Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 06-13-2018, 08:13 PM   #101
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Re: 1979 Chevrolet C70 Conversion to OEM Air Conditioning
You're welcome, we did our best to locate things when I worked at the parts store and that stuck with me. I look up my own parts before I go to the store to avoid unnecessary headaches haha. Seems like that fan would work, the 2" difference in diameter shouldn't hinder the cooling any I would think. The depth that the fan goes into the shroud is important for sure. The height of the 2797 clutch is about 3 5/8" roughly. The bolt spacing for mounting the clutch to the pulley/pump is 2.5".
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 06-13-2018, 11:58 PM   #102
Airdirect
I need to measure the depth to make sure I have room for it. I will take some more measurements and post the results.
Thanks Robert!
Airdirect is offline   Reply With Quote
Old 06-26-2018, 01:38 AM   #103
Airdirect
Shortened the frame back to its original wheelbase (203 in).
Old 07-06-2018, 12:59 AM   #104
Airdirect
Been going through the brake system replacing wheel cylinders and hoses. I have also taken the opportunity to strip and prepare to repaint the Dayton hubs. I have new tubeless 11 - 22.5 rims and radial tires ready to be installed. I wanted to keep the original 9.00 - 20 rims, however radial tires for them were almost impossible to find and very expensive. I know in the long run the tubeless is a much better option.
Old 07-10-2018, 01:54 AM   #105
Airdirect
Continuing to make progress on the brakes. Front brakes, master cylinder, and hoses are finished. The passenger side rear is ready to have the drum reinstalled and it will be finished.
Old 07-10-2018, 02:00 AM   #106
Airdirect
New front brake lines:
Old 07-10-2018, 02:04 AM   #107
Airdirect
Can anyone tell me what the sender on the Secondary fuel filter does? It has a single wire going to it. I assume it applies a ground when the pressure reaches a given threshold. I have grounded the terminal and do not get any light showing on the dash. I have reviewed the wire schematics and do not find any information about it.
Old 07-11-2018, 06:04 PM   #108
gmtech68
On our 8V71 's at work it is connected to a circuit that allows the engine to stay running. No fuel pressure; shuts off. However those engines have a Woodward hydraulic governor. Yours does not. May also be used as a "run" circuit to send power to various things to signal the engine is running. It has been a while since I've had to mess with that engine. Pretty reliable.
gmtech68 is offline   Reply With Quote
Old 07-18-2018, 11:05 AM   #109
Airdirect
Finishing up the last brake. Here is a picture showing my sons Micah and Noah learning how to reinstall the rear brake shoes. They were fascinated with how the brake spring installation tool worked. In this picture they are installing the lock rings on the brake shoe retainer castle nut.
Old 07-18-2018, 11:33 PM   #110
jumpsoffrock
Can you post a picture and hopefully a part number of the brake spring tool you used?
When disassembling my C50 brakes I used big ass sheetmetal pliers but it was not fun.
Thank you.
jumpsoffrock is offline   Reply With Quote
Old 07-19-2018, 12:55 AM   #111
Airdirect
Thank you.
Here is a picture. It makes spring removal and installation a breeze. No effort required.
Old 07-27-2018, 02:12 PM   #112
Airdirect
Finished brakes, installed new rear transmission seal and parking brake shoes. Installed new front shocks, my sons Noah and Micah stripped and repainted the front and rear hubs and clamps. Installed new tubeless rims and tires (11.00R 22.5 radials) Next step is to acquire a bed and we will be ready to haul.
Old 07-27-2018, 02:18 PM   #113
Airdirect
Drove the truck to town and got it inspected and licensed. The truck rides terrible with the new tires. The air pressure is 85 psi. The old bias ply tires rode much smoother. The left rear duels wobble just a bit, will have to loosen and re tighten them to see if I can correct. I sure hope the bed weight will smooth things out! Any ideas?
Old 07-28-2018, 03:13 PM   #114
Best thing to do is jack up the front/rear and spin the tires by hand and check for run-out. We had that happen on our old '79 Ford L8000 water truck at the fire department. The front wheels were actually worse, when I looked out the driver's door while rolling I could see the tire/wheel wobbling in and out. Local tire shop apparently never worked with Dayton wheels before. I'm actually going to look at a 1989 C70 cab and chassis next weekend if they don't sell it by then. Has a 366 and a 5+2, has the same wheels but it has 10.00-20 tires.
RJD
Old 07-29-2018, 11:30 AM   #115
Airdirect
Thanks Robert, I will jack it up and check the run out. Hopefully that will fix the problem. I hope it is not a bad tire. I still need to get the A/C fan clutch installed. I am sure it will reduce load on the engine and noise. The current fan is fixed and very noisy. With a Detroit Diesel cooling is not much of a problem. I cannot imagine why GM did not make the clutch standard on this model. Thanks for all your input!
Old 08-09-2018, 11:27 PM   #116
Airdirect
I am having trouble with my new Accuride de-mountable rims. The part of the rim that clamps to the wheel runs true. However the outer rim wobbles. It appears that when the welded the clamp ring to the wheel they did not have it square. Anyone else had problems with Accuride rims?
Old 08-29-2018, 01:19 PM   #117
DT3Ton
Thanks for documenting this so well.
Were the AC donor parts from a pickup or MDT? I would like to add air to my crew cab.
DT3Ton is offline   Reply With Quote
Old 08-30-2018, 01:16 PM   #118
gmtech68
Find an experienced tire guy. It is part art, part skill to tighten clamp nuts so the wheel runs true.
Old 08-31-2018, 05:47 PM   #119
Airdirect
The parts were from both a C65 and 70's pickup. The evaporator and heater core are all the same. The parts that are unique to the 2 ton are the vent distribution in the dash and the mode selector control (no bi-level mode on the truck). I believe that a pickup unit would work, you would just have to use hose instead of the molded plastic parts to distribute the air to the drivers side of the dash. I am not totally sure as I was able to rob those parts from the C65. I know the heater floor distribution is different. I reinstalled my original heater floor distribution unit and it mated up with the pickup evaporator housing. The pickup condenser is very similar and can be made to work. The lines on it are aluminum where the C65 used steel. Hope this helps.
David
Old 08-31-2018, 05:50 PM   #120
Airdirect
Thanks!
Old 08-31-2018, 06:05 PM   #121
Airdirect
More progress. I am purchasing a Jerr-Dan rollback bed off a wrecked GMC/Chevy Medium Duty truck. The bed has been removed and is being prepped for installation. The bed was purchased from Jon Wickham and Associates, a Danco Products dealer in the Dallas area (jonwickham.com).
Old 09-01-2018, 12:18 AM   #122
Airdirect
Picture taken by Jon Wickham & Associates of the truck awaiting bed installation.
https://www.facebook.com/jonwickhama...ciates/photos/
Old 09-06-2018, 11:51 PM   #123
jumpsoffrock
What is the bed Weight? I am so envious..lol
Man that's gonna be one sick truck.
Old 09-12-2018, 10:19 PM   #124
Airdirect
I weighed the truck, without the bed it was 9,600 lbs. I do not know what the bed weighs.
Old 09-12-2018, 10:38 PM   #125
Airdirect
PTO is installed, awaiting hydraulic pump which will be bolted to the flange.
add oem air conditioning
