Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Closed Thread
Old 08-27-2015, 03:08 PM   #101
gmachinz
Re: F/S: 73-87 power window relay harness
He has quite the project truck going on-he opted for the single headlight relay harness, dual tank harness and diesel engine harness. I had delays getting my wife's truck back together after fixing and repainting the whole thing so that's been what's been holding me up a bit. But I'm glad that's over....I know every square inch of that Yukon now!!!
gmachinz is offline
Old 10-08-2015, 02:39 PM   #102
cgovia
Aloha I have a 89 crewcab that I put powerwindows in from a 87 suburban and I would like to purchase you wiring kit with express down on the two front doors only what is the cost and How woul i get the money to you Mahalo Ed
cgovia is offline
Old 10-18-2015, 06:24 PM   #103
1976K5CHALET
1976K5CHALET's Avatar
Having done a lot of wiring work over the years id like to say wow to your attention to detail and quality of the parts used!
Any thoughts on replacement window motors. I bought so A1 auto motors from ebay and together they lasted a day...
DW
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline
Old 10-18-2015, 08:25 PM   #104
gmachinz
Thank you for the kind words! I try to provide the highest quality OEM style harness with or without late model upgrades....I build them exactly as I use them!
gmachinz is offline
Old 10-18-2015, 10:28 PM   #105
gmachinz
There's a local 3M electrical shop in town around here that services any type of motor-Id say check into that or, I have had good luck sending the OEM window motors out to A-1 Cardone for an R&R rebuild. Back when I was a parts counter guy (yep, there were of a few of us parts guys who knew our stuff!) we used to routinely send off OEM parts for customers to get rebuilt-stuff like water pumps, alternators, distributors, etc. when they wanted to retain a numbers matching vehicle.
gmachinz is offline
Old 10-21-2015, 07:20 PM   #106
zaccaglin
zaccaglin's Avatar
Will a 2door harness work on a 4door sub?dont necessarily need it on the back doors. Don't roll them down as much.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline
Old 10-21-2015, 07:42 PM   #107
gmachinz
You can-the kickpanel connectors are different-you'll need to re-pin everything.
gmachinz is offline
Old 10-22-2015, 11:11 AM   #108
gmachinz
The issue with the power window/lock harnesses through the years is that across the board and for no apparent reason, there were many different style of connectors used for the male/female mates which is why if possible, its often better to replace the center harness along with the LH and RH because I build an OEM replacement from end to end so I know everything will mate up. Otherwise, without knowing exactly what connector styles you have on your center harness be it a 2-door or 4-door, I can only supply you with the most common styles-now IF yours appear to be different then a quick pic or two and I can send the corresponding terminals out-much better to shoot me some pics beforehand so I can see what you're dealing with. Also, you just never know what a PO has done to the wiring as well ya know? Either way, if you need a specific connector, drop me a line-I have pretty much every connector/terminal all on hand for even the most unusual situations.
gmachinz is offline
Old 11-04-2015, 09:42 PM   #109
1774btcrew
1774btcrew's Avatar
I am curious what people that didn't originally have power windows are using for the door jamb boots? I got my harness and my truck didn't have power windows so I have to drill all of the holes in the jambs. Are people getting original ones at the wrecking yard or are their other alternatives?
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline
Old 01-13-2016, 06:09 AM   #110
345HP87SSAC
I will be talking to you if I get this 76 Crew purchased. I need everything. PM me here or on the MC SS board.
345HP87SSAC is offline
Old 01-13-2016, 07:28 AM   #111
gmachinz
Cool! Pics! Pics!
gmachinz is offline
Old 06-09-2016, 02:23 AM   #112
Nukeman3000
Talking Re: F/S: 73-87 power window relay harness
Hi, I have a 85 stepside 2 door cab and was wondering if you had a harness that would work for it. It has existing power windows but I am looking for an upgrade and your YouTube video was very impressive. Any information would be appreciated thanks.
Nukeman3000 is offline
Old 06-10-2016, 04:50 PM   #113
gmachinz
PM sent!
gmachinz is offline
Old 11-13-2016, 09:00 AM   #114
Joe69C10
Joe69C10's Avatar
Interested in one of your power window relay harnesses for my 86 if you can shoot me some prices.
