View Poll Results: what light setup looks the best?
#1 current LED setup, Hella Rallye 4000 Compact Xenon pencil 8 29.63%
#2 current LED setup, Hella Rallye 4000 Xenon Euro Beam 1 3.70%
#3 BD Squadron wide cornering, Hella Rallye 4000 Xenon Euro 1 3.70%
#4 BD Squadron w.-crn., Hella Rallye 4000 Comp. Xenon driving, Hella Rallye 4000 Comp. Xenon pencil 2 7.41%
#5 BD Squadron wide cornering, Hella Rallye 4000 Xenon euro, Hella Rallye 4000 Comp. Xenon pencil 2 7.41%
#6 BD Squadron wide cornering, Hella Rallye 4000 Xenon euro, Hella Rallye 4000 Xenon pencil 0 0%
#7 HIDDEN BD Squadron wide crn, Hella Rallye 4000 Xenon euro, Hella Rallye 4000 Comp. Xenon pencil 1 3.70%
#8 HIDDEN BD Squadron wide cornering, Hella Rallye 4000 Xenon euro, Hella Rallye 4000 Xenon pencil 2 7.41%
#9 BD Squadron wide crn, Hella Rallye 4000 Comp. Xenon driving, Hella Rallye 4000 Comp. Xenon pencil 9 33.33%
current LED setup 2 7.41%
Multiple Choice Poll. Voters: 27. You may not vote on this poll
Old 06-27-2014, 07:47 AM   #101
K20chevy
K20chevy's Avatar
Re: 78 K20 custom delux "modern meets vintage" build thread
Originally Posted by winningz View Post
You are going all out man this is awesome. I love this truck
Thanks man!
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104
68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441
K20chevy is offline   Reply With Quote
Old 07-06-2014, 03:19 PM   #102
K20chevy
K20chevy's Avatar
Put some wood in the back to squat the suspension down and check the diff cover-tank clearance.
And I got lucky, even with a ton and a half of wood in the back I still have a bout 3/8" of clearance.
Old 07-06-2014, 03:23 PM   #103
K20chevy
K20chevy's Avatar
New shoes for the K20:
17x9" Weld Racing Forged aluminum wheels with 37x12.50R17 Goodyear Wrangler MT/R Kevlar.
(wheels are powder coated white for a future mod..youŽll have to wait on that)
Old 07-06-2014, 03:51 PM   #104
whitels1
whitels1's Avatar
Bad ass build, that fuel cell is nice with the inset fuel pump and the way it's positioned forward under the frame bend. Do you have any specs on it? I just installed a blazer tank and I'm going to have to do a lot of trimming to the bed support.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 07-07-2014, 01:23 AM   #105
K20chevy
K20chevy's Avatar
Thanks! I would have to digg up the drawing of the cell itself. But it was custom made and I wanted the inset fuel pump to not have to modify the bed. This one is pushing the size limit on the long bed truck though, so in order to fit it into a short bed or a blazer, youŽd have to have it a lot shorter than mine.
If I remember correctly (IŽll check) it is 31" long, 26.5" wide and about 14" deep on the part toward the axle and then slants up toward the bumper for some more ground clearance.
The fuel pump is a 2008 GMC Sierra Denali pump, wich has all the hook ups directly on the pump. The only other thing I had to have was the fuel filler neck. I have to admit I kind of messed this one up, if I could do it again IŽd have that posissioned differently, but I made it work.
The coolest part is, the entire fuel cell is mounted with stock crossmembers that have only been tweaked a bit.
The cell has around 45 gal capacity and is fully made out of aluminum.
IŽll look for the drawing so I can give you the exact dimensions.
Old 07-07-2014, 02:01 AM   #106
Hankster
Hankster's Avatar
Can't wait to see what you do with the wheels..
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 07-08-2014, 12:42 PM   #107
K20chevy
K20chevy's Avatar
Just one more hint on what I have planned with the wheels....
Old 07-15-2014, 03:41 PM   #108
K20chevy
K20chevy's Avatar
the 37Žs fit great in the rear...
but the front needs some fender mods bad. I can only turn the wheels when the fender goes between the tread blocks!
starting to build a rear bumper from scratch...
Old 07-15-2014, 03:45 PM   #109
K20chevy
K20chevy's Avatar
the beginning of the new bumper...
Old 07-15-2014, 04:42 PM   #110
K20chevy
K20chevy's Avatar
So here are the requested dimmensions of my fuel cell....
Hope this helps.
This is another shot of the tank with the bed off...
In this pic you can also see the mounting plates for the rear bumper. 1/2" steel plate.
Old 07-15-2014, 04:42 PM   #111
TheBlueBomber
TheBlueBomber's Avatar
I hate that about big tires and these trucks. I've never liked cutting fenders but it must be done to fit the right sized tires... I'll have to cut mine to fit the 33" boggers I have.
Truck is looking great and I love the white rims. Can't wait to see the finished bumper! Are you going to paint it to match the body?
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 07-15-2014, 04:50 PM   #112
K20chevy
K20chevy's Avatar
Thanks! Well I made the 35Žs fit with 4" of lift and no trimming. But backspacing of the wheels plays a big role and also what tread you have. Boggers for sure are really agressive...
