Old 12-22-2015, 08:39 AM   #101
Keith Seymore
Keith Seymore's Avatar
Re: What can be said about the 4-speed New Process NV833 overdrive manual transmissio
Good call, D13. Didn't think about a Julian date.
I'm curious now, so I think I'll crawl under lil Red and check that date and also the part number.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 12-22-2015, 11:25 AM   #102
Keith Seymore
Originally Posted by aotte1 View Post
My '86 stepper came with one originally, and below are a couple of photos. I believe the shifter, boot, and knob to be original.
Correct - your shifter, boot and knob are original (appearing) for '86 and '87.
K
1979-1986
1986 - 2019
Old 12-22-2015, 01:11 PM   #103
Gregski
Post Whore
Gregski's Avatar
ok, for those of you who are just skimmnig this, my obsession with this one odd ball bolt will seam extravagant, but as soon as you take your side cover off and try to put it back on you will say, oh o, that Gregski guy was on to something
so here is a pic, the top bolt is the wierd one with the longer neck / or shoulder what ever you call it, the bottom one is like the other six
there is 10 side cover bolts total, 2 long ones, 1 odd ball one, and 7 short ones
Where does this odd ball one go?
Gregski is offline   Reply With Quote
Old 12-23-2015, 08:11 PM   #104
hatzie
Moderator
hatzie's Avatar
With a shoulder that long the case will have to be counterbored to mate with it.
You should be able to examine the bolt holes to find the one that doesn't have threads flush with the case.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 12-28-2015, 01:30 PM   #105
Gregski
Post Whore
Gregski's Avatar
ok, my turn, here is the number off of mine, I'm glad you brought it up cause I did not even notice there was a number there it was so dirty
CB1197587
sort of interesting how mine only has the one single number on that rectangle and not three like the other transmission in the thread
Old 12-28-2015, 01:47 PM   #106
Gregski
Post Whore
Gregski's Avatar
more importantly bought some shifter rods off of eBay for $120. Although I only needed the middle one I had to buy all three. At a quick glance they look identical to the ones I have, I will bolt the middle one up here shortly to see how this beauty shifts. Can't wait.
Old 12-28-2015, 02:28 PM   #107
hatzie
Moderator
hatzie's Avatar
Cool
Pick the ones with the least wear and sell the leftovers on Fleabay.
Someone is probably looking for them.
Old 12-28-2015, 02:32 PM   #108
Gregski
Post Whore
Gregski's Avatar
Originally Posted by hatzie View Post
Cool
I will wait till I install this transmission and see how it shifts, handles, feels. If I like it I may just keep the extra bits and piece together another shifter. One things for sure, the GM specific truck shifter linkage is more rare than the transmission, ha ha
Old 12-28-2015, 02:37 PM   #109
Gregski
Post Whore
Gregski's Avatar
so the good news continues, after whipping off 40 years of grease off of the new shifter rod I was able to mount it, and it fits perfect (the seller was adamant it would only fit a 4x4 and not a 2WD like mine) but I did my homework using all three Parts Illustration books you all recommended, thank you and took a chance, well it paid off
please note the small rectangular bracket on ours says 3rd and OD as in Over Drive instead of 3rd and 4th gear like the Mopar ones do, is it more than just text on the metal, does it signify a different cut out / angle for the shifter, who knows, just reporting the facts
I will share pics off all three shifter brackets next, but here is the one I was missing, it's the middle one, fits like a glove
Old 12-28-2015, 02:42 PM   #110
Gregski
Post Whore
Gregski's Avatar
here are all the three LEVERS as they are called in the parts book, the rectangular pieces that are about 1 inch by 2 1/2 inches, they are not all the same,
the insert cut out for the bolt is on a different angle on each, impossible to see in my pics as it is hidden behind the washer, but I will share some more detailed pics later
also the 1st & 2nd gear one is flat, the 3rd & OD gear one is flat, the Reverse gear one is offset by about 1/8 of an inch
I share this stuff in great detail, in case someone finds themselves needing to make these from scratch, maybe they can make them for themselves, maybe sell them to others
Old 12-28-2015, 03:04 PM   #111
Keith Seymore
Make sense since there was some trickery employed to create the overdrive.
Actually third gear is reconfigured to .73:1, and fourth gear is 1:1, so the arm is "flipped" (I'm told) so that you fake the shifter out into thinking it is a traditional "H" pattern. Otherwise you'd have to shift into 4th for straight up and "downshift" into 3rd to get overdrive.
Flipping the linkage makes it transparent to the driver.
K
1979-1986
1986 - 2019
Old 12-28-2015, 03:45 PM   #112
hatzie
Moderator
hatzie's Avatar
please note the small rectangular bracket on ours says 3rd and OD as in Over Drive instead of 3rd and 4th gear like the Mopar ones do, is it more than just text on the metal, does it signify a different cut out / angle for the shifter, who knows, just reporting the facts.
