#102 |
VA72C10
![]() Join Date: Mar 2008
Re: Project "Keeper"
Thanks!
![]() Here are pictures of the cruise-in I went to tonight. https://plus.google.com/u/0/10694048...ts/X3amadp8ciC
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#103 |
VA72C10
And here's a picture from this evening after I put the rad cover on and painted it satin black to match...it looks too glossy in this pic because it was still wet...
#104 |
VA72C10
Here's something I needed to repair...
Ended up trying out a header repair kit from Advance auto....it came with a fiberglass mesh and a hardening steel (think jb weld) material. I was doubtful but it seems to have worked...I followed directions for it. Mixed it well, sanded and cleaned the surface the best i could, applied with an old screwdriver, let it cure for 30 minutes and then ran it at idle for 20 minutes. Then drove it up to the local cruise-in (10 minute drive with traffic/lights). Ticking is still there but it's very slight now...before it was loud and there were actually flames coming out of the headers at night and backfiring when I let off the gas....it's not doing that any more. It's not pretty, but I can sand it down (will use a dremel) and paint-i'll wait until I detail the engine bay...probably take them off, sand them down and clean them up and apply more if I notice the other leaks, paint them with high temp paint (they are ceramic coated but starting to look old) to make it all one color and call it good....much better than spending 450 on a new set of sanderson headers to match these...or buying cheaper ones and modifying the exhaust to fit. At this point I have $14 and 30 minutes total time invested....
#105 |
VA72C10
This is the "before" picture of the tailgate.
Then, the "during" when I took it off and cleaned up behind it. (before the cleaning- you can see the dirt) Was happy to see it's an original stamped gate-not a cheap flat aftermarket (note-the ones available now from triplus/keyparts are nice but when this truck was restored 9+ yrs ago the non-stamped gates available were thin metal and easy to bend...) And the "after"---much better!
#106 |
VA72C10
Finally, the wheel covers...
The way the truck looked before Comparison (I used flitz metal polish and put the vinyl bowties on the 73-75? covers) Closeup
#107 |
VA72C10
Next up will be replacing the old center a/c vent before I do the stereo (for easier access), putting in the stereo- going to be a tight fit with a/c for sure) and then I'm going to take off the wipers and wiper cowl to clean up that area, putting black cowl vent covers to keep the leaves out, and putting new polished stainless wipers/arms I found (matches the polished trim around the windshield)
#108 |
VA72C10
Tried to put on the piece that goes between the grill and rad support to smooth that out but found I had purchased it for 67-68...going to get the correct one for a 72 the next time classic industries does 20% off...
#109 |
VA72C10
Can anyone believe I've held onto this truck for nearly 6 months???
#110 |
A guy with a truck
It's a nice one; definitely a keeper. Looks much better now with 'correct' covers. You've got the right plan--anything other than subtle changes will ruin this one
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#111 | |
VA72C10
![]() Next plans are get the stereo installed (install new upper A/C vent first) (Will need BMERDOC's help as I tried and can't access it w/out disassembling a lot of my dash) Then plan to take off the wipers/cowl and clean out that area, fix the spot of rust near the A/C box, put the screen on the underside of the cowl, put on the cowl and some new polished wipers I found for it (think they look great with the polished stainless trim around the windshield) Final little tweaks are adjusting the parking break and working on the door locks so they function more easily and match the ignition key.
#112 |
![]() Join Date: Aug 2014
Updates?
My dad always says that HEI distributers are pointless... •1972 Custom/10 Deluxe. My first truck and I've had it since I was 7. Tilt, tach, AM/FM, 350, deep dish rally's, original paint and an increasing amount of NOS jewelry. It's always taking my money.. •1967 c10 with tach, dropped 3/5 on deep dish rally's •1972 Cheyenne Super. Sold |
#113 |
VA72C10
I've collected a few small parts for it. Mainly watching it sit outside and starting it every month or so and driving it around the cul-de-sac... I haven't been home very often due to my work schedule. Have spoken w/ BMERDOC who is going to help me knock out some of the punch list items soon. After that....we will see. I really want a blazer for the family but this would have to go to fund a blazer purchase....
#114 |
VA72C10
diagnosed the fuel gauge. tried the printed circuit first. it's good and connections are all good. Traced the wire and it's all tucked up nicely (had to take the carpet loose off the gas tank). Wire was on the fitting....took it off and grounded it to the tank and presto-full tank.
![]() Also diagnosed the parking brake (as in I have none). Looks like the cables are just loose- so that should hopefully be an easy fix when I get it up on the lift next time at Nick's (BMERDOC) work... Got a new AC drier to make sure the system is optimal. Will hopefully be able to use his equipment to capture the R134 and refill after we swap that out.
#115 |
VA72C10
Here's a recent picture after my daughters surprised me by washing the truck for my Birthday.
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 04-28-2015 at 08:29 PM. |
#116 |
VA72C10
BMERDOC helped me get the drier swapped (looked old and heard it was best to replace). System had held the charge perfectly so he used his machine to collect, vacuum, and then re-charge the system. Running nice and cool and should run well for a long time.
Got all the locks changed out...had two different keys and no key for the outer locks when I bought the truck. Now one key for the locks, ignition, and glovebox door. Got the center A/C vent switched out by BMERDOC....thankful as I couldn't get my hands inside the radio hole to try to get it done.... Ordering a radio tonight...going with something modern and simple with correct knobs. The nice thing is the modern ones aren't as deep so should make installation a little easier with the A/C and everything else in place.
#117 |
6>8 Plugless........
![]() Join Date: Sep 2007
The truck still looks great!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#118 |
VA72C10
Well, you all know me...."keeper" was a bad name for one of my projects
![]() I've decided to sell this truck. Want to end up getting a blazer or suburban so I can fit the whole family. Hate having to take only two of four kids and deal with the disagreement on who rides which time....and take a second vehicle to get to a show. Can't afford both at this point...and don't want the truck to sit outside. Posting on the forum and on craigslist. I did keep it for over a year...barely ![]() Someone is going to get a very nice truck.
#119 |
Blazers rock, I would own one in a heartbeat, go for it man!
#120 |
VA72C10
#121 |
VA72C10
Thanks...always hated that I had to sell the 71 Blazer (project "finishing touches" on here). Loved driving that with the top off of it.
#122 |
VA72C10
Had an offer to trade for this 79 Corvette today. Not bad but not quite room for 6 in it
#123 |
VA72C10
Lowered the price...
#124 |
![]() Join Date: Dec 2010
Nice truck! Someone will be very lucky to end up with Project Keeper!
Is that the 523 Dark Blue? It sure looks light in some pictures but really dark in others. Thanks, Chris
Chris Build Thread for CSautosports 69 SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=675701 |
#125 |
VA72C10
Took some pictures tonight as I cleaned up the truck. Put in the old air products cowl screen and a set of polished wipers I found on eBay. Have a gentleman coming tomorrow who says he's buying the truck...
