Old 06-15-2019, 09:25 PM   #101
Madkidd007
Madkidd007's Avatar
Re: Project “Blue Bomb” (rebirth of a 1970 c30)
Originally Posted by 68bowtie View Post
If I had known what a pain it would be to install an edelbrock on a stock cast iron sbc manifold I wouldn't have done it. But the carb was free and I learned a few things along the way in addition to how to do a carb rebuild.
I read that I needed a spacer to keep the carb from overheating. Bought one, and learned that Square bore and Spread bore are not the same. So then I needed an adapter plate kit. The one I bought wasn't machined properly so I had to grind down the bolt heads so they fit into the adapter plate. The carb studs were cheap-o and I stripped one. So I got a better quality set and installed them (after the pic below).
Attachment 1911785
Attachment 1911786
Attachment 1911787
Not that it matters now. But if you have to do this again or end up with a vacuum leak. You could just drill out the holes in the spacer and run long studs all the way from the intake thru the spacer and carb. Also a “base gasket” is what I used to run, thicker and less prone to leaks while spacing the carb up. Looks like you’ve got it handled but just sharing thoughts if you end up redoing the setup or a leak arises
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 06-16-2019, 12:24 AM   #102
68bowtie
68bowtie's Avatar
Great point!
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
Old 07-19-2019, 08:22 PM   #103
68bowtie
68bowtie's Avatar
Carb installed.
Gear oil.
Brakes bled.
Tail lights installed.
Not 100% finished... but it's driving again!
Old 07-20-2019, 09:37 AM   #104
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks good, I'm glad you got it drivable.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Ol Blue K20 is online now   Reply With Quote
Old 07-20-2019, 03:22 PM   #105
Madkidd007
Madkidd007's Avatar
This really makes me wish i still had my 69 C30 but you can only drive so many vehicles at once.
Old 07-22-2019, 04:06 PM   #106
rustytruck50
rustytruck50's Avatar
That's one of the most satisfying feelings, after alot of sweating, swearing, etc
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 07-26-2019, 01:15 AM   #107
68bowtie
68bowtie's Avatar
For my wife (she is from Texas)
Old 08-04-2019, 11:17 PM   #108
68bowtie
68bowtie's Avatar
Flaps are in. Just need to fab up some brackets...
Old 08-05-2019, 09:01 AM   #109
Ol Blue K20
Those are going to look nice.
Dale
Old 11-02-2019, 12:34 PM   #110
68bowtie
68bowtie's Avatar
It’s bed time boys and girls…
Old 11-02-2019, 11:10 PM   #111
68bowtie
68bowtie's Avatar
Didn’t quite get as much done as I wanted today, but made some decent progress. Just need to weld up a few more tacks and prep the rear brace, which will be bolted in place to box in the wood. Tried to keep everything as low profile as possible, and tight with the outer tire width.
Old 11-03-2019, 11:24 AM   #112
cornerstone
cornerstone's Avatar
LOVE this truck! And of course God bless Texas.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 11-09-2019, 11:21 PM   #113
68bowtie
68bowtie's Avatar
Made some more progress today. Rear brace is installed (removable for wood access), welded on d-rings, drilled holes for all the lights, and did some light sanding to get off the mill scale. Halfway installed the class IV receiver. Of course I ran out of weld wire in the middle of everything, but you gotta expect things like that.
Old 11-10-2019, 08:49 PM   #114
CG
BlahBlahBlah
Great job. I really like this truck!
Old 11-10-2019, 09:14 PM   #115
68bowtie
68bowtie's Avatar
Thanks guys!
Old 11-11-2019, 08:13 AM   #116
Ol Blue K20
Nice work it's looking great. I can't wait to see some wood on it.
Dale
Old 11-17-2019, 09:10 PM   #117
68bowtie
68bowtie's Avatar
7'x11' +/-
Old 11-17-2019, 09:55 PM   #118
3757chevy
3757chevy's Avatar
Very Nice! Been worth watching this thread , Thanks for the updates.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 11-17-2019, 10:06 PM   #119
flashed
Wow , the bed turned out nice , just need a Headache Rack to keep that cab nice .
flashed is offline   Reply With Quote
Old 11-17-2019, 10:20 PM   #120
AJohn6
Knuckle head
AJohn6's Avatar
The C30 looks amazing. I wished I could have found one nearby for a reasonable price. I am doing a C10 on a 2014 1-ton chassis instead and my on the 1-ton chassis is a ratty rust bucket. Haha
Keep up the great work!
Adam
'71 SWB/Step http://67-72chevytrucks.com/vboard/s...d.php?t=291750
2017 Crew Cab Silverado LTZ with 6.2l, 8 Speed tuned by RPM in Garner, NC
'00 Chevy 1500 6.0l Silverado Reg. Cab Short Bed
'09 Chevy 1500 5.3l Silverado Crew Cab Short Bed (SOLD)
1971 LWB on 2014 1 ton chassis, L96 6.0LS / 6L90E http://67-72chevytrucks.com/vboard/s...d.php?t=796785
1969 LWB C10- Future project, possible AWD C10 on a 2002 Escalade Chassis.
AJohn6 is offline   Reply With Quote
Old 11-17-2019, 10:20 PM   #121
3757chevy
3757chevy's Avatar
Somethin' where you can still see that cab.
MIKE
Old 11-21-2019, 07:40 PM   #122
rustytruck50
Good looking truck..the effort has definitely paid off!
-Doug
'05 RCSB Sierra 2WD
Old 11-22-2019, 10:11 AM   #123
The bed came out really nice. A super nice truck!
Old 11-22-2019, 11:18 AM   #124
cornerstone
You've really made this a special truck. I'd love to have that as a daily driver.
Brian
Old 12-14-2019, 09:05 PM   #125
68bowtie
68bowtie's Avatar
Thanks everyone.
Finally reinstalled fender emblems (blech). What a pain. Had to recruit my wife to help at one point (small hands).
Also, discovered a pinhole heater core leak, so got that going too.
