Old 06-17-2017, 06:27 PM   #101
FAKKY
Re: 57 Panel "FAKMLC" build
Hope to measure backspacing and order some wheels and tires.
Get this firewall finished and sand everything back and paint it.
FAKKY is offline   Reply With Quote
Old 06-17-2017, 06:58 PM   #102
FAKKY
I assume since I'm going to be running an auto might as well pull the clutch and weld up that hole.
Also ... are most guys use the same brake pedal/accelerator holes ...... doing a 5.3 swap ..... unsure of DWC or DBW as yet..... not sure if it matters?
Finally ..... cant remember what the large hole at pic/post #44 was ..... thing it was a bracket for the starter mechanism ..... anyone confirm ?
thx
Old 06-20-2017, 12:48 PM   #103
FAKKY
http://67-72chevytrucks.com/vboard/s...d.php?t=740604
linkback to a radiator thread for myself/others following
FAKKY 57 PANEL BUILD
Old 06-20-2017, 12:52 PM   #104
FAKKY
Got most of the holes I wanted filled.
Would like to have done a few more but don't know what I need yet. Hate to weld it then redrill it.
Not a show truck .... This should do
Old 06-24-2017, 05:23 PM   #105
FAKKY
Bought and test fitted these. 235/75/R15 8" wide with -19 offset.
Wouldnt call them my favourite wheel/tire combo ...... but for $500 new all the way around ..... going to swing with them. Actuallhy like the whitewall ring.
Plan is to get the other 3 this week ........ and maybe source a steering shaft and get steering hooked in.
I'll have 4 days off so really want to get the sanding and painting of front end done over that time.
Then wiring or brakes.
Old 06-24-2017, 11:18 PM   #106
59chev
59chev's Avatar
Looks great. I like the skinny whitewall. I will be running black 5 spokes with skinny whites on my 59 when it is back on the road.
My Build Thread: 59 Apache - Lifelong obsession
http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession
59chev is offline   Reply With Quote
Old 06-25-2017, 12:01 PM   #107
yossarian19
Looking good.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 07-02-2017, 08:00 AM   #108
FAKKY
Old 07-02-2017, 08:36 AM   #109
FAKKY
https://goo.gl/photos/i7hyxrfZPgcSpVtL6
Old 08-26-2017, 05:29 PM   #110
FAKKY
Haven't done much due to heat and other 'life' things. But need to get back on it.
Got the steering column bracket removed - and put the S10 one I pulled from a junkyard in place - but dont like it for fitment at all.
http://imgur.com/lensciM
So going to go with the CPP 5559FMB kit.
http://www.classicperform.com/Instru...structions.pdf
Outside of that ...... need to order gauges. Either speedhut or dakota. Waiting for labor day specials to decide but likely going to pony up and buy
http://www.dakotadigital.com/index.c...rod/prd737.htm
Then since IM dropping all this coin which I dont have ...... still toying around with the idea of the steering column. Reusing stock and slicing a few lines on end to flare out and place bearing, and reweld.... or just go ididit. If I can find a half decent sale I will likley go with a 32" universal tilt.
https://www.summitracing.com/parts/i...RoCu4kQAvD_BwE
Only problem with that is getting the stock steering wheel which my wife loves to work with the turn signal cancel ........ not sure exactly all thats required here but did see a video on this somewhere.
Some questions
What are you guys using for steering wheel .......pic ?
What did you use for firewall holes you didnt fill to block off ? Have a few I didnt fill in case I needed for running electrical or other. Curious.
Old 04-26-2018, 02:50 PM   #111
FAKKY
Getting back on this
Just bought a Hummer H2 LQ4 with a 4WD 4l65e.
http://67-72chevytrucks.com/vboard/s...23#post8248323
Will be tearing this apart myself (or) with a buddy who owns a diesel shop a ways away.
Old 04-28-2018, 01:02 PM   #112
FAKKY
Old 04-28-2018, 01:04 PM   #113
FAKKY
Brake/steering bracket is a good fit.
Need to cut and adjust hydroboost rod.
Old 04-28-2018, 01:04 PM   #114
FAKKY
Old 04-28-2018, 01:05 PM   #115
FAKKY
Tack weld and putting in patch panel for rust
Old 04-28-2018, 01:07 PM   #116
FAKKY
Old 04-28-2018, 01:11 PM   #117
FAKKY
Wife gave her another two coats of the Rust-Oleum $50
Old 04-28-2018, 01:37 PM   #118
FAKKY
Question
When I see videos of people doing patch panels they single bead it all the way around.
If its not structural - can you just tack it in all corners and then use a fiberglass patch to seal , level and strengthen ?
tacking it the way around will take some time and also look messy so need to spend lot of time grinding back also ........
probably not - but curious.
Ill be adding a bondo fibreglass repair over the top to smooth out all the tack welds and level out anyway ?
shrug
Old 04-28-2018, 03:26 PM   #119
FAKKY
tacked it all in and ground it down and checked underside and only see a couple pinholes Ill try and fix up.
wasnt too bad
Thats the step done. Just need to cut and measure the door hinge and do that and I *think* thats about all the body work I have to do.
Old 04-29-2018, 08:15 AM   #120
BIGglaSS
BIGglaSS's Avatar
That's back yard hack. No reputable professional restoration shop would do this.
The BEST way, keep filling the pinholes. Grind, sand, file, etc. Blast off any remaining silicon slag. Then epoxy. If there are any microscopic holes remaining, fill with a dab of epoxy. Then use a quality filler. The repair will be waterproof from the backside.
BIGglaSS is offline   Reply With Quote
Old 04-29-2018, 08:29 AM   #121
FAKKY
Thx
Figured ....but thought I'd ask anyway
Old 05-02-2018, 10:32 PM   #122
FAKKY
Engine and trans I picked up today ......LQ4/4L65e
Anyone got recommendations on who does a good rewire for LS harnesses
Will start teardown on trans soon for output shaft swap.
Old 05-05-2018, 04:22 PM   #123
FAKKY
Old 05-07-2018, 07:55 PM   #124
FAKKY
Did a mock fitup to see if trans tunnel was going to be a problem before I pull it and seperate the trans and rebuild/2wd convert it.
Not sure - what do you guys think.
From above still a slight angle front to back.
Old 05-07-2018, 07:56 PM   #125
FAKKY
clearance at back
