Old 02-18-2014, 09:59 AM   #101
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: 1954 3100 C4 Tube Chassis Build
Yeah, he was a great friend, he would have done the same. A terrible loss for everyone who came in contact with him. 30 is to young to go.
Now, if I can get this 292 out of my garage I'll get moving on rebuilding this 5.3!
--Josh
Old 02-19-2014, 11:45 PM   #102
STOCKISH
STOCKISH's Avatar
Spent a little while in the shop tonight and finished my upper control arm mounts. 7 cutoff wheels later and a lot of grinding this is how they look. Clamped them together and threw them in the drill press as well. My DOM showed up today too so hopefully the cross member will be finished this weekend and installed in the truck!
--Josh
Old 02-20-2014, 12:08 AM   #103
99 to Life
99 to Life's Avatar
damn, very nice work. if you haven't or don't use dewalt cutoff discs, do so. I'v yet to find anything better. you can get em bulk on ebay. I shoulda done that on my last build. This build now, I'm between 30-40 discs. Didn't get them in bulk till about 20 discs in.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 02-20-2014, 11:25 AM   #104
vince921
Looking good!!
vince921 is offline   Reply With Quote
Old 02-20-2014, 12:29 PM   #105
mcbassin
Still Learning
mcbassin's Avatar
Killer progress Josh. I like the new power plant plan.
mcbassin is offline   Reply With Quote
Old 02-20-2014, 04:46 PM   #106
FarmerSid
FarmerSid's Avatar
Nice job Josh! You gotta slow down a bit. LOL! I'm waiting for my material to come in so I can build along with ya. How did you come up with upper control arm mounts from that picture of a drawing?
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 02-20-2014, 04:52 PM   #107
FarmerSid
FarmerSid's Avatar
Here's a few pictures of a jig a buddy passed on to me. Maybe they will be of some help.
C4 IFS & D44 IRS
5.3 HO L33
Old 02-20-2014, 05:21 PM   #108
STOCKISH
STOCKISH's Avatar
In post 102 you can see the template I used to make the upper mounts. I like that jig. I don't have anything like that. Just tape measures, levels, and angle finders over here. Low tech all the way! It fool yo show people that you don't have to have 150,000 worth of equipment and frame tables to do something like this. Just have to take your time and measure, ALOT!!
--Josh
Old 02-20-2014, 07:14 PM   #109
FarmerSid
FarmerSid's Avatar
I have low tech tools too. I saw the drawings you posted but can make out some of the dimensions. They are blurry when you try and zoom in. How did you make the upper CA mounts from that drawing? The lower control arm holes measurement is cut off in the first picture. I'd like to start fabbing along with you but those drawings are lacking quite a few critical measurements. Would you mind posting what those measurements are?
I find the Walter Zip disks last the longest.
C4 IFS & D44 IRS
5.3 HO L33
Old 02-20-2014, 08:20 PM   #110
STOCKISH
STOCKISH's Avatar
If you are asking the distance between the lower control arms they are 24 1/4 from center of the bolt to center of the bolt. Thats the only measurement I can see that is cut off, sorry about that. As for the upper control arm mount I just layed that template you see in post 102 on the 1/2 plate and traced it out.
Mike, Yeah Im pumped about the LS for sure. Now if I could just unload this 292!
--Josh
Old 02-20-2014, 08:46 PM   #111
FarmerSid
FarmerSid's Avatar
Thanks for the measurement Josh. I just reread my post and I think I may have come across a little crusty. I didn't mean to come across that way. I got to thinking, I wonder if the holes in the upper mounts should be slotted for caster and camber adjustment? Your thoughts?
C4 IFS & D44 IRS
5.3 HO L33
Old 02-20-2014, 09:33 PM   #112
STOCKISH
STOCKISH's Avatar
No you didnt sound weird at all. No worries man. The camber and caster is adjustable with shims just like the factory would have been. You have to move the upper arm in and out horizontally to adjust camber or caster, not up and down vertically or front to rear.
--Josh
Old 02-21-2014, 10:46 PM   #113
STOCKISH
STOCKISH's Avatar
Made a little progress tonight, I made a simple jig to ensure my lower control arm mounts stay nice and square while I burn them in. They are 1" diameter
.250 wall tool steel so hopefully they will be strong enough. I will either add a couple gussets or put a piece of 2" .500 wall DOM over them and weld them on as well. What are your guys thoughts?
