Old 11-01-2017, 03:46 AM   #101
MTCK
MTCK's Avatar
Re: 1984 K30 Project Plow Truck
My one good set of brackets modified to eliminate the stone guards and new straps installed. A buddy brought me a clean used set off a parts truck to make up the other side.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 11-01-2017, 12:28 PM   #102
MTCK
MTCK's Avatar
Plow truck is getting to spend a few days in the camper garage while the frame is prepared for the new bed.
-Marcus
Project Plow Truck
Old 11-01-2017, 12:30 PM   #103
daddyjeep
daddyjeep's Avatar
That bed liner should be a good solution on the tanks. I just did a bunch of coats of rubberized undercoat on mine, but mine will see limited winter driving.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 11-01-2017, 12:31 PM   #104
MTCK
MTCK's Avatar
Flapper wheel, wire brush and lots of elbow grease got it “ready”.
-Marcus
Project Plow Truck
Old 11-01-2017, 12:34 PM   #105
MTCK
MTCK's Avatar
Shot the frame, springs, rear end etc with a quart of zero rust. Conditions were not ideal.
-Marcus
Project Plow Truck
Old 11-01-2017, 12:39 PM   #106
MTCK
MTCK's Avatar
Seems to have taken fairly well though. Mounted the rear shocks and prepped the tanks.
-Marcus
Project Plow Truck
Old 11-01-2017, 12:40 PM   #107
MTCK
MTCK's Avatar
Used carriage bolts instead of rivets on the straps.
-Marcus
Project Plow Truck
Old 11-01-2017, 01:35 PM   #108
MTCK
MTCK's Avatar
Ready to hang tanks which takes us to today.
-Marcus
Project Plow Truck
Old 11-01-2017, 03:07 PM   #109
jhama78
jhama78's Avatar
Better get that thing done, termination dust is looming im sure!!
Did you ever decide what color you are going to go with when you paint it?
-j-rod
'06 3500 LWB CC 4wd, 8.1 Allison
jhama78 is offline   Reply With Quote
Old 11-01-2017, 07:47 PM   #110
BossH0G
BossH0G's Avatar
Looking good, keep up the good work.
BossH0G is offline   Reply With Quote
Old 11-02-2017, 01:26 AM   #111
whitels1
whitels1's Avatar
Hell yes man, frame looks great!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 11-02-2017, 03:10 AM   #112
MTCK
MTCK's Avatar
Jrod I’m pedaling as fast as I can! have not thought about paint yet but soon. May need to let the bank heal up a month or two after buying all the little stuff for this upgrade and the camper garage. We will see what the CEO/CFO says...
Thanks guys. I’m ready to drive it. Fuel selector looks nothing like the original, but all the connections are the same. Says it’s rated to 65 psi interestingly enough. No return lines. Maybe you just take the caps off...
-Marcus
Project Plow Truck
Old 11-03-2017, 03:49 AM   #113
MTCK
MTCK's Avatar
Should be able to throw the bed on tomorrow. Tanks are hung and plumbed. Still have a little work to do on the hitch and bumper but we are getting close.
-Marcus
Project Plow Truck
Old 11-04-2017, 03:43 AM   #114
MTCK
MTCK's Avatar
Progress.
-Marcus
Project Plow Truck
Old 11-07-2017, 12:32 AM   #115
MTCK
MTCK's Avatar
Finally. Both tanks work. Both gauges work. Spare tire, bumper and hitch are all mounted. I need some ballast for the rear, mud flaps and proper fuel fill hardware and hoses.
-Marcus
Project Plow Truck
Old 11-07-2017, 05:23 AM   #116
Jaysonb
Jaysonb's Avatar
Looks good Marcus! I would love a k30. I wonder how long it will be before you wish you still had a flatbed on something....
Jaysonb is offline   Reply With Quote
Old 11-07-2017, 01:44 PM   #117
jhama78
jhama78's Avatar
Looks good Marcus, what are you gonna do for rear ballast? 55 gallon drums of water/ice?
-j-rod
Old 11-07-2017, 02:59 PM   #118
sweetk30
sweetk30's Avatar
15" tall 3/8 or 1/2" thick i dont recall 9ft I-beam cut in 2 and set side by side and welded up is my ballest weight .
500-550 lbs of weight .
i added 2 weld on d-rings to secure it to the bed with heavy ratchet straps.
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-08-2017, 06:02 AM   #119
MTCK
MTCK's Avatar
Thanks guys. This season I’ll probably just use some sand bags. Ideally I’d like something like sweetk30 has or plate steel with good tie downs.
Hauled a load of trash tonight, filled both tanks and cruised around a bit. Ride is great with the kyb shocks. Fronts were actually original. No bangs or driveshaft vibrations. I️ really like driving it.
-Marcus
Project Plow Truck
Old 11-13-2017, 01:49 AM   #120
MTCK
MTCK's Avatar
Oh boy...
-Marcus
Project Plow Truck
Old 11-13-2017, 10:46 AM   #121
jhama78
jhama78's Avatar
I hope you have them plugged in.
-j-rod
Old 11-13-2017, 07:39 PM   #122
MTCK
MTCK's Avatar
Still warm, thankfully! +25 or so in that pic. Sub zero by Thursday.
-Marcus
Project Plow Truck
Old 11-13-2017, 08:21 PM   #123
cochino12
It followed me home?
cochino12's Avatar
Would you mind sending some of that snow my way? thanks haha
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 11-16-2017, 04:53 PM   #124
Indyfab
Indyfab's Avatar
Really enjoying both your builds, especially your crew. Makes rethink changing the color on mine, lol. You wouldn’t happen to be able to measure your crews headliner size? Mines in the exhaust shop, about an hour from home and I’m wanting to order fabric that matches my seat upholstery I just ordered. Thanks in advance.
Indyfab is offline   Reply With Quote
Old 12-16-2017, 11:11 PM   #125
MTCK
MTCK's Avatar
Hey sorry Indyfab, I haven’t been on here in a bit. Do you still need the measurements? Let me know if so and I’ll grab them.
Took almost three weeks, but ups finally delivered all the boxes for my back rack. I also have some led floods, a strobe and strobe mount bracket that I need to install and wire.
-Marcus
Project Plow Truck
