08-26-2020, 11:48 AM | #101 | |
Post Whore
Re: What kind of gas mileage do you get with your 67-72?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
08-27-2020, 02:00 PM | #102 |
A Gen III or later Vortec will give better mileage than a carbureted or TBI engine. 5.3's as stated above should do 20 on the highway. My 6.0 with 4.10 posi rear and 16" wheels with tall tires gives about 16, and my foot is kind of heavy on it. I just love the off-the-line grunt of the LQ4. If I was lighter on the foot I might squeeze another few mpg out.
02-07-2021, 08:45 AM | #103 |
This 68 on ebay is meant to get 40 uk mpg's
https://rover.ebay.com/rover/0/0/0?m...2F293993455423
69 longbed 350 700r4 3.73 POSI cruiser |
02-08-2021, 03:17 AM | #104 |
369 with THM 400. 10 on the highway. 3/4T with 4:11's.
Same motor with a 700R4 mileage went to 13 on the highway. 30% improvement. Would only do 95 in overdrive. Any more throttle and it would kick down into 3rd. Missing one passenger mirror after the experiment. I know the transmission could have been modified to pull full throttle in overdrive. I only attempted this once and as such I didn't care. Didn't change much in town. Just crappy mileage like always. Rick |
02-08-2021, 04:32 AM | #105 |
71 vortec 350 with ramjet cam and 1.6 rockers , 2004r 3.08 rear gears 26" tall tires.
15 in town if I keep my foot out of it. 19-20 highway at 75-85mph Should do better once I lower it and add the belly pans and front air dam. and close up much of the front grill opening . The step bumper hanging down there is like a big parachute, |
02-08-2021, 10:02 AM | #106 |
Mr. Cheyenne
Stock 350/350 combo (mild RV Cam), 4BBL Qjet, 3.07 rearend with 275 /60 R15 - I haven't seen 10mpg yet, one time I got close.
Though I barely have over 800 miles on the rebuild and I do have a Qjet sent off for rebuilding and tuning. I also have set in the garage / driveway with a lot of idling or very short trips for test runs and not going easy on the gas pedal. Only a few weeks ago did I figure out I needed to adjust the kick down cable for the TH350. Before that, WOT did not much of anything.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 02-08-2021 at 10:11 AM. |
02-08-2021, 10:14 AM | #107 | |
under 10 is big block numbers. my 402 did better than that around town. Something is very wrong. These trucks are not heavy. |
02-08-2021, 10:22 AM | #108 |
Mr. Cheyenne
well, that makes me feel good - very & wrong - two words I really didn't want to hear/read about my truck :'(
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
02-08-2021, 11:15 AM | #109 |
Mr. Cheyenne
I wanted to wait a bit before filling up again but before my Sunday drive to Cars & Coffee I filled up. With my Sunday trip and after little drives to the stores I got 11.3 MPG - I used about 1/4 tank yesterday from sun up to sun down.. All my other MPG checks i had been doing all manner of odd MPG testing/driving I was doing. For the longest I was trying to figure out why I never had any power when I punched it (then finally figured out the kick down adjustment for a TH350).
I'd say 1/3 of driving was 50~60 MPH (stuck behind flat bed truck hauling a zillon bags of concrete), then my return trip 1/3 60~75 MPH, then the final 1/3 tooting around town for various stops to stores in town.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 02-08-2021 at 11:28 AM. |
02-08-2021, 11:38 AM | #110 |
if you have a holley, i understand reducing the main jet size and increasing the PVCR to compensate can really lean out high speed cruise AFR. Lower speed cruise is tougher because you have more idle circuit in play and there is a lot going on between the ifrs and iabs. But i bet most guys with a holley could pick up a mpg or 2 just by playing with the pvcrs and main jets.
02-08-2021, 11:39 AM | #111 | |
At what rpm is the mechanical advance "All in" |
02-08-2021, 11:46 AM | #112 |
Mr. Cheyenne
I would have to figure out how to do all of that ;-) I'll be researching - more fun for me.
02-08-2021, 12:17 PM | #113 |
Mr. Cheyenne
My 1st test with my hand pump to the Distributor JM6701 Vacuum Advance Canister, I pump it up to 10 and it drops to zero in about 25 seconds. I assume that is not good and the Canister should hold vacuum?
02-08-2021, 12:17 PM | #114 |
Who Changed This?