--Josh
Old 02-22-2014, 08:42 AM   #114
fabguy
Elev8r Man
fabguy's Avatar
Nicely done, I would do both DOM and the gussets. Better to be safe now than wish later.
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!!
1958 Fleetside SWB ---> 58 Fleetside Build thread
1939 2 door sedan
My F.B. project page.
fabguy is offline   Reply With Quote
Old 02-22-2014, 04:21 PM   #115
STOCKISH
STOCKISH's Avatar
Made some kick ass progress today. Got my front cross member all welded up and installed in the chassis. Everything is perfectly square and the tire size and clearances are perfect for my ride height. Need to figure out correct spring rate and order coil covers now.
--Josh
Old 02-22-2014, 04:50 PM   #116
Flames97
Flames97's Avatar
Love the work you've been doing on this, looks really good.
-Aaron
'15.5 Chevy Duramax LTZ/Z71, LML, CC/SB
'77 Chevy K10, 4" lift, 33-12.50, 350/350
'55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD)
My 55.2 Chevy 3100 Build
Flames97 is offline   Reply With Quote
Old 02-22-2014, 05:51 PM   #117
STOCKISH
STOCKISH's Avatar
Thanks man. I appreciate that.
--Josh
Old 02-22-2014, 09:28 PM   #118
FarmerSid
FarmerSid's Avatar
Friggn right you've been kick'in ass! Looks awesome. Post some more closer up pictures of fab job with components installed.
C4 IFS & D44 IRS
5.3 HO L33
Old 02-22-2014, 10:09 PM   #119
STOCKISH
STOCKISH's Avatar
I will take more tomorrow when its light out. Super pumped!
--Josh
Old 02-22-2014, 11:25 PM   #120
99 to Life
99 to Life's Avatar
you made that look super easy. nice work.
Old 02-23-2014, 11:01 AM   #121
STOCKISH
STOCKISH's Avatar
Thanks guys, here are a couple more pics of the installed cross member. I still have to burn in the upper mounts completely with the 230 at work. I also added a picture showing the tire clearance in the front. The tire will be cambered in more than it is right now as well.
--Josh
Old 02-23-2014, 12:05 PM   #122
oldman3
oldman3's Avatar
Wow, that looks great, super nice job on the build of crossmember and components...Jim
oldman3 is offline   Reply With Quote
Old 02-23-2014, 03:33 PM   #123
STOCKISH
STOCKISH's Avatar
Thanks man, I have about $38 invested in the entire thing. The 1/4 wall I made the crossmember out of and the 1/2 I used for the upper control arm mounts I had laying around for years. The only thing I purchased was the 1/4 wall DOM for the lower mounts. Sure beats Flat Outs $1000 price tag. Sure was more work (lots more) but more rewarding as well. Cant wait to redo the back now and make it a full roller.
--Josh
Old 02-23-2014, 07:32 PM   #124
FarmerSid
FarmerSid's Avatar
Nice job Josh. Hope you don't mind but I'm going to copy the ride height, rim style and size, offset etc and tire size. That's the stance I'm after. Is the UCA mount parallel with the LCA mounting points? Kinda curious, why didn't you weld in the rack mounts and gusset the LCA mounts before you welded the cross member to the frame? You had things braced and that would have been a good time to gusset to stop movement during welding. Just wondering. That's all. A little on how you came up with the location of the cross member. How did you determine the vertical and horizontal location?
As nice as the Flat Out cross member is, the price tag is what's making me make one as well. Keep posting pictures! If only you made them a bit bigger.
It's quite impressive what you've done so far.
C4 IFS & D44 IRS
5.3 HO L33
Old 02-23-2014, 11:12 PM   #125
STOCKISH
STOCKISH's Avatar
I didnt do the rack mounts yet because Im not 100% set on wether I will use the Vette rack or use a T-Bird rack. The mounts for the T Bird rack are much simpler. I will add the gussets after I determine which rack Im goint to use, that way the gussets wont dictate how/where I mount the rack. As for the placement I put my fenders on and positioned my wheels where I wanted them, than marked my wheel center on the chassis. After that I used Flat Outs mounting instructions based on my wheel center. I will gladly mail you a copy of their instructions if it will help you.
--Josh