Joe69C10 is offline
Old 11-13-2016, 03:43 PM   #115
gmachinz
PM sent earlier today!
gmachinz is offline
Old 01-15-2017, 11:14 AM   #116
moregrip
moregrip's Avatar
Originally Posted by gmachinz View Post
Yes-my fan harnesses differ from anything else you will find on the market-I worked (unsuccessfully I might add...) with Mark K. @ Spal some years back about designing a HD fan controller exclusively for the Mark VIII fan and other high output Motorcraft fans. I bought the OEM Motorcraft fans in large bulk from Ford for use in my relay harnesses I was building at the time for my shop customers. Well, two things happened:the fans went on the dis-continued list from Ford and Spal wasn't interested in building such a demanding controller for use with that or any OEM fan. Even their latest fan controller has an internal over current limit of 35 amps. If you try to run a fan that draws any more juice than that, it is designed to kick off.
Given what I know about fan motor efficiency I am not satisfied with any pancake style motor that Spal and most aftermarket companies offer so I was back to the drawing board. A rep for Siemens VDO out of Canada who designed/manufactured the fan motor for Ford informed me they (Ford) wanted a design that could run at full speed 24 hours a day for 10 years if need be...since that deisgn would see service in both high end Lincolns and police package vehicles. So I know from the horses mouth Motorcraft makes the most stout fans hands down.
Now, after reviewing the circuit design that Lincoln used on those fans called a VSC (variable speed controller) that they varied the speed by using a variety of capacitors of varying voltages to change the speed of the fan-not quite PWM but a more mechanical version of it. I figured the same thing could be accomplished through the use of a series of resistors to limit the voltage based on how many resistors the current must pass through-so I built a test harness and it has worked just like I planned from day one-I've perfected it over the last year and now, it serves as a conversion fan harness whereby it can allow you to take any fan-single or dual speed and use it as a 3-speed fan. My aim was to create a harness that can easily handle the demand of the Mark VIII fan since if it can do that, it can handle any fan you run it with, right? And, my relay resistor harness allows for 3 speeds out of it. Nobody else makes a non-PWM kit that can do that.
I just finished testing/running it on a dual 18" fan assembly from a 2010 F250 with the largest dual fan setup I've ever seen-it moves a reported 6000 CFM and pulls about 42 amps @ full speed to do it. I ran both fans at 3 speed in parallel and managed a 16, 28 and 42 on low, medium and high speed.
Awesome info! Thank you
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline
Old 01-16-2017, 02:00 PM   #117
gmachinz
Here's a Motorcraft 2-speed RF24 T-Bird fan mounted stealth style inside a stock pickup fan shroud-it is powered using my 3-speed conversion harness also. This way, the fan motor is converted to 3-speed operation. This type of fan harness allows you to run any style of fan(s) without the worry of high inrush currents or sudden spiking. I've moved away from failure prone PWM controllers and have been using these bullet proof relay resistor fan harnesses for over 6 years now.
gmachinz is offline
Old 01-17-2017, 12:33 AM   #118
gmachinz
For those looking for a complete replacement harness and are using either 81-up doors, are using factory 77-80 power doors or plan to convert manual doors 73-87 using a hardware conversion kit from Classic or A1 I have several options for harnesses-stock, auto down and auto down/up. If you've got a mutt of a build and need options on power accessories, PM me for details-I've got the best options available for power windows!
gmachinz is offline
Old 01-17-2017, 02:28 AM   #119
moregrip
moregrip's Avatar
Not that I'm especially knowledgeable when it comes to e-fan actuation but I do know that even mid grade relays will get eaten up by today's more powerful fan motors. Also, that initial amperage hit can be hi! I remember cruising around with extra relays just for the times when they would go bad to ensure I stayed on the road! Went so for as to source 40amp relays and was going to attempt to build my own harness.....lol.....that was back in 06, still have the parts but no harness!
When I get to the wiring phase I will definitely be contacting you! Thanks for the great info!
moregrip is offline
Old 02-07-2017, 12:27 PM   #120
NorCalAnthony
Just wondering, do you make complete vehicle re-wiring kits? I have an 84 K5 am thinking about getting one of your upgrade harnesses for the windows, headlights, and e-fans and am trying to decide if I replace the rest while I'm at it so I have a fresh slate going forward...
NorCalAnthony is offline
Old 02-07-2017, 01:36 PM   #121
gmachinz
I've got everything available for you except for underdash harness.
gmachinz is offline
Old 02-07-2017, 02:03 PM   #122
NorCalAnthony
Sweet PM sent.
Old 03-18-2017, 12:30 AM   #123
twarne
PM Sent.
twarne is offline
Old 05-08-2017, 12:01 PM   #124
JMac11
JMac11's Avatar
1982 Pickup with windows, would like kit with express down. Price and availability
please
JMac11 is offline
Old 05-08-2017, 12:14 PM   #125
gmachinz
$159 shipped-1 week out right now.
gmachinz is offline
Closed Thread