I believe that's specific to the OD version of the A833 not just the GM variant. I've seen 3 of the Mopar A833 OD variants in base model early 80's D150 Ram trucks. They all used the same "flipped upside down 3-4 lever" trick as the GM A833 OD gearboxes. I can't remember whether they were marked 3 & OD on one side or not... likely they were.
Old 12-28-2015, 07:20 PM   #113
Gregski
Post Whore
Gregski's Avatar
here is a better look at the special cut outs in the LEVERS I mentioned earlier
1 & 2 Lever appears to be straight up and down like 12 o'clock
3 & OD Lever is upside down and appears to be angled like 2:00 o'clock
Reverse Lever appears to be angled like 1: o'clock
Old 12-28-2015, 07:23 PM   #114
Gregski
Post Whore
Gregski's Avatar
I swear I thought something rattlin' loose in that there transmission, I may have knocked something off upon my initial disassembly or it may have been like that from the git go, I don't know, but today I was determined to seek and find it, and so I did
and this is what I found at the bottom of the beast, question now is where do it go?
Old 12-28-2015, 09:11 PM   #115
Gregski
Post Whore
Gregski's Avatar
Well I found out what it is, though I had to go to the 1985-86 Illustration Catalog to look up the MY6 transmission schematic as the 1979-84 did not show this piece, I guess you shifted in to reverse with pixie dust in those years.
It is called a Reverse Interlock Link and along with it I found the Reverse Interlock Link Retaining Pin at the buttom of my trans attached to the magnet that's why it didn't make no rattlin sound.
The piece goes on the backside of the side cover.
Not too pleased with the way the pin goes in, I just tapped it in with a hammer, this may need revisiting.
Old 12-28-2015, 09:14 PM   #116
Gregski
Post Whore
Gregski's Avatar
well even with the RIL back in position I still couldn't shift into reverse and I decided the shifter itself was to blame, so I decided to divorce it from the bracket
two bolts, of different sizes
Old 12-28-2015, 09:17 PM   #117
Gregski
Post Whore
Gregski's Avatar
still not happy that I had to wedge a large flat screw driver to get the darn shifter stick to pop into reverse I decided to take it all apart, it needed a cleaning anyway, as I could hear sand grinding in there
Then Monday Night Football was about to start, so I decided to call it a day
Old 12-29-2015, 02:54 AM   #118
Gregski
Post Whore
Gregski's Avatar
Excellent video on how to rebuild the Hurst Competition Plus shifter, by The Man himself
https://www.youtube.com/watch?v=huUETRzXM7k
Old 12-29-2015, 10:17 AM   #119
Keith Seymore
Which "man" is that?
I was expecting either George Hurst or Jack "Doc" Watson (the "Shifty Doctor").
K
1979-1986
1986 - 2019
Old 12-29-2015, 12:04 PM   #120
Gregski
Post Whore
Gregski's Avatar
K
Sorry to disappoint Keith, he did write the book on how to rebuild the manual transmissions that we see all over the Internet, plus the man has a soul patch, ha ha
Old 12-29-2015, 01:55 PM   #121
hatzie
Moderator
hatzie's Avatar
A couple points I don't like about how he does this.
He re-uses the roll pins. I would never do that. They're usually fairly cheap and they loose some tension when you drive them through. You don't want em walking through when you're driving.
GM Hurst etc used Nylok nuts for a reason. Loctite may work OK but I've had fasteners with Loctite come loose where Nyloks will stay in place.
I wouldn't recommend hardened relay rod bushings. The main reason to have soft plastic relay rod bushings is they wear instead of the rod ends, shifter paddles or, the transmission levers. The Pit Pack with nylon bushings is pretty cheap.
Old 12-29-2015, 02:16 PM   #122
Gregski
Post Whore
Gregski's Avatar
I concur, same rule of thumb as cotter pins.
From what I saw he reused the single Nylok nut.
Yeah, I thought that too, those plastic bushings are the sacrificial part, if you replace them with a part that is tougher than the other parts, then your other parts will wear out instead of the part that is meant to wear out.
But than again, he builds race transmissions and not your grocery getters, so there may be a reason, probably tighter fittings, more sturdyability, and race cars are driven less than daylies so the parts can last just fine. Honestly I don't know. ha ha
Old 01-01-2016, 02:24 PM   #123
walkerb
walkerb's Avatar
Gregski, I'm guessing this is the bolt. It's the bolt in the middle at the back of the cover. Inline with the two shifting forks, again towards the rear of the cover
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 01-01-2016, 02:55 PM   #124
Gregski
Post Whore
Gregski's Avatar
thank you so much, for some reason mine would not fit through the hole in the lid in that spot, but the case did have a deeper hole in that spot, thanks again I will clean the hole in the lid and it should go back in
Old 01-02-2016, 05:59 PM   #125
walkerb
walkerb's Avatar
It's been awhile since I've had a side cover off so I can remember if my Saginaw fork looked like this.
Is this wear acceptable?
