Old 02-16-2016, 12:15 PM   #101
sharkskinman
Re: Rear Brake Drum Dilemma
Doesn't rockauto have them and/or complete kit for from and rear? Cylinders-shoes-drums...
sharkskinman is offline   Reply With Quote
Old 08-05-2016, 01:36 AM   #102
Praxiss454
Praxiss454's Avatar
Going through this dilemma now myself for my new-to-me 65 gmc. What a pain in neck. Of course the local machine shop is only open 8:30 - 4 M-F so I have to take a day off work to deal with this if I go the Wagoneer route.
Praxiss454 is offline   Reply With Quote
Old 08-05-2016, 01:46 AM   #103
sharkskinman
Rock auto kits
I'd like to do a dual master cylinder
Keeping 6 lug drums
I'm guessing with a proportion valve or just smaller lines like OG
Old 08-06-2016, 02:12 PM   #104
Praxiss454
Praxiss454's Avatar
For those who still have this rear drum dilemma, I ended up finding the NAPA equivalent of the Centric 122.66028 (Wagoneer drums). I measured them next to my stock rear drums and I think they're going to work, with the additional machining as mentioned before. The NAPA part number is 440-1361 and I paid $25.83 a piece. Now I gotta find a shop to do the machining.
Old 08-06-2016, 06:02 PM   #105
jtrichard
The price on the drums that "fit" (NO LONGER available) was anywhere from $110 to $160 so at $26 you can afford the small amount of machining it takes to make them fit
jtrichard is offline   Reply With Quote
Old 08-10-2016, 01:21 AM   #106
Praxiss454
Praxiss454's Avatar
Well I actually had significant trouble finding a machine shop that had a lathe large enough to fit the drums. Finally found one, and the guy said it took him about 2 hours to get them done, and charged me by the hour. So it was damn close to being a wash vs buying the ones that "fit". But, I installed them tonight and they fit perfectly.
Old 08-11-2016, 03:26 AM   #107
sharkskinman
I got one at auto zone I think .. Fits fine
Old 01-15-2017, 08:42 AM   #108
cbeerman
Looks like there is typo for the Centric part number it should be 122.63028
cbeerman is offline   Reply With Quote
Old 01-15-2017, 09:12 PM   #109
sharkskinman
I gave #s and screen shot of the ones I bought and put on my truck
Now I need a part number of the dual master that's a direct bolt in and the sizes of the tube adapters
67c10 correct??
Old 02-22-2017, 09:17 AM   #110
KVB
I am trying to find the parking brake strut bar, shown in the pic. Both ends are offset.
Anybody have any leads as to who sells this?
I took this pic from post 20 of this thread.
I believe my rear end to be a Dana 44.
KVB is offline   Reply With Quote
Old 02-22-2017, 10:00 AM   #111
roger55
roger55's Avatar
Are you missing those on both sides?
roger55 is offline   Reply With Quote
Old 02-22-2017, 10:17 AM   #112
KVB
Yes, i bought a set a while back and am now just putting this together. The ones I have are offset on one end only.
Old 02-22-2017, 10:41 AM   #113
roger55
roger55's Avatar
It doesn't appear that the bar is included with any kits I can find.
That may only leave you the options of finding them in a wrecking yard or fabricating your own. If you can borrow one to make a trace, it wouldn't be very difficult to do that.
Old 02-22-2017, 12:07 PM   #114
par4tom
Last year I took the 6 lugs out of my 66 rear end, swapped the axels and put in the 5 lugs. I may have a couple of the drums you are looking for.
Tell me again, exactly what dimensions you need and I'll see what I have. I'm in the process of converting my current 5 lug system from drum to disc...I do have a set of those 5 lug drums I won't be needing as well as the entire back plate system...
Tom
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 02-22-2017, 12:09 PM   #115
roger55
roger55's Avatar
He's not looking for drums. He's looking for the cross bars in that photo. Hopefully you will be able to help him out.
Old 02-22-2017, 12:46 PM   #116
PGSigns
PGSigns's Avatar
That picture really looks like 12 bolt stuff. Are you sure its a Dana 44?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-22-2017, 12:59 PM   #117
roger55
roger55's Avatar
Jimmy
Yes. My photo.
'65 GMC w/leaf spring rear, Dana 44 and stock brakes.
Old 02-22-2017, 01:10 PM   #118
KVB
Roger,
Thanks for the clarification.
I must say your threads are very well documented.
I have a parts yard in Ontario looking for the parking brake strut for me.
www.billstruckshop.com
Will keep you informed if he finds anything.
Ken
Old 02-22-2017, 06:39 PM   #119
roger55
roger55's Avatar
It might help you find one if you refer to the part as a parking brake spreader bar.
I think that's the most common name but I've seen parking equalizer bar also.
Best thing to do is call it a parking brake spreader/equalizer bar to cover both.
Old 02-22-2017, 06:44 PM   #120
par4tom
You may be in luck...I am going to be ditching this entire rear brake assembly maybe as early as next week. Going to a Baer disc brake system. If you can hold tight, I'll take some pictures and post them here with what I have on the truck now...mine is a 12 bolt and if memory serves me correctly, is like what you have pictured above
My Build Thread
Old 02-22-2017, 07:01 PM   #121
KVB
Great. If someone has one of these spreader bars, and could trace the outline, send it to me in an envelope, i could cut them out of some plate.
I would be willing to compensate the postage and envelope, with cash or if you need something, I might have it.
Ken
Old 02-22-2017, 07:44 PM   #122
par4tom
Is this what you are looking for?
My Build Thread
Old 02-22-2017, 08:26 PM   #123
KVB
I am looking for the parking brake spreader bar like shown in post 110, it has an offset on both ends.
The one you have shown has an offset at one end only.
Old 03-12-2017, 07:39 PM   #124
KVB
Found the Spreader bars.
Old 03-18-2018, 03:52 PM   #125
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
what is the part number for the Wagoner drums?
49 chevy 5 window 20 year project (sold)😟
57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.)
62 GMC 305 V6 custom L/B
72 HIGHLANDER K5 BLAZER 2nd owner
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
62 GMC SHORT BED SERVICE BODY V6 (STUMPY)
74 GMC CUSTOM 1500 L/B
Matt's k5 is offline   Reply With Quote
