Old 04-12-2016, 01:47 PM   #101
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: Minnesota Daily Driver
Good fun!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 07-25-2016, 08:20 PM   #102
400/400
Figured I'd update the thread. Recently went to back out of the garage and found that the shifter wouldn't come out of park. Dropped the pan and found it was hitting the edge. This was pretty strange as the pans been on for more than 15,000 miles. Ground in some clearance and it was good to go.
Here's a pic of the mark it left hitting the pan.
1979 K25 350/SM465/205/44HD/14FF
1985 K20 400/400/208/10/14
1987 V10 TBI350/700R4/208/10/10
'85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968
400/400 is offline   Reply With Quote
Old 07-25-2016, 09:01 PM   #103
MTCK
MTCK's Avatar
That's odd. Wonder if something with the shift linkage geometry outside the case...
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 07-25-2016, 09:23 PM   #104
400/400
Forgot to mention I had retightened the bolts in the pan before it happened. I think the gasket may have collapsed just enough or the pan shifted slightly. Ive heard with these pans that sometimes more clearance needs to be added for the shifter. Just odd it happened after being on the truck for so long.
Luckily, the shifter linkages are all still tight.
Old 07-25-2016, 09:30 PM   #105
400/400
I had reconditioned the original door panels when I reassembled the truck but they were showing their age and were starting to crack. So I ordered some from Rockauto. Pretty happy with how they turned out. I need to paint the kick panels to match.
Old 07-25-2016, 09:32 PM   #106
400/400
Also replaced the power window switches as the passenger side had started acting up.
Driver door.
Old 07-25-2016, 09:32 PM   #107
MTCK
MTCK's Avatar
Nice, those look the same as the ones I got for the front of my crew, in a different color of course. I popped the inserts off and recovered them in matching seat fabric which wasn't hard to do.
-Marcus
Project Plow Truck
Old 07-25-2016, 09:35 PM   #108
400/400
And another pic of the truck.
Old 07-25-2016, 09:39 PM   #109
400/400
Thanks. The inserts on these be ones were glued on. Is that how yours were? The factory panels had speed nuts holding them on.
Old 07-25-2016, 10:10 PM   #110
MTCK
MTCK's Avatar
Yep. I popped them off, scraped off the loose adhesive, peeled off the fabric they came with and used 3M spray adhesive to put it all back together.
-Marcus
Project Plow Truck
Old 07-26-2016, 09:37 AM   #111
y5mgisi
y5mgisi's Avatar
Nice! Is that the color the rock auto panels came in? Or did you paint them?
Old 07-26-2016, 07:37 PM   #112
400/400
That was how they came. They had different colors available. This was as close to my interior as I could get. Now I just need to decide if I want to paint the kick panels to match the new door panels or vice versa.
Old 09-08-2016, 06:42 PM   #113
400/400
Wow, just realized it's been another year of daily driving. Close to 30,000 miles on it now.
Here's a pic pulling the wheeler.
Old 09-08-2016, 07:16 PM   #114
Matt Man
Matt Man's Avatar
How is the rust repair holding up?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 09-08-2016, 07:48 PM   #115
400/400
It's holding up very well. I was pretty meticulous on the repair and painting. Also, it's very well mainted. It's frequently washed inuding the undercarriage, especially in the winter.
In the process of the repairs I figured out where the problem areas are (where salt, dirt, and moisture collect) and keep them clean.
Old 09-25-2016, 03:21 PM   #116
400/400
Recently I've noticed an intermittent hesitation when taking off from a stop. I figured out the tranny wasn't always shifting back into 1st when coming to a stop.
To fix it I started by pulling and cleaning the governor which seemed to help. I still wanted to clean & inspect the valve body as it appears the trany's never been worked on. All I've done was change the fluid & filter and install a deeper pan. I figured while I was in there I'd install a shift kit.
Got it installed and went for a test drive. It's definitely shifting back to 1st. Light throttle shifts seem the same and heavy throttle has been improved. So it was a success.
Old 10-02-2016, 09:19 PM   #117
400/400
Repacked the front wheel bearings. Also lubed the inner spindle bearing.
Spindle reinstalled and ready for the hub.
Old 10-02-2016, 09:22 PM   #118
400/400
Hubs ready to install.
Old 10-02-2016, 09:26 PM   #119
400/400
Also replaced the auto locking hubs with manual. Had a couple times going down the road below 0 last year they tried engaging themselves. So it was time for manual.
Old 10-03-2016, 12:11 AM   #120
MTCK
MTCK's Avatar
Good looking hubs! I had lots of trouble with the auto hubs on my 83. Good marketing tool, poor idea in the long run.
-Marcus
Project Plow Truck
Old 11-12-2016, 04:14 PM   #121
400/400
A few updates:
1st - The truck has had an intermittent off idle flat spot. It would only happen when accelerating after slowing down from highway speeds. After a quick check of a few things I decided to pull the cap and take a look.
Here's what I found.
Old 11-12-2016, 04:17 PM   #122
400/400
There was a lot of dust in the cap. Very strange as the distributor was rebuild less than 30,000 miles ago.
Pulled the rotor to take a look at the weights. Here's the rotor.
Old 11-12-2016, 04:21 PM   #123
400/400
Turns out the weights were wearing away. These were cheap weights but the only ones available at the local parts store when I was rebuilding the distributor.
Here's a pic of the wear.
Old 11-12-2016, 04:37 PM   #124
400/400
A reman ACDelco distributor has been installed. So far so good with that.
Next was the steering. The parts house brand reman steering gear was becoming sloppy. I decided to just replace it with an ACDelco and be done with it. Also installed an ACDelco steering pump.
To go with the steering gear, I installed a drop pitman arm. When the lift was installed, I put the raised steering arm on the axle but there was still a 2" drop from the pitman arm to the axle. This resulted in the wheels turning right as the suspension compressed. Which is most noticeable when braking or when pulling a trailer. Now the drag link is nearly level.
Old 11-13-2016, 09:00 AM   #125
LT7A
Nice lookin purpose-built rig.