I will modify the fenders to the point, where you wonŽt ba able to tell they are modified unless you compare them side by side to a original fender. stay tuned for that.
I must say myself, I like the white rims too and I do really like the goodyear tires as well.
No, the bumper will get the same semi gloss black powdercoat as the front bumper has. At some point, the rock sliders will too...
Old 07-16-2014, 09:15 AM   #113
Ol'_Blue78
Ol'_Blue78's Avatar
This truck is absolutely amazing. With the fuel cell did you have to relocate anything or did you have to run a body lift at all so it clears everything?
1978 Sierra 1/2 ton lifted, 388/SM465/NP205, 35x12.50 on deep dish aluminum slot wheels.
Ol'_Blue78 is offline   Reply With Quote
Old 07-16-2014, 12:28 PM   #114
jhama78
jhama78's Avatar
Which end are you linking first front or back? Also do you have an idea of the spring rates that you are going to start with?
-j-rod
'06 3500 LWB CC 4wd, 8.1 Allison
jhama78 is offline   Reply With Quote
Old 07-16-2014, 02:57 PM   #115
Hankster
Hankster's Avatar
Looks good with them wheels!
Current Build
Old 07-16-2014, 05:20 PM   #116
K20chevy
K20chevy's Avatar
Thank you! No body lift. I did have to relocate all the crossmembers in the back. the furthest back had matching holes at the end of the frame, so I just had to drill the rivets out and move the crossmember back and bolt it to the existing holes. The spare tire carrier and front cross member also had to be relocated, but I made it all work with factory stuff. The fuel cell was built so that it clears everything the way it is...
The front will be linked first. I already have all the links built, the shock hoops done, etc. All the brackets are there as well, just havenŽt had the time to weld it all in yet. I need to do the front first to set the final ride height because of the steering, engine crossmember etc. That will dictate the rear height too. In the rear IŽm not sure If IŽll link it or just run long travel deaver springs. To be honest with you, IŽd have to look the spring rates up again, it has been so long since I ordered them. I think they are 200 oder 300. But IŽll look it up again to give you the correct numbers.
Thank you! looks more old school than the chrome wheels...
Old 07-16-2014, 06:30 PM   #117
bob_o
bob_o's Avatar
Not really into lifted trucks, always preferred them a little closer to Mother Earth But I just went through this whole thread and it's really inspiring! The fit and finish and build philosophy are badass.
Functionality is clearly #1 while aesthetics play a guiding role, making sure that while this truck is a very capable 4x4, it still looks damn good doing it! Killer truck! Where I've grown up, most lifted trucks are all about looking like an offroad machine, but in reality they're mostly a bunch of pavement princesses. They just make me roll my eyes now.
But seeing your truck makes me want to build my own offroad rig someday I look forward to more updates
bob_o is offline   Reply With Quote
Old 07-17-2014, 06:11 AM   #118
K20chevy
K20chevy's Avatar
Thank you for the kind words. I appreciate the feedback. I never thought the truck would generate that much interest. IŽll keep the updates coming.
Old 07-17-2014, 09:17 AM   #119
Ol'_Blue78
Ol'_Blue78's Avatar
Thats awesome. I was trying to figure out how I can run a fuel cell so I can get rid of the saddle bag and this seems like a real simple solution. Im gonna have to reroute my exhaust though cause I have 3" pipes right down the middle of the frame.
Old 07-18-2014, 07:22 AM   #120
K20chevy
K20chevy's Avatar
That is why my exhaust is so short, coming out in front of the rear wheels. ItŽs jsut the tail pipe, so shouldnŽt be much work to change that. You can also runa 40 gal suburban tank with minor mods to the crossmembers. that would be even easier than running a fuel cell like mine.
Old 07-18-2014, 09:09 AM   #121
Ol'_Blue78
Ol'_Blue78's Avatar
Thats really good to know. Thank you for the tips and advice. Just need to find my driveshaft slip yoke and I can drive it again! Its been a wild goose chase so far. Looking in to seeing what itll cost me to have a machinist make one for me.
Old 07-19-2014, 09:27 AM   #122
whitels1
whitels1's Avatar
Thanks for the pics!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 07-22-2014, 12:34 AM   #123
K20chevy
K20chevy's Avatar
Find your slip yoke? Where did it end up? Not an item so small that you could drop and loose, right? Good luck with the drive shaft....
trust me, mine hasnŽt been an easy walk either!
YouŽre welcome. Hope they are helping you out a little bit.
Old 07-23-2014, 02:55 AM   #124
Ol'_Blue78
Ol'_Blue78's Avatar
Nope haven't found it yet. Going to check another shop this week pending a get out of work in time. Talked to a machinist about making one and it'd run me like $800 cause I'd tie him and his machines up for at least two days. If that wasn't a 16 spline shaft that thing would already be back together and the second one broken by now lol.
Old 07-23-2014, 05:54 AM   #125
K20chevy
K20chevy's Avatar
$800 for a Yoke, wow. Is your drive shaft so special? For that money you can have the craziest drive sahft custom built. So maybe you should just have acomplete shaft made up with a slip yoke, or convert it to a fixed yoke while youŽre at it.
