03-05-2015, 10:31 PM | #101 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Re: My suburban's Twisted Little Sister
So, am I understanding that you are building more of a Blazer than a Sub?
I like!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
03-07-2015, 02:51 AM | #102 |
Sweet I love Builds with lot's of body Mods.
03-07-2015, 02:55 PM | #103 | |||
Stay tuned. Lots of cutting and welding coming soon.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
03-09-2015, 08:27 PM | #104 |
Drilled spot welds and separated panels. The factory worker who spot welded the front drip rail was nuts. He had two or three spot welds on top of each other every inch all the way around. Taking them apart really chewed them up
03-09-2015, 09:30 PM | #105 |
Holy-S!
Really? Some real work ahead! Go for it!
03-09-2015, 10:22 PM | #106 |
1961 crewcab
interesting,,, I see a third piece sandwiched in there that I haven't seen on trucks, maybe a suburban only piece?
that might explain the extra spot welds: the inner piece was welded first, then the outer on top of that... I am curious to see what is in there.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
03-10-2015, 12:01 AM | #107 | |
03-11-2015, 09:09 PM | #108 | ||
Thanks Modges. Ya fun starts now
Here's the truck with no roof. For any one removing a suburban roof after you do all the bolts that go down into the side there is a bolt that goes up into the edge of the roof from inside the channel behind the door. There is also a weld that holds the inner roof to the roof support. Above the rear doors there are two rows of spot welds as well as a hidden one in each corner.
03-11-2015, 09:20 PM | #109 |
There is some rust around the front. Some above the A- pillars and along the sides
03-11-2015, 09:36 PM | #110 |
Before the cutting starts we removed the wood floor and then the metal floor up to the back of the doors. We also added some extra supports from the cross brace to the frame
03-11-2015, 10:07 PM | #111 |
Started the cutting on the back just to see whats inside. Found more rust of course. Cut the center post out and then separated the inner and outer panels inside the window channel
03-11-2015, 11:09 PM | #112 |
Keep the pics coming, cause that means the works progressing. Can't wait to see more.
03-12-2015, 09:07 AM | #113 |
Looking cool already
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
03-12-2015, 07:42 PM | #114 | |
Thanks reaper. First thing to go was the outer panel. The second picture shows the support between the inner and outer panels. Then we removed the inner panel. Next we did the same on the drivers side. The next step is to move the back forward to meet the front. Since the frame was in the way and is badly rusted we cut the back of the frame off.
03-12-2015, 09:58 PM | #115 |
Hmmmm, not much left.
This should be a good learning experience! I am gonna watch religiously!
03-12-2015, 11:09 PM | #116 |
Can't wait for more. Some great work going on here, really like learning. Thanks
03-13-2015, 02:38 PM | #117 |
This will be fun.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
03-13-2015, 04:09 PM | #118 |
neat! so REALLY short wheelbase, like an isuzu amigo? Love the thinking
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
03-13-2015, 04:19 PM | #119 |
Wow.... you guys putting an 8,000 hp Top Fuel Engine in that frame!!!!!
you could!!!! |
03-13-2015, 08:29 PM | #120 |
When it's all done how much of the original truck will be left- in terms of pounds? Considering that the truck weighed about 3,700 pounds new, what percentage of the original truck be left- about 25% ?
Also how % much will be weld? |
03-14-2015, 06:59 PM | #121 | |||||
We're having fun now Rusty Quote:
Friday we got the front and back pushed back together. It looks very short in the picture but the door will get extended by 16" soon. We also got the shop cleaned up a little bit
03-14-2015, 07:36 PM | #122 |
1961 crewcab
interesting so far... visually after you chop and section it ,it will appear a lot longer and lower.....
03-14-2015, 11:30 PM | #123 |
1961 crewcab
btw... I was playing with your photo in "photochop"..... as the roof comes down, the upper section of the rear window, and the door frame get longer, so don't throw any of your scrap pieces away yet!**** some of that length could be remedied by leaning the rear post a little bit
when you do the doors if you have an extra set you could cut them both long , and then longer on the top to cut down on the welding and body work..
03-15-2015, 02:05 AM | #124 |
INSANE!!! add another awesome unique build to the list that folks will be talking about for a very very long time. oh you converted a long bed into a shortbox, thats nice. bet you never converted a suburban into a coupe'!!! will that side window be a slider? i may have an extra lock...
03-15-2015, 02:23 AM | #125 |
Funny how things move on at different pace for everyone.
Yours is suddenly a light year ahead.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
