
Old 02-01-2014, 03:03 PM   #114
lynnfield
The Waco Kid
lynnfield's Avatar
Tank is back from being coated
Old 02-01-2014, 07:03 PM   #115
lynnfield
The Waco Kid
lynnfield's Avatar
Starting on the rear section of the line. I think there was more adjustments in the last foot and a half than in the entire rest of the line.
Old 02-01-2014, 07:08 PM   #116
lynnfield
The Waco Kid
lynnfield's Avatar
I had to straighten the 90 degree bend in this line. I know a few of you probably won't like this, but it's either that or cut the line and use a compression fitting and a repair section from the local parts store.
Old 02-01-2014, 07:16 PM   #117
lynnfield
The Waco Kid
lynnfield's Avatar
Once the line was fairly straight, there was a factory bend farther up the line that needed to be turned back into the frame. After that I used part of the original 90 (I didn't straighten it completely) to make the offset going into the filter/ regulator. Greg
Old 02-01-2014, 07:28 PM   #118
lynnfield
The Waco Kid
lynnfield's Avatar
I scored these fuel lines from the wrecking yard off a 2000/ 2001 truck 5.3 with a return style fuel system. One is 5/16, the other 3/8. The ends will work with the WIX 33737 filter/ regulator and provide locks to make sure the hoses stay on (little extra protection never hurts). I plan on making my own lines from the fuel tank and having the local tube and hose place crimp these factory ends on. My goal was to avoid using AN fittings by using the factory fuel lines from the donor truck, and hopefully with as few splices as possible. Greg
Old 02-02-2014, 11:52 PM   #119
lynnfield
The Waco Kid
lynnfield's Avatar
I figured out a way to use the shift cable from the donor truck!
Old 02-02-2014, 11:55 PM   #120
lynnfield
The Waco Kid
lynnfield's Avatar
There is a pivot joint built into the cable that allows some side to side travel, plus you can just about bend the thing in half and it will still move thru the full travel.
Old 02-03-2014, 12:05 AM   #121
lynnfield
The Waco Kid
lynnfield's Avatar
I measured the ball where the cable originally attached, and ordered this throttle linkage ball stud from Jegs : http://www.jegs.com/i/JEGS+Performan...15226/10002/-1
Then drilled and tapped the head of this bolt, added a lock washer……..
Old 02-03-2014, 12:11 AM   #122
lynnfield
The Waco Kid
lynnfield's Avatar
Bracket is about 3" wide
Old 02-03-2014, 12:20 AM   #123
lynnfield
The Waco Kid
lynnfield's Avatar
Set up and positioning to weld the two pieces together. Basically, I moved it around until everything lined up and nothing rubbed. All of the gear positions line up except for park, it's a little farther to the left of the "P". Which is a lot better than I had, none of mine lined up dead on before with the stock linkage/ 700r4 I was running.
Old 02-03-2014, 12:22 AM   #124
lynnfield
The Waco Kid
lynnfield's Avatar
Had to tweak the arm a bit on the column too
Old 02-03-2014, 12:26 AM   #125
lynnfield
The Waco Kid
lynnfield's Avatar
Installed, I'm going to mate the shift cable up to the E-brake cable so it follows that down. This clears up a bunch of real estate for the exhaust.
