Old 10-05-2017, 09:28 PM   #101
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: 1966 C1434 SWB Custom Cab
I'll be watching...
66 C20 Service Truck:
Old 10-13-2017, 06:38 PM   #102
CustomCab66
CustomCab66's Avatar
Smile Re: 1966 C1434 SWB Custom Cab
Motor mount plates are made and installed. now on to the tranny cross member. I know I'm re- inventing the wheel here but it's more satisfying when you make your own parts
CustomCab66 is offline   Reply With Quote
Old 10-14-2017, 08:23 AM   #103
CustomCab66
Angry Re: 1966 C1434 SWB Custom Cab
If I didn't have bad luck I wouldn't have any luck at all. Tapping out one last hole for 3/8-16 and broke the tap. Hope I can weld to it and get it out otherwise I will need to redo that whole plate :/
Old 10-14-2017, 09:04 PM   #104
CustomCab66
So I came across a little luck because was able to remove the broken tap. Happy to say the motor is in there all bolted up. With the hoist out of the way I'll be able to start the tranny mount, oil cooling lines, fuel lines and connections
Old 10-15-2017, 07:25 PM   #105
CustomCab66
Doesn't look like a tranny crossmember yet but I know there's one there somewhere. 👍🏽
Old 10-19-2017, 09:42 PM   #106
CustomCab66
Transmission crossmember taking shape.
Old 10-20-2017, 11:01 AM   #107
scdude37
love seeing this project. Like seeing the 5.3 coming together and the progress on it. I would like to swap mine out sometime to the same thing you are running.
scdude37 is offline   Reply With Quote
Old 10-23-2017, 09:44 PM   #108
CustomCab66
Thanks, the progress is not quite as fast as I'd hoped but I'll get it evenually
Old 10-23-2017, 09:49 PM   #109
CustomCab66
I have the center mount tack welded in place right in the middle so time for test fit #1. So far right in track
Old 10-24-2017, 01:50 PM   #110
CustomCab66
I removed the center of the arches and from there I'll Just go straight to the frame. Welding it out now so all I need is about 3 inches of straight pipe on each side. To Be Continued
Old 10-24-2017, 02:01 PM   #111
53chevyforever
53chevyforever's Avatar
Originally Posted by duallyjams View Post
super nice
you can add a vacuum gauge to fill out the gauge panel
Attachment 1303930
Here is mine.
53chevyforever is offline   Reply With Quote
Old 10-27-2017, 03:53 PM   #112
CustomCab66
Originally Posted by 53chevyforever View Post
Here is mine.
Nice!!! I want a Vac gauge
Old 10-27-2017, 03:59 PM   #113
CustomCab66
Headers are here and they fit!!!!! Wow impressed with them so far. These are the LS swap header for C-10 trucks from Speed engineering specifically for 60-66. Not bad for headers made for these trucks with an LS.
Old 10-27-2017, 04:14 PM   #114
bj383ss
bj383ss's Avatar
Those look really good man!
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 10-27-2017, 05:54 PM   #115
53chevyforever
Awesome headers!
Old 10-28-2017, 04:08 PM   #116
CustomCab66
Talking Re: 1966 C1434 SWB Custom Cab
Now that the headers fit I'm back on the tranny mount, now I have it the width of the frame. Notice I cut the humps off and ran it straight out from there to the frame. It should end up in the center of the frame rail. Frame is 29 inches from the inside of one frame rail to the other. All that's left is to fab the mounting plates that I'm gonna use to secure it to the frame
Old 11-02-2017, 09:49 PM   #117
CustomCab66
No pictures this time. I'm gonna try and run my driveshaft down to scotty's drivetrain and machine here in Austin. Those guys said they would shorten the driveshaft for 89. They tack on more for new u joints and balance job. I'll have them spin it first to see if it is even worth even messing with it or if the tube needs to be replaced.
Old 11-11-2017, 11:00 AM   #118
CustomCab66
My LS has a drive by wire throttle body. I'm debating where I want the wiring at this point but I mounted the pedal assembly on the floor where the wires feed the tail lamps. I cut the pedal off of the pedal switch and welded a piece of the original pedal fulcrum to it. I pushed the pedal and it moves freely the entire rotation of the throttle switch. I've been warned when welding on items with electronics that the arc surge will cook the electric circuit. Tip is to ground as close to the area that needs to be welded so I used the ground clamp to hold my peices together. Cooled them shortly after in some water to prevent heat damage to the switch. Hope it will work
Old 11-17-2017, 02:19 PM   #119
CustomCab66
He biggest hurdle in this whole swap has been the tranny mount itself. I checked the frame side to side checked the driveline angle over and over. None of the original holes in the frame are square, the driveshaft loop same. Blah blah blah. Over and over. So I eyeballed it so that the mount looks square with the tranny itself with the motor bolted down. I centered the tailshaft of the tranny between the frame rails and boxed the frame in. Drilled the mounting hole and welded nuts inside the boxed section. This will aid in removing the cross member in the future because I will not need a back up wrench. Hope it all works out. If I made it square it would have looked bad out of square. Only time will tell
Old 11-18-2017, 10:21 PM   #120
CustomCab66
Separated the motor from the transmission so I could replace the front and rear main gaskets and seals and the pan gasket. So far so good
Old 11-20-2017, 08:13 PM   #121
CustomCab66
Splashed a fresh coat of VHT black engine paint on the lower portion of the block. I found out that the rear cover had stripped bolt hole bosses on the oil pan flange. Got a NOS part coming from EBay. Do it slow and you know it's right
Old 11-22-2017, 08:01 PM   #122
CustomCab66
My rear cover showed up today so I finished sealing up the motor. Got ahead of myself and before I knew it I had it back in the truck. Time to start with all the small stuff like wiring and plumbing the tranny lines.
Old 11-23-2017, 08:44 AM   #123
northern 85
northern 85's Avatar
Looking good!!!
northern 85 is offline   Reply With Quote
Old 11-25-2017, 10:54 AM   #124
CustomCab66
So wiring day is close. I used the instructional at LS1 Swap.com to convert the original harness to a stand alone harness back when I first bout the LS combo. Yesterday I installed the harness and hooked up all the sensor related stuff in the engine compartment. I ran the harness into the cab using a stock grommet hole for the original engine harness. Time to bust out the soldering iron and shrink wrap
Old 11-25-2017, 11:00 AM   #125
CustomCab66
Also I have the pre and post fuel filters and necessary fittings on the way from Summit Racing. To Be Continued
