Old 04-25-2015, 12:19 PM   #101
tim's68gmc
tim's68gmc's Avatar
Re: 1968 Gmc ground up restoration
Well sense it has been raining the last two day's i decided to bring in a bed side to work on. We welded up all the trim holes and made a patch to cover the old gas door.
vehicle's I own 1968 gmc 3/4 ton camper special
1972 gmc jimmy
1972 Chevrolet nova
1947 ford 1.5 ton dully
1997 f-350 1 ton
2007 Chrysler 300 with hemi
tim's68gmc is offline   Reply With Quote
Old 04-28-2015, 08:37 PM   #102
tim's68gmc
tim's68gmc's Avatar
Did a skim coat of bondo to fill in a few little low spots
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 04-28-2015, 09:56 PM   #103
LPoole
LPoole's Avatar
this has been one of my favorite ground-up restos to follow. you guys are doing awesome work. giving me a lot of good ideas. that boy is loving helping you, you can tell. he's a good helper. reminds me of mine when he was that age.
LPoole is offline   Reply With Quote
Old 04-29-2015, 12:16 AM   #104
tim's68gmc
tim's68gmc's Avatar
Thanks Lpoole we are having a fun time working on this truck.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 04-29-2015, 01:07 AM   #105
swamp rat
swamp rat's Avatar
Ok, it looks like your able to get about 1/4" long weld beads on sheetmetal, curious what kind of wire, brand/gauge and heat/feed settings your using? Also assuming 25/75 gas mix??
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-30-2015, 08:45 AM   #106
tim's68gmc
tim's68gmc's Avatar
Originally Posted by swamp rat View Post
Ok, it looks like your able to get about 1/4" long weld beads on sheet metal, curious what kind of wire, brand/gauge and heat/feed settings your using? Also assuming 25/75 gas mix??
The wire is L-56 it is .025" and i have my temp and feed set at A for temp and 4 for speed. And yes i am using 25/75 mix. I was pushing my luck with the longer welds i did get a little warp that i worked out.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 05-07-2015, 11:44 PM   #107
tim's68gmc
tim's68gmc's Avatar
More cab sand blasting today getting closer to finishing the blasting.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 05-07-2015, 11:58 PM   #108
OlSmokey
Great work. Loving this thread. Keep it up!
OlSmokey is offline   Reply With Quote
Old 05-08-2015, 07:33 PM   #109
swamp rat
swamp rat's Avatar
What type media are you using? i keep hearing stories of warpage due to blasting.?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 05-11-2015, 10:18 AM   #110
tim's68gmc
tim's68gmc's Avatar
I have been buying media from Mclendon's and it has white sand and glass. haven't had any warping issues so far plus i try not to stand in one area to long.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 05-11-2015, 12:54 PM   #111
swamp rat
swamp rat's Avatar
Thanks, i bought some stuff at Tractor Supply in Puyallup on River Rd, they carry fine and medium grits.
http://www.tractorsupply.com/en/stor...ing-grit-50-lb
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 05-11-2015, 07:32 PM   #112
tim's68gmc
tim's68gmc's Avatar
Another place that has all kinds of media is Kleen Blast in the Tacoma tide flats.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 05-12-2015, 08:41 PM   #113
tim's68gmc
tim's68gmc's Avatar
Spent the weekend on the Oregon coast and on the way home came across a fenced off parking lot full of old cars.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 05-13-2015, 08:04 PM   #114
tim's68gmc
tim's68gmc's Avatar
Did a little work today, I rebuilt the heater box. All i need now is a new heater core and it's ready for install.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 05-18-2015, 07:58 PM   #115
1956cameo
1956cameo's Avatar
Nice project! It's gonna look great once its done.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 05-27-2015, 07:09 PM   #116
tim's68gmc
tim's68gmc's Avatar
Well took Tuesday off work and spent it building a rotisserie for the cab. It did work but will move the engine stand plate towards the firewall more due to the weight in the front is more than the back, I didn't even think about that when i put it together. Here are some pictures. After i rotated the cab i sandblasted the bottom until my last tip blew a hole in the side.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 05-27-2015, 07:13 PM   #117
tim's68gmc
tim's68gmc's Avatar
More pictures. I did find a bunch of pinholes in the passenger side rocker panel and back corner of the cab once i got a better view. So i guess i will be replacing those.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 05-27-2015, 10:14 PM   #118
swamp rat
swamp rat's Avatar
Wow! With the engine stands upright post being at a slight angle i didn't think 2 of them would allow for the ability to turn, you proved me wrong..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 06-01-2015, 09:49 PM   #119
tim's68gmc
tim's68gmc's Avatar
Saturday I Cut off and moved the engine stands 3" closer to the front of the truck so now i can roll it with out help. Today i cut off the right side rocker panel due to the holes in the bottom and found a rusted out lower door pillar. temp clamped in the new rocker panel fits pretty good will have to do some fine tuning later.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 06-01-2015, 09:51 PM   #120
tim's68gmc
tim's68gmc's Avatar
More pictures, Turned the cab onto its side made it easy to drill out the bottom spot welds
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 06-06-2015, 11:54 PM   #121
tim's68gmc
tim's68gmc's Avatar
I chose not to attach the rocker panel till i set the cab back on the frame and Aline the door and fender. So we prepped and primed the underside of the cab then applied raptor liner to the bottom.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 06-06-2015, 11:55 PM   #122
tim's68gmc
tim's68gmc's Avatar
More pictures
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 06-07-2015, 03:44 AM   #123
swamp rat
swamp rat's Avatar
Nice progress again, at least someone is making headway.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 06-07-2015, 12:05 PM   #124
karphan
karphan's Avatar
Very simple idea with the engine stands for the rotisserie. How did you attached the square tubing to the body? Spot welds or bolts? I'm at the same stage you are with doing the underside and am always looking for simple solutions. Thanks, Dan
karphan is offline   Reply With Quote
Old 06-07-2015, 12:25 PM   #125
old Chevy guy
old Chevy guy's Avatar
Just found this thread. Great job your doing and I love that your doing it with your boy, for your boy. Its a great bonding experience , I helped my son do a frame off on a first generation S10 about 5 or 6 years ago. The best part is when its all done your Son will have so much more appreciation for the truck and will take better care of it. So many people I've known just buy their kids nice stuff and don't make them work for it at all. Then all you get is the majority of them beating the crap out of the vehicle and having no remorse when it blows up or gets crashed. Nice job and great lessons learned, Life and trades experience.
old Chevy guy is offline   Reply With Quote
