Old 11-04-2019, 03:45 PM   #101
Camaroguy
Camaroguy's Avatar
Re: Son's 68 c10 Short Bed
Got the frame all buttoned up and exhaust done. Still need to re-install the tank but you get the idea.
Former Build (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=724379 (SOLD)
Current Built (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=787712
Camaroguy is offline   Reply With Quote
Old 11-05-2019, 11:25 AM   #102
Camaroguy
Camaroguy's Avatar
A couple weeks ago, I spent the afternoon polishing the gas tank. Yesterday, my dad decided to redo it. I have to say, his work is obviously much better than mine.
Old 11-05-2019, 11:33 AM   #103
MDPotter
MDPotter's Avatar
Well now he's just showing off...
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 11-05-2019, 11:48 AM   #104
67C10GS
67C10GS's Avatar
Isn't that what dads do naturally though lol
1967 GMC C15 sb 6.0 lq4 pro daily. Named the “formula 10”
67C10GS is offline   Reply With Quote
Old 11-05-2019, 11:55 AM   #105
KevinK7
KevinK7's Avatar
...just lovin' this build
KevinK7 is offline   Reply With Quote
Old 11-05-2019, 12:24 PM   #106
Camaroguy
Camaroguy's Avatar
Yeah, at first I thought maybe he was punking me. Then after about 6 reflection pictures, I was positive he was punking me.
Funny.
Old 11-05-2019, 12:24 PM   #107
Camaroguy
Camaroguy's Avatar
Thank you
Old 11-07-2019, 11:07 AM   #108
Camaroguy
Camaroguy's Avatar
One more picture.....
Old 11-11-2019, 10:59 AM   #109
Camaroguy
Camaroguy's Avatar
I didn't take any pictures but we spent a few hours working on Saturday. We put a new diff cover on the rear end because the old one was bent on the bottom and the fluid needed to be changed anyway. Also, I finally flipped the shroud on the radiator so it isn't upside down anymore, and had to clearance a boss on the block on the driver's side to stop it from contacting the header.
So, little steps but still making progress.
Old 11-25-2019, 03:47 PM   #110
Camaroguy
Camaroguy's Avatar
Finally making some progress on the bed floor. Two weekends ago we started grinding and splitting spot welds. Saturday, we got the floor out completely and the rear section inserted and spot welded back into place. Today, they got the front section cut to length and inserted. Still need to get the middle cross braces put back in and weld the seam.
Old 11-25-2019, 04:05 PM   #111
MDPotter
MDPotter's Avatar
How did you end up with two sections of floor? I forgot that there was a flat section on the front portion but it looks like you have two new sections now?
Old 11-25-2019, 04:50 PM   #112
Camaroguy
Camaroguy's Avatar
Well, initially I was only going to replace the front, then decided to do both instead of dealing with that God awful bed liner. I had already ordered the front section and instead of sending it back and ordering a full floor, I just ordered a rear section. Plus, shipping the two sections was significantly cheaper due to size.
I'm actually pretty impressed with how it all is coming together. They come longer than an actual full floor and both front and rear are stepped to mate with an original floor. We cut about 5" off the front. Will have to weld the seam and body work it but it wont be bad. Now all the sheet metal on the bed will be new except the bed sides.
Old 11-25-2019, 04:55 PM   #113
Camaroguy
Camaroguy's Avatar
Here are some pictures of the whole floor laid out on the ground. Also, a picture of how they are stepped and approximately how much we had to cut.
Old 11-25-2019, 05:47 PM   #114
MDPotter
MDPotter's Avatar
Interesting, I had no idea! I'm interested to see what type of coatings you put on which parts of the bed. I was planning on 4 coats of epoxy primer to the underside of the floor, raptorliner to the top side of the floor, epoxy to the underside of the wheel tubs, then paint both sides of the sides, front panel, tailgate, and top side of wheel tubs.
Old 11-25-2019, 06:06 PM   #115
Camaroguy
Camaroguy's Avatar
Everything top side will be painted and finished as nicely as the rest of the truck with the exception of the inside of the bedsides. They will sprayed with undercoating to add a little texture and then painted body color. Everything underneath is already or will be sprayed with undercoating.
Old 11-25-2019, 06:09 PM   #116
Camaroguy
Camaroguy's Avatar
One obstacle I am trying to work through in my mind is what I am going to do for a fuel door/cap. This truck already had a tank underneath the bed and the filler neck is dead center. With a steel floor bed, you have to deal with the ribs so I don't know what we will do yet. I have some ideas but haven't decided.
Old 11-25-2019, 07:32 PM   #117
MDPotter
MDPotter's Avatar
I'm planning on buying a billet access door and using seam sealer to caulk the gaps between the ribs and the door, or cut and weld in a flat spot. You can either keep your cap or get a push-in cap too.
Old 11-26-2019, 12:06 PM   #118
Camaroguy
Camaroguy's Avatar
Yeah, I might end up adding some material so a cap will sit flat. Trying to come up with something a little different though.
Old 11-26-2019, 12:43 PM   #119
Camaroguy
Camaroguy's Avatar
The boy is working today and I just got these pics from my dad.
Old 11-27-2019, 11:00 AM   #120
SCOTI
SCOTI's Avatar
Cut out sections of your old floor where they are shaped to clear bolt holes & add them to the center rib.
I've also seen where they have 'bridged' the ribs so the center 3 are tied together in that area & have the same shape in between the ribs so it all looks consistent.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-27-2019, 12:53 PM   #121
MDPotter
MDPotter's Avatar
I like that third picture.
Tanks Inc has a fuel door kit but it's kind of pricey. You can always cut out a door assembly at the junkyard and weld it in too.
Old 12-09-2019, 02:06 PM   #122
Camaroguy
Camaroguy's Avatar
Thanks for the ideas. I was planning to get all creative but think I will end up ordering a Hagan door. Haven't decided if I am going to go with a square or round one yet, but will post pics once I do.
The motor harness should be here in the next week or two. In the meantime, I have ordered a fan relay and am just waiting for the parts to get here to fire this thing.
Old 12-19-2019, 04:33 PM   #123
Camaroguy
Camaroguy's Avatar
No real updates. The harness came in but we haven't had a chance to work on the truck.
I picked up this steering wheel as a Christmas present. Also, the Hagan fuel door came in.
Old 12-19-2019, 05:38 PM   #124
MDPotter
MDPotter's Avatar
I like my Forever Sharp wheel too!
Did you get the American Autowire Classic Update or are you talking about the LS harness?
Old 12-19-2019, 07:28 PM   #125
Camaroguy
Camaroguy's Avatar
Just the ls harness. I did the Autowire kit on the last one of these we did. Good stuff.