Does your brother have a variable timing light? He should be able to determine the total advance, if so, and could check the vacuum advance as well. I get 10 MPG in combined driving, mostly city. 400 engine, 400 trans, 3.54 rear gear and a big camper shell with a bunch of stuff packed into it.
02-08-2021, 12:33 PM | #115 | ||
Mr. Cheyenne
My brother is 5 hours away from me and the truck - he has passed it on to me :-) However, I got myself a Equus 5568 Digital timing light sometime back. I only used it to insure my timing hadn't moved and to set my idle. I just called him about the Vacuum Advance Canister not holding vacuum and he said, ya you need to fix that pronto..... no to figure out what the kind of a Vacuum Advance Canister replacement this Distributor takes (it was bought/installed by the previous owner).
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 02-08-2021 at 06:50 PM. |
02-08-2021, 06:19 PM | #116 |
Who Changed This?
There are a lot of different vacuum advance cans. They have different vacuum levels for actuation and different amounts of advance offered. I don't know how to steer you to the exact right one. On points ignition I've always used the one that gives the most vacuum advance, which in the Standard Ignition parts book was a VC-24A, IIRC. For HEI, I'd need to investigate. All I can tell you is that I have a Mallory HEI and don't know max advance or what the vacuum advance pulls in, either. I'll have to get one of those variable timing lights myself, as mine doesn't have that feature.
Here's a link. I'm going to read it myself. https://www.crankshaftcoalition.com/...ance_Specs.pdf
~Steven '70 Chevy 3/4T Longhorn CST 402/400/3.56 Custom Camper Simi Valley, CA Last edited by Steeveedee; 02-08-2021 at 06:24 PM. |
02-08-2021, 06:41 PM | #117 |
I get 12 highway or around town . But then I do 70+ with 4:11 gears 265/75r16s
02-08-2021, 07:46 PM | #118 | |
Mr. Cheyenne
Okay, I am set at 12 degrees and I am getting 17hg vacuum after she is good and warmed up off the manifold (I removed the A/C vacuum reservoir line that is tied to the tree and connect my Bosch vacuum gauge there). Connect up the vacuum up to the distributor canister, I rev up and hold at 2.5k. At this RPM I am getting around 40 degrees. It is as steady as I can keep my hand on the hot throttle and not drop my light, it stays steady there. Not sure if I did that right or those are good/bad numbers...
02-08-2021, 08:08 PM | #119 |
Mr. Cheyenne
Rats, at mechanical (no vacuum on Distributor) I am at 23° at 2.5K RPMs
02-08-2021, 08:42 PM | #120 |
Who Changed This?
OK, either you have too-strong springs on the advance weights, or the weights are stopping at the limits. The limits and/or weights can be modified. Is it an HEI? The VAC isn't that hard to remove and replace. Is it one of those electronic ignition distributors that look like stock?
02-08-2021, 09:13 PM | #121 |
Mr. Cheyenne
I am just repeating what George at topstreetperformance.com told me about the VAC. This unit is their low end HEI Ready-To-Run - there are no adjustment to this thing. Below is all they list, you want to change some things, you need to go pro.
But to be honest, I am looking else were and even to a Progression Ignition TSP’s Ready to Run distributor is designed for easy installation. With the included ignition module, all you'll need to complete your set-up is a coil. Using simple design elements throughout, it's a great way to get an easy-to-install ignition at a affordable price. With an aluminum housing, steel internal construction, and a high-quality ignition module, this distributor will get the job done.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 02-08-2021 at 09:27 PM. |
02-08-2021, 09:14 PM | #122 |
Ok, I’ll add a second response
Do you mean “Gas Smileage” ? |
02-08-2021, 10:59 PM | #123 |
Who Changed This?
OK, a whole new proprietary brand distributor. I ran a points distributor in my truck up until I put a Buick engine back in my '68 Skylark when the 305 SBC wore out. I then transplanted the Mallory HEI into my truck. I personally stay away from the aftermarket stuff that I've never heard of. I'm not going to be much help on that distributor, TBH.
02-08-2021, 11:08 PM | #124 |
Mr. Cheyenne
Ya, I am sewing on it - assuming that thing is actually good it is likely over kill for my stock engine. On the other end I am looking at a PerTronix Ignitor III D7100700 - far more reasonable and more out there in the wild.
02-09-2021, 04:47 AM | #125 | |
What is the initial timing set at? AND what is your cruise rpm. is it lower or higher than the all in (timing) rpm of 2500? |
