Old 12-20-2013, 11:29 PM   #101
Z10
Z10's Avatar
Re: 72 GMC Short Step Build
First Radiator Test Fit
Car Boss installed the radiator and is sorting out the upper and lower hoses. Also fitted the passenger side wheel well to make sure that the surge tank didn't interfere and it fit like a glove. We also got the drive shaft back from being shortened and new heavy duty u-joints installed.
Mean while Double E is working on the intake wiring. More pics to follow on this a bit later.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 12-21-2013, 11:03 PM   #102
Z10
Z10's Avatar
Originally Posted by Z10 View Post
F.I.R.S.T TPI Manifold and ZZ4 Head Mismatch
We ran into a bit of a mismatch with the F.I.R.S.T TPI intake manifold and the aluminum heads on the ZZ4. The ZZ4 heads have a protrusion that interferes with the intake seating properly. Car Boss and I have another friend who owns a machine shop, He machined enough off for the intake to fit properly. So, for those of you contemplating using this intake on a ZZ4, be aware that you'll need to make this modification.
*****Update***** Double EE spoke to Ken at F.I.R.S.T. and he has a modification for the ZZ4 head. He'll mill down the manifold to fit the head. We just didn't tell him what we were installing on. So, if you order one, let him know before he ships.*****
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 12-23-2013, 06:26 PM   #103
Z10
Z10's Avatar
Custom Trans-Cooler Mount
Car Boss decided zip tieing the trans cooler the radiator just wouldn't cut it. No surprise to me, so...............the creation of a very slick very elegant cooler mount.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 12-24-2013, 06:02 PM   #104
Z10
Z10's Avatar
Coil Bracket 2.0
We picked up a new HEI coil and discovered it did not have a bracket attached to it like the one Car Boss had used to fabricate the first mounting bracket. So, a redesign was in order.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 12-31-2013, 10:26 PM   #105
Z10
Z10's Avatar
Oil in the Engine!
Milestone day today, we've got oil in the engine, some nice clean Castrol 10-30 and a nice pint of Comp Cam Engine Break-In Oil Additive.
Yep, we buttoned it up. Comp roller rockers, hardened push rods, and guide plates installed and the F.I.R.S.T TPI intake, torqued down to the top of a brand new ZZ4.
Also installed the rebuilt steering shaft and rag joint.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 01-01-2014, 12:26 PM   #106
Bomp
Bomp's Avatar
Sweet lookin motor.
Can't wait to see it in between the fender wells.
Bomp is offline   Reply With Quote
Old 01-01-2014, 01:40 PM   #107
Z10
Z10's Avatar
Originally Posted by Bomp View Post
Sweet lookin motor.
Thanks Bomp, it won't be long now.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 01-01-2014, 04:37 PM   #108
FRANKENSTEINC10
FRANKENSTEINC10's Avatar
looking outstanding
FRANKENSTEINC10 is offline   Reply With Quote
Old 01-01-2014, 11:31 PM   #109
Z10
Z10's Avatar
Heater Hose Heat Shield
Car Boss is doing something a little different with the heater hose on this engine. Instead of coming off the water pump, he's coming out of the block near the rear of the block and then into the Vintage air unit. He was a bit concerned about the heat from the headers, so time to fabricate a heat shield.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 01-03-2014, 12:50 AM   #110
Z10
Z10's Avatar
Dome and Curtesy Light Switch Installed
My Truck came with a Dome light but no door switch, so Double E installed the proper wiring, the switch and curtesy lights. It's the little things that make the difference.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 01-03-2014, 04:55 PM   #111
Z10
Z10's Avatar
Last Wiring Fitting
Double E is about to complete the wiring under the hood and did one last final fitting before the connectors are installed, it's wrapped, and hides inside the loom. Lot's of time has been spent studying, fitting, and restudying and refitting this harness. Here's a couple of pics.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 01-03-2014, 05:15 PM   #112
FRANKENSTEINC10
wow man. I need those kind of friends around here lol. my motor night only be controlled by 6 wires and yours is still cleaner.
Old 01-03-2014, 10:00 PM   #113
HSRACER
HSRACER's Avatar
Fun to watch, I am joining in.
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
Old 01-03-2014, 10:50 PM   #114
knomadd
knomadd's Avatar
Nice work so far. I'll be following along.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 01-04-2014, 05:20 PM   #115
Z10
Z10's Avatar
ECM Harness Finished!
Is this not a thing of beauty? Double EE has out done himself building this one of a kind, custom fabricated ECM harness. The next time you see it, it will be installed.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 01-04-2014, 10:16 PM   #116
FRANKENSTEINC10
awesome man.
Old 01-08-2014, 12:08 AM   #117
Z10
Z10's Avatar
It's finally in the Truck (for the last time)
Another milestone day today. Car Boss, Double E, my Son-in-Law, and I all pitched in and lowered the engine into the engine bay for hopefully the last time. Stay tuned as we continue
[URL=http://s20.photobucket.com/user/wtz10/media/IMG_0868.jpg.html][/URL
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 01-08-2014, 09:18 AM   #118
FRANKENSTEINC10
wow!! if you are ever near Dallas let me know. I would love to see this thing in person.
Old 01-08-2014, 11:30 PM   #119
Z10
Z10's Avatar
No off the shelf air intake on this build
Car Boss was hard at work again today working on ideas for an air intake.
He also bolted in the under-dash Vintage Air unit. We also pulled the wheels and tires to have new taller rubber installed. Anybody need a pair of Nitto 555 in 245/30/R20, let me know, I'll let them go cheap, less than 200 miles.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 01-10-2014, 12:48 AM   #120
Z10
Z10's Avatar
Plumbing the AC & Heater hoses
AC & heater hoses are coming along. We are not using the hoses that came with the Vintage Air kit, but instead fitting and routing them custom lines.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 01-13-2014, 12:26 AM   #121
Z10
Z10's Avatar
ECM Harness is Complete and Installed
Busy weekend. Well at least for Car Boss and Double E. I on the other hand skipped out Saturday to attend my grandsons first birthday. While I was gone, the ECM harness was installed, the fuel injectors were tested, and a vacuum was put on the AC system to check for leaks. We passed the vacuum leak test but failed the injectors. A couple were dripping under pressure and another shot out a stream of fuel even though it wasn't firing.
Friday I got the Boss 338's mounted with taller rubber, now I just need to decide how much I'm going to lower the truck. Also got the drive shaft installed and the last inner fender installed.
Bonus Pic of my 72 and "Hank" the 58
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 01-15-2014, 10:46 PM   #122
Z10
Z10's Avatar
Seat Covers and Air Intake Delivered!
I've been waiting a couple of months for my seat covers to arrive from Truck Seats and they were dropped off today.
I also received the AEM air filter and 4" Aluminum tubing that Car Boss will turn into something special.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 01-15-2014, 10:55 PM   #123
nds1968
nds1968's Avatar
Coming together nicely
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 01-18-2014, 03:05 PM   #124
Z10
Z10's Avatar
Thanks, we're getting closer. If I can get Car Boss back home from Barrett-Jackson, we just might get this thing running in a couple of weeks.
Oh, Car Boss.....parts are stacking up on your bench.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 01-19-2014, 02:00 AM   #125
Z10
Z10's Avatar
Truck Seat is at the upholsterer
I took the seat and the new houndstooth seat covers to the upholster Friday. Here's a pic of what it looked like before. Strangely I don't have any pics of the black mouse fur cover? Must be because I didn't like it. So here's the only photo that shows a bit of it.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
