Old 03-31-2017, 07:20 PM   #101
rsmarr1982
rsmarr1982's Avatar
Re: 72 c30 longhorn parting
Originally Posted by undertaker72 View Post
yes and I know the steering wheel has cracks but I wanted it also , so can you figer that and ship together
Pics
1969 chevy c10 lwb stepside 250 6 3 ott
1971 chevy c10 lwb 250 6 with power steering 3 ott
1972 chevy k20 4x4 350/TH350 automatic
1978 chevy Malibu 4dr 305 2bbl (all original)
1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver)
rsmarr1982 is offline   Reply With Quote
Old 04-01-2017, 08:01 PM   #102
bulky
Bulky
bulky's Avatar
Originally Posted by rsmarr1982 View Post
Sorry had to take a break from the truck for family things. Battery tray, wiring, junction blocks, fuel switch , washer bottle bracket, filler neck sold to Dave. Dirt's72 I will take pics of fuel line and cluster tonight. Undertaker72 I will get pics of steering will tonight as well. I will accept bulky's offer on the air horn.
PM sent
2016 Silverado
1930 Model A Hot Rod
1923 Ford A/SR Altered - Injected 409
1982 Honda CB900F Super Sport
Dad's 1970 GMC 9' Stepside
Dad's 1969 GMC Custom Camper
bulky is offline   Reply With Quote
Old 04-03-2017, 06:53 AM   #103
spitfire980
spitfire980's Avatar
Do you have these?
spitfire980 is offline   Reply With Quote
Old 04-03-2017, 06:47 PM   #104
rsmarr1982
rsmarr1982's Avatar
Originally Posted by crossjo View Post
Do you have these two A/C ducts and also do you still have the horns? Thanks.
Yes I have them but , #13 has a crack where it fits over #12
Old 04-03-2017, 06:48 PM   #105
rsmarr1982
rsmarr1982's Avatar
Originally Posted by spitfire980 View Post
Do you have these?
No I don't have those
Old 04-03-2017, 06:51 PM   #106
rsmarr1982
rsmarr1982's Avatar
Originally Posted by Dirt's72 View Post
Thanks. Still interested in the cluster as well. Pic of crack? Fuel line from pump to carb?
Cluster was missing a whole corner I took it a part to fix my own cluster. Here are pics of the fuel line . Are you still interested in the shroud?
Old 04-03-2017, 07:29 PM   #107
rsmarr1982
rsmarr1982's Avatar
Parts still avalible :
Big block Alternator brackets $100 shipped sold
Big block Power steering brackets and pump $85 shipped sold
Big block Crank pulley and water pump pulley $65 shipped
Big block fan shroud $125 shipped.sold
Solid high hump trans tunnel for automatic $100 shipped
Big block 72 quadrajet #7042206 $150 shipped
Big block 1972 402 , has int/ext. Manifolds and flywheel $750.
Big block 72 engine perches and clam shells with bolts $150 shipped
Old 04-03-2017, 07:33 PM   #108
rsmarr1982
rsmarr1982's Avatar
Pics2
Old 04-03-2017, 08:13 PM   #109
Dirt's72
Yes fuel line and shroud shipped to 87114?
Dirt's72 is offline   Reply With Quote
Old 04-03-2017, 08:28 PM   #110
rsmarr1982
rsmarr1982's Avatar
$115 shipped
Old 04-03-2017, 08:51 PM   #111
Dirt's72
Sounds good.
Old 04-03-2017, 09:21 PM   #112
bulky
Bulky
bulky's Avatar
Interested in the alternator brackets, PM sent.
2016 Silverado
Old 04-03-2017, 11:00 PM   #113
72k5zl1
72k5zl1's Avatar
interested in hi hump and all of the clutch linkage between pedal and fork. need motor pivot and frame pivot also. thanks
my build threads, 68 pro touring, auto cross c10 (mid life crisis)
http://67-72chevytrucks.com/vboard/s...d.php?t=464109
website http://www.sauersgarage.com/
72k5zl1 is offline   Reply With Quote
Old 04-04-2017, 12:27 AM   #114
BlueBoy72
Active Member
Interested in lower retaining clips for fan shroud .
BlueBoy72 is offline   Reply With Quote
Old 04-04-2017, 12:50 AM   #115
jpgl
Junior Member
power steering system include the reservoir? if so i am interested.
jpgl is offline   Reply With Quote
Old 04-04-2017, 03:39 PM   #116
b.sharp
b.sharp's Avatar
pm sent about frame.
b.sharp is offline   Reply With Quote
Old 04-04-2017, 08:54 PM   #117
72swbcamo
Active Member
I have a C-30 that the cross member just before the rear differential is rotting away. Would you be interested in removing this crossmember from the frame and selling it? If you are planning on leaving the frame intact I can understand that. I'll try to get a picture of the crossmember i am interested in.
72swbcamo is offline   Reply With Quote
Old 04-04-2017, 09:50 PM   #118
rsmarr1982
rsmarr1982's Avatar
clips are gone sorry
Old 04-04-2017, 09:51 PM   #119
rsmarr1982
rsmarr1982's Avatar
sorry frame was rusted bad in the rear, nothing left of it sorry.
Old 04-04-2017, 09:52 PM   #120
rsmarr1982
rsmarr1982's Avatar
frame is shot and was scrapped sorry
Old 04-04-2017, 09:52 PM   #121
rsmarr1982
rsmarr1982's Avatar
yes it is included
Old 04-04-2017, 10:25 PM   #122
rsmarr1982
rsmarr1982's Avatar
radio, speaker and power wire sold to dave.
Old 04-04-2017, 11:06 PM   #123
jpgl
Junior Member
i will take the power steering setup sent you a message.
Old 04-04-2017, 11:44 PM   #124
72swbcamo
Active Member
Thanks for your reply.
Old 04-05-2017, 11:08 PM   #125
feller
feller's Avatar
Is the cab getting cut?
feller is offline   Reply With Quote
